Question about Technics SL-1210 Turntable
I have only one side of the signal coming through from the deck
It seem to be a intrmittent fault as it worked for an hour lastnight and then stopped. how do you replace the lead?
  • 515 Answers
More than likely either your RCA cables need to be replaced, or the tonearm is damaged. Do you use Ortofon Concorde cartridges by any chance? If so, the tonearm could be faulty, or the connection from your cartridge to your tonearm might be loose. Just tighten the nut a little bit more.
If you use different cartridges, then the issue is probably your RCA cables and need to be replaced.
IN either case, professional assistance is highly recommended.
- OPTiC
Turntable Repair Expert
Digital Analog Therapy
A DJ PRO AUDIO Co.
Posted on Dec 13, 2008
How to level the mowing deck on 2002 John Deere (Scotts) 42 " mower. Mower deck drags on right side. Mower height adjuster doesnt work seems jammed.
Have a look underneath while someone operates the height adjustment. There's probably a link arm come off which does deck height. Go to google images for this machine, type height adjustment and look at the pictures if you don't have a handbook. Google JD handbooks and see if you can find a free download.
Aug 13, 2016 | John Deere Garden
I have an old record player. It was made in the 80's according to my mom. I have recently started to use it( it hasn't been used since 86). With the exception of 45s, the record player will only play side...
I must say I have never come upon a record deck that will only play one side of a good condition record!
The only action I can suggest is to replace the belt if it's a belt driven deck. Please make a note of how it fits before removing the belt. But why any record deck would treat a new record any different on one side than the other will be a mystery to any good engineer.
The only exception would be if the deck played one side good then played up on every other record. Till it's switched off for a while, then repeats this action.
The cause of this fault would be a part overheating the longer the deck is left on. When you stop it to turn over, the system fails. This is however more likely to happen on a direct drive turntable, not a belt driven one.
Aug 24, 2014 | Audio Players & Recorders
My toro zero turn seems to overheat and stops moving from left side about half hour it runs fine.?
First check to see if you have any leaks especially on the problem let side. This includes the wheel motor. where hydro oil comes out, air can go in. either way it sounds like you need to take your pump out and open it up and check for metal inside. If you do not have any metal inside check the 5 pistons to see if they are stuck. What series hydro pump do you have?
10L 10A etc.
Jul 28, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Sound only from left side speakers!
If you put the good channel from the deck into the right and then left phono imputs of your amp, the sound should come out from the left and right speakers. If it only comes out from the left, then the amp as a right hand channel fault. Now if other devices work on both channels, then it's the pre-amp for the phono socket that has a fault on it. You should be able to find this by following the wires from the phono socket. If you touch around that pre-amp you should get it to buzz on either channel (where it joins with the main pre-amp). Doing this with a screwdriver will pin-point where the faulty part is (working backwards). PS don't short anything by touching to bits of metal together with the screwdriver.
Magnetic cartridges need a small pre-amp before they can be past to the main pre-amp. That's why you can't hear anything with the deck plugged into another line socket.
If you get signal on both left and right speakers with the above test the deck is to blame.
Jan 11, 2010 | Sony PS-LX300USB Turntable
Signal indicator brake lights and fm radio
You may have an intermittent switch or possibly a shorted or broken wire. As for the radio, I'd yank it and put an after market deck in. GM radios aren't known for their quality. But, you could check the back of the radio to see if the antenna lead is plugged in securely.
Hope this helps.
Aug 11, 2008 | 1999 Pontiac Grand Am GT
REFRIGERATOR ON BLEAK
sounds like a problem with the defrost timer / control board. the defrost timer cycles into defrost every 12 hours and turns off the compressor and fans. it seems like it is malfunctioning and causing problems with other components too.
Jul 08, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenwood KX-W6080 dual stereo cassette tape deck
I have the same unit which had the same problem. It has to do with dirty contacts on each tape mechanism.
Remove the main cover and look down on each tape mechanism. You will see 4 contacts on each unit. These come in contact with the tape. Remove each unit by removing 4 holding screws.
You will now be able to spray some contact cleaner into the front of the plastic contact cover. I removed the covers on both of the second from the right contacts so that I could clean them with an abrasive. These are the main ones.
Put everything back the way it was and the tape deck should work great.
Mar 24, 2008 | Kenwood Audio Players & Recorders
Technics SL-1210 Turntable Logo
106 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
