Question about Jura Capresso 560 Electric Burr Grinder
The bean container won't fit into the machine
I think that the been container was removed without turning it to the proper position. The continer isn't lining up properly.
5 Suggested Answers
SOURCE: Jura E9 grinder spins but does not grind
I had a similar problem, and solved it by turning the grinder by hand against resistance. Apparently the grinder wasn't really turning during the cycle and needed to be cleared. If your beans are "hopping" this may be a different problem.
Posted on Aug 14, 2009
Testimonial: "Grinder is turning but old bean oil is clogging it. Stirring beans on next brewing after drying the grinder was also customer services recommendation"
  • 1089 Answers
SOURCE: grinder doesnt grind beans although
I would suspect a log in the outlet shute where it goes into the grinds hopper. Clean it out and then turn the hopper to the coarsest setting to clean it out all together. Coarse grinds are a very good cleaner.
Posted on Oct 04, 2010
SOURCE: my jura impressa c9 coffee machine keeps tellnd me
I just called their customer service 800-220-5701 with the same problem.
There's a point at the bottom of the chute where you can add ground coffee that tends to clog, especially if water gets in there. Access is from underneath - - remove the bottom tray and reach in - - it's not the hinged flap opening (that's the first thing you'll feel) but if you leave that closed and reach behind it, there's a silver-dollar sized area you're supposed to try to access and clean using a dry cloth. Once that's done you're supposed to try vacuuming from the top and then let it dry for a day or two.
Posted on Dec 22, 2010
  • 29 Answers
SOURCE: Display reads fill beans, but bean are filled. I
This sounds like the grinder is not strong enough to grind properly. Try adjust the grind to a bit coarser, if this makes no difference then the bearings inside the grinder may gone. Try only fill a small amount of beans in the container and see if it works. It may be that when there is too much of a load on it it will not spin the blades.
Posted on Mar 29, 2011
Why won't it brew?
Think the grinding mechanism is jammed with something. Disassemble unit and look for same.
Sep 03, 2017 | Saeco Vienna Plus Black Super-Automatic
Tip
Saeco Italia automatic espresso coffee machine Grinder Cleaning Instructions
Saeco Italia Grinder Cleaning Instructions
Removal
Step-1: Remove beans that are in the bean hopper without spilling them inside. (Use Vacuum).
Step-2: Remove the beans container by removing 3 phillips head screws. Remove the rubber gasket from below the hopper. At this stage the upper burr will be visible.
Step-3: Rotate counter-clockwise the outer ring of the grinder assembly (the ring has gears half way around), until the red mark is at the 9 o’clock position, looking at it from the front of the machine.
Step-4: Lift the upper burr by using the fins that are on top. Press lightly on the doser adjustment gear, to clear it from the dose adjustment gear.
Cleaning-
At this stage, the grinding chamber will be exposed. Clean out any crushed coffee in the grinder chamber and the burrs. Use Vacuum and cleaning brush.
To Re-Assemble
Step-1: With the red mark on the outer ring still at the 9 o’clock position, replace the upper burr back into the grinder. Make sure that the red line (on the upper burr) is at the 3 o’clock position. This position will align the other tabs as well. During re-installation, press slightly on the doser adjustment gear so the upper burr will clear it as it is placed back in.
Step-2: With the Upper burr in place, rotate the outer ring clockwise until it stops. The two red marks should be aligned at the 3 o’clock position underneath the doser adjustment gear.
Step-3: Replace the soft rubber gasket back on the upper burr. Use the fins to align it properly.
Step-4: Slide the doser adjustment gear toward the front of the machine until it stops.
Step-5: Before replacing the bean hopper, rotate the grinder adjustment wheel to Zero (0), and the doser adjustment wheel to Minus symbol (-). Place the bean hopper into position on the machine, slightly adjusting each adjustment wheel as you are placing it down in the machine. Once in place, fasten the bean container with the 3 screws. Test each adjustment wheel through the full range of motion. The grinder knob rotates from 0 to 18 and back, and doser knob from Minus (-) to Plus (+) and back.
Now position the grinder adjustment knob at Eight (8) and the doser adjustment knob to the halfway point between the Plus (+) and the Minus (-) marks. This will put the machine back to the factory setting.
When using for the first time after adjusting the grinder, it may take more than one grinding cycles to make the first cup of coffee.
on Aug 12, 2010 | Coffee Makers & Espresso Machines
How do I dismatle the grinder on my Krups espresseria automatic
I suspect that as you have only managed to remove 2 screws from the beans container that this is going to be quite a task for you but here goes.
1) Remove the button from grinder adjustment by pulling or levering upwards
2) Lift beans container off
3) Remove front trim panel (square frame like a picture frame at front) Done by removing drip dray and thumping frame upwards with heel of your hand.
4) Undo 2 outer screws at top front of top housing
5) Undo screw in middle at back under where beans container was
6) Lift off top housing, you may need to rock & flex it a bit to release rear clips
7) Put knob back in & turn grinder adjustment fully right (clockwise)
8) You now need to mark that part of the grinder top that goes between knob and grinder so that you will be able to put it on exactly as it is now. Then remove that part from the top of the grinder
9) Now you can turn the top of the grinder anti clockwise further than the adjustment knob was moving it.
10) Once you have turned it as far as it will go you will be able to lift (with wriggling) the top part of the grinder out.
11) Cleaning out will be done with a small screwdriver and vacuum cleaner with nosey parker attachment fitted.
Dec 29, 2014 | Krups Coffee Makers & Espresso Machines
How do I remove beans from the machine?
Why don't you use the Hoover? I do that when I clean the machine.
give it a try,
kolbrun
Dec 04, 2014 | Coffee Makers & Espresso Machines
Keeps saying fill beans container when already full
The machine understant that there is not any beans in the container by the mesuring how easily the grinder motor rotates. If there is not any beans in the grinder motor rotates freely. In your case means that the beans from container are blocked to enter down to the grinders disk plates or they partialt enter, so the motor runs more freely and machine understant that there ae not enough beens. So you need to remove the beans and container and by the use of a vaccum cleaner remove all remainings from the grinders entrance and funel. You can also use a brush to remove any coffe oils and remianing so the bean can easily slide inside the grinder.
Jun 25, 2011 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Hi, my tchibo coffee machine display is showing bean container empty when the container is full of coffee beans.I have removed the container and made sure it is there is nothing obstructing the tube.i have...
Hello
Push "Off" on the coffee maker's control panel. Unplug the coffee maker, and allow the machine to cool down completely. Remove the coffee bean container by lifting up on it and sliding it out. Wipe it out daily with a damp cloth, and slide it back into the coffee maker. Press down on the handle to click the container into place.
Dump out the water in the water container,Wipe out the water container with a damp cloth. Refill the water container with clear drinking water.
Remove the dump box and drip tray, and empty them.Wipe each one down with a damp cloth. Open the service door and push "Press." Remove the brew group by its handle, and rinse if off in a sink with hot water. Use the key provided to unscrew the plastic pin holding the metal filters together. Rinse each one separately. Put the filter back together and dry the separate parts with a towel.
Mix a package of descaler with the water in the water container every four to six months to rid the coffee machine of mineral deposits. Plug in the coffee machine, and select "On." Select the "Hot Water" button, and position the steam valve over the drip tray. Dispense two thirds of the descaler and water into a container in 15 minute intervals by turning the steam valve counterclockwise to dispense and clockwise to shut off the flow.
Let the coffee machine heat up fully, and then dispense the remaining descaler and water by turning the steam valve counterclockwise to empty the water container. Press "Off" to turn the machine off.
If this does not work then you might require a technician.
THANK YOU FOR VISITING FIXYA
Feb 10, 2011 | Coffee Makers & Espresso Machines
How do I clean the bean grinder in a seaco royal profesionla machine?
These instructions come directly from the service manual. Notice the mention of a qualified technician. If you do this on your own be careful. If you don't follow the instructions correctly or you break something you've will have no one to blame but yourself.
-Clean the coffee beans container periodically; this operation should be accomplished by a qualified technician! Unplug the machine. Empty the coffee container and unloose the two fastening screws. Now, the container can be removed and cleaned.
-Carefully pull the adjustment lever upwards, previously writing the set grinding degree.
-Turn the adjustment ring counterclockwise, until the blue marks coincide.
-Now, it is possible to remove the grinding ring from the machine, slightly pulling it upwards.
-With the aid of a brush or a narrow vacuum hose, clean both the gear box and the grind ring support. Make sure the position of the grind ring does not shift. To reassemble the coffee grinder, carry out the reverse sequence, making sure the adjustment ring has not been shifted during cleaning. If that is the case, turn it until the blue mark coincide with one of the three notches. Assemble the grind ring support and make sure the blue marks coincide.
-Turn the adjustment ring clockwise, to make the red marks coincide.
-Fit the adjustment lever on the ring, until it coincides with the previously set grinding degree.
Nov 28, 2010 | Saeco Royal Professional Espresso Machine
Aug 14, 2009 | Jura Capresso Impressa E9 Espresso Machine...
Ginding problems, all clogged up
Follow these instructions to put grinder back together...
Items needed to clean grinder
1- #2 Phillips head screw driver
1 Cleaning brush
Prep:
Remove all beans from the bean hopper, vacuum out any
beans that cannot be scooped out by hand.
Remove the front and back screws and pull off bean hopper
container from the machine. (Note: The rear screw is longer
than the front screw.)
Note: Doser adjustment knob is available only on Vienna
Digital and Vienna Deluxe Rapid Steam.
Place screws in a safe place so that they will not be lost.
Cleaning the Grinder Viennas
back screw
front screw
grinder
knob
doser
knob
Before beginning to clean the grinder please be sure to turn the machine off and unplug it from the wall
socket. Grinder Tip: Using an oily bean will cause the coffee to build up quickly and clog the grinder.
Saeco recommends using a medium to dark colored bean that is not oily.
After cleaning the grinder and then brewing a cup of coffee it may take 2-3 grinding cycles for the machine
to dispense coffee.
Step 1:
Remove the black rubber gasket, then vacuum additional beans or grinds from the grinder area (Fig. 1).
Rotate the outer ring of the grinder counter-clockwise until the red line is at the 12 o'clock position (as
viewed from the front of the machine) or until the red line on the outer ring is 180º from the opposite red
line on inner burr ring (Fig. 2).
Lift the inner burr ring out of the assembly (Fig. 3).
Figure 1 Figure 2 Figure 3
Step 2:
Vacuum out any residual grinds from inside the grinder and clean the grinder burrs using the cleaning
brush (Fig. 5). Clean out the grinder coffee chute using the end of the cleaning brush (Fig. 5).
Remove the drip tray, open the service door, remove the dregdrawer and brew group. Gently pull
down the coffee doser door and brush out any ground coffee that may be inside the chute (Fig. 6).
Reassembly:
Be sure that the red line on the outer ring is still in the 12 o'clock position. Place the inner burr ring back
into the grinder making sure the red line on the inner burr is at the 6 o'clock position or 180º opposite from
the red line on the outer ring (Fig. 2). Once the inner burr ring is in place, rotate the outer ring clockwise
until it will not turn any further. At this time the two red lines should be aligned. The grinder is now at the
"0" position. Replace black round rubber gasket (Fig. 7).
Take the bean hopper container and rotate the grinder adjustment wheel to zero (0) (Fig. 8) and the doser
adjustment knob to the minus symbol (-) (Fig. 9). Slide the doser adjustment gear toward the left of the
machine until it stops. (Note: The Vienna Black does not have a doser adjustment knob. Only the Vienna
Digital & Vienna Deluxe Rapid Steam have a doser adjustment wheel.)
Reinstall the bean hopper container being sure to use the LONG screw in the back, then replace the finger
guard using the short screw in the front of the container. Once the bean hopper container has been
reinstalled, rotate each knob through the full range of motion. The grinder knob should rotate from (0) to
(18) and back, and the doser knob from the minus symbol (-) to plus symbol (+) and back.
Place the grinder adjustment knob at the eight (8) position and place the doser knob at the halfway
point between the plus symbol (+) and the minus symbol (-) symbol, or to your preferred settings.
For questions or concerns please contact Saeco Customer Service
at 800.933.7876 or email at support@saeco-usa.com.
Figure 4 Figure 5 Figure 6
Figure 7 Figure 8 Figure 9
Jan 12, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco royal coffe machine
Clean the central unit whenever the coffee bean container is filled, or at least once a week. If the water hose seems dirty it is probably due to hard water and needs to be descaled.
Descaling is done with a special citric acid you can buy in any grocery store or dealer of such machines. follow the directions and run clean water through afterwards.
To clean the filter:
Switch off the machine and open service door
Remove grounds coffee container .
Remove central unit, by holding the handle and shortly pressing the PRESS key. Wash the central unit with hot water; do not use any solvent.
Make sure there are no coffee residues on the two steel filters: the upper filter can be removed by unloosening and turning the plastic pin anticlockwise using the tool supplied with your device. Dry thoroughly each central unit component, fit the filter again and tighten it properly with the screw .
Remove coffee rest drawer and clean it, using a non-abrasive solvent. Clean the service area thoroughly and fit the coffee rest drawer again. By holding the central unit by its handle, slide it back into its original position, making sure it is correctly engaged. Then close the door. Fit the coffee grounds container again.
good luck, stephen
Jul 04, 2008 | Saeco Royal Professional Espresso Machine
Jura Capresso 560 Electric Burr Grinder Logo
90 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
