Question about Epson Stylus Photo 890 InkJet Printer
Epson Stylus Photo 890 doesn't respond
when I put the printer on, the green and the red light flicker alternately. The printer doesn't respond to the computer.
Would you have a solution for this problem?
thanks
Alex
  • Anonymous May 06, 2009
    scc? what exactly do you mean?
  • Epson Master
  • 541 Answers
Your printer needs to be reset the software is called the scc put that in google and you will see it
Posted on Nov 23, 2008
Hello my Epson Stylus photo 890 doesn't print. Everything seems to work fine, but sheet is White.
Print but blank result?
Error at main board, no electricity supplied to head through flexible cable. Check cable connection at board. Find a fuse there, check it.
Carriage moving is by stepping motor, printing by head.
Oct 02, 2013 | Epson Stylus Photo 890 InkJet Printer
My Epson Stylus photo 830 flashing lights
Got the alternate red/green flashing light ona photo830. The app shown by Bill Miller sorted the problem and got the printer back on line. Use the 'protection counter' / 'reset counter option'
Thanks Bill :-)
Mar 03, 2012 | Epson Stylus Photo 830 InkJet Printer
My Epson Stylus Photo 890 stopped printing. Both ink cartridges are full;there is no paper jammed inside. The green power light goes off and the maintenance red light stays on. Any advice ? Thank You
it could be the coagulation of ink in between the cartridgebetter dip it in mild hot water for some times and replace it wiping the water. it would do the trick and solve your problem . it has been practicallytested.
If this solution helpful/useful for you please rate my solution. THANKS FORUSING FIXYA.
May 17, 2011 | Epson Stylus Photo 890 InkJet Printer
2 red lights are blinking!!!!!
is both the light blink the same time or blink alternate ? if blink the same time, it's probably a fatal error..
if blink alternately then the waste ink counter need to be reset and the waste ink pad need to be replaced.
Jul 18, 2010 | Epson RX620 All-In-One InkJet Photo...
Epson C88 shows red alternately blinking lights
the problems are :-
  • cartridges are not recognised or installed
  • there is a paper jam.
Feb 05, 2010 | Epson Stylus C88 InkJet Photo Printer
My Epson Stylus R230 has both red lights blinking alternately
Your printer has reach its maximum count of cleaning and printing. This need to be reset using epson adjustment program. But before resetting make sure that you have replace the waste pad inside your printer or it is much better to point outside the hose where the waste ink goes out.
Jan 21, 2010 | Epson STYLUS R230 InkJet Photo Printer
MY EPSON STYLUS PHOTO R200 HAS THE RED A GREEN LIGHT FLASHING
WWW.EPSON.COM/SUPPORT AND DOWNLOADS, WHEN YOU FLIP OPEN THE COVER SEE IF THE UNDERSIDE HAS A INSTRUCTION APPLET ON CLEANING AND REPLACING INK CARTRIDGES, THOSE LIGHTS MEAN 2- THINGS RED-LIGHT, INK IS TOO LOW,NEEDS REPLACEMENT, RED WITH GREEN AFTER REPLACEMENT CLEAN HEADS, I HAVE SAME PRINTER , NOTHING MAJOR, USER GUIDE IS ON SITE ALSO IN PDF, FORMAT.... JON T
Dec 07, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson C48 red and green lights flashing alternately
Only Solution is Re-burn printer firmware.
Mahesh DG, Pune
Sep 08, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson Stylus Photo 890 InkJet Printer Logo
304 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
