Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Ice maker chute door
When trying to dispense ice, the door for the ice chute doesn't open to release the ice. We can reach in and open it to release the ice, but would rather it work as intended. :-) Might also help if we could look at a technical (rather than user) manual for the parts and assembly. Thanks
  • 237 Answers
Here's a location for a schematic to let you see what's all inside there. http://www.partselect.com/Schematics/Whirlpool/VM1P3RPM.gif
Posted on Dec 29, 2006
SOURCE:
THE ICE MAKER PRODUCES LOTS OF ICE HOWEVER WHEN I PUSH TO DISPENSE ,ICE COMES DOWN THE SHOOT BUT DOOR WILL NOT OPEN TO RELEASE.tHE WATER FEATURE WORKS FINE ON THE FRIDGE .i HAVE REPLACED THE DOOR SEAL BUT...
There is a small motor on the outside of the freezer that you can see if you look up inside the door opening for the water and ice. It may be a silver color and is not very big. On a Whirlpool it is between the ice chute and the water outlet. Also, sometimes the ice chute door freezes shut.
Mar 25, 2015 | Maytag Refrigerators
My ice maker makes ice but will not dispense it
When you push the lever to dispense ice, can you hear the motor running? If not, that motor might be dead and not turning the auger, which would be your problem.
If you can hear the motor and auger turning, the chute or the opening in the ice maker might be clogged up with ice. Clean the entrance to the ice maker and the chute in the freezer door and that should fix your problem.
Dec 13, 2010 | GE Monogram ZDI15C Automatic Icemaker
LFX25970 Bottom Freezer Refrigerator This morning it began to make a clicking noise coming from the ice/water dispenser and cold air was coming down from the opening. I pushed the lever for ice and it...
You may have an issue with one or more of the following:
* icemaker
* dispenser actuator
* ice chute door assembly
* ice dispenser solenoid (if the solenoid is stuck in an open position, the ice chute door/flap would remain open allowing cold air to escape).
Contact an appliance service company.
Feb 16, 2010 | LG Refrigerators
Will not release ice and makes crushed ice, even when on cubed.
I believe in your case the ice maker part number WR30X10093 being electronic with the control board in the front is the problem. I think the control board behind the front cover of the ice maker may have corrosion and causing the ice maker to malfunction. You can try disconnecting the set of wires to the coil on the water control valve and see if the water stops or turn off the ice maker first and try disconnecting the coil wires later. It has to be the control board or the water control valve part number WR57X10032
Oct 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
In door ice maker not working
In some cases, living in an area with extreme humidity, the ice dispenser door can stick open ( a small flap in the chute that delivers ice into the glass). This can cause a problem. The grinder in the dispenser sounds like it is frozen. Try using a HEAT GUN (hair dryer) on a low setting to defrost the dispenser DO NOT TRY TO MELT THE PLASTIC! Or a quicker solution, Unplug the refrigerator and pour water thru the dispenser CAN BE A MESS try to catch in a bucket or pan. Remove the dispenser from the door clean and dry as necessary and reinstall.
Try using cube ice to see if this helps. The occasional cup of cubes will dislodge stuck ground ice in the dispenser.
ABOVE ALL BE CAREFULL THE GRINDER CAN CUT YOUR FINGERS OFF. ELECTRIC SHOCK IS A DANGER AS WELL.
Sep 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Maytag side by side Refrig. - Ice maker chute door
problem is in dispenser, check switches and or selenoid.
Jan 05, 2008 | Frigidaire FRS3R5EMB Side by Side...
Bottom of ice maker/dispenser frosting over
Open the freezer door and look down the ice chute while you shine a flashlite up the dispenser cute from the outside. If you see light around the chute door, it needs to be replaced or something is wrong with the mechanism. The problem you describe is almost always air leakage around that flap.
Post back if you need more help.
Nov 17, 2007 | Whirlpool GC5SHEXNS Side by Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
384 people viewed this question
Top KitchenAid Refrigerators Experts
vince
geob91
Dakshinamurthy...
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
