Question about Hotpoint RGB745 Gas Kitchen Range
Everything else works fine except oven won't light
How do i fix it?
  • corpsman4 Nov 28, 2008
    The burners light, the oven quit heating, and an "F2" keeps flashing.
If its a gas stove/oven and everything else is ok, then its the ignitor at the bottom of your oven. first Open your oven door alittle til its stops the first time then pull it up and out. that gives you freedom to work. then pull out the racks. Now you have two screws that hold down the cover of where the ignitor is, unscrew those and pull off the cover, you'll see the ignitor. Pull out the drawer at the bottom and you'll see where its connected, disconnect it and take it to an appliance parts store where you can order one. Take the new one and splice the original wires onto to the new ignitor( make sure to use the ceramic wire nuts) and reconnect it and there you have it. It'll take you alittle time so dont rush. I change them all the time, it takes me like 10-15 min. You dont have to turn off the breaker, just DONT turn the oven knob ON
Posted on Feb 16, 2010
    Habit-Forming:
  • 171 Answers
The first part that goes bad is the element,check that you are getting power to it. electric stoves work like a light bolt and the switch on the wall, the oven thermostat is like your wall switch and the element is like the light bolt.
Posted on Dec 10, 2008
The bottom oven in is not heating.
I would call the service repairman , probably had a element go bad
Jan 06, 2016 | Ovens
Problem with Samsung microwave oven
My Samsung microwave is about 7 years old and everything works fine except it won't heat the food. What can we do to fix it?
Nov 24, 2012 | Microwave Ovens
LMA1560SB microwave--everything works fine (lights, clock, turntable) except does not heat food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 16, 2011 | LG 1.5 Cu. Ft. Full-Size Microwave - Black
I have a microwave oven over the range ,brand Frigidaire , model CFMV156DC purchased in 2006 and stopped working , even the lights on the front panel are on when I press the start button it happened just a...
I have exactly the same problem. Everything works perfectly even fan, except microwave table won't turn. I just found out what's the problem... The door for some reason is sitting too low now, even though it is not obvious at all. It looks leveled with everything else, but it's not. Set your Microwave to let's say 30 seconds and turn it on. It will not do anything... but you just gently lift the door (while closed of course) few millimeters and your Microwave will start running like new. There is something wrong with those latches on the door, not touching the microswitches inside the Microwave. Doors must be properly closed in order for Microwave to work. This is due to poorly design. I yet have to figure out how to fix that permanently.
Apr 15, 2011 | Frigidaire FMV156DC Microwave Oven
I purchased a microwave/convect oven combo last week. Installed today, everything works fine except that the lower oven won't heat. I tried turning the breakers off waiting a few minutes and back on. ...
Ensure that the clock is set and that is not in auto mode, the clock is only linked to the main oven and therefore it will not opearte if the clock is not set correctly, all the best
Sep 04, 2010 | Bosch HBN 9722 GB Electric Double Oven
Everything appears to work fine but it is not heating anymore.
If the microwave oven appears to be working but it is not heating the food, it is very possible that the magnetron, or its power supply has failed.
Jerry G.
May 03, 2009 | Hotpoint RVM1435 Microwave Oven
Everything works except heat
this is something you should probably call a repair technician for, due to the danger of the componentry.
Usually in ther case of this problem, even a technician will advise you to replace the unit, in the minds of cost effectiveness and safety...
Mar 21, 2009 | GE JE1540 Microwave Oven
Frigidaire conventional oven won't heat up
My frigidaire model is CPLEF398CCB conventional electric flat top oven. Everything is working fine except my oven. When I select pre-heat, broil or bake nothing lid up. No heat on the coil, only fan.Any suggestions?
Jul 03, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Hotpoint RGB745 Gas Kitchen Range Logo
249 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Justin Duby
Justin Duby
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
