Question about GE WBSR3140DW Top Load Washer
Water wont stop filling my washing machine
I think its only the hot water
    Sergeant:
  • 291 Answers
The hoses of the washer have gone faulty and they needs to be replaced to make it perfect.
Posted on Nov 23, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
A couple of possibilities:
  • defective water inlet valve. to check plug in machine, allow to fill with water, unplug, the water should stop filling if the v\inlet valve is OK, if water continues to fill, then it is faulty;
  • defective water level sensor/switch. this detects how much water is already inside;
  • part of the water level sensor/switch is the tubing. This in due course slips off, gets cut, cracks or plain worn.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
    Sergeant:
  • 276 Answers
His often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out
  • smarttech Nov 23, 2008
    A quick test to split up your possible trouble makers:
    Let the washing machine fill with water and when the washer is about 1/2 full of water unplug the washers power cord from the wall outlet. If the water keeps flowing into the washing machine with the power cord pulled the fill valve ( where the hot and cold hoses are attached to your washer ) has mechanically stuck open and will have to be replaced. If the water shuts off when you remove it's power cord from the wall outlet, try plugging the washer in and out a couple more times and if the water stops each time the fill valve indicates as being good = on to the next trouble makers.
    The water level control is responsible for shutting off the power to the fill valve and redirects the power to the timer to start the washing machine running once the correct water level has occurred. The WLC itself could be bad. The WLC uses a hose that the water level pushes air into to tell the WLC what the water level is inside the washing machine...the hose could be pinched, fallen off of the tub spout, has a pin hole, clogged up with calcium or soap curd and the WLC cannot "sense" or "tell" what is happening inside the washer.
    A tip from Scott...
    Hello there, I came across your site after researching why our whirlpool model no. LSR7233EQ1 washer was overfilling and not going to the agitate cycle. I did the tests that was suggested on your site and the problem pointed towards the water control valve. I removed the 2 screws and flipped the panel back to access the switch and found the problem. The hose that goes to the switch had simply come off, probably from shaking from unbalanced loads. I reattached the hose and secured it better with a spring clamp that I had lying around and did the final test (which passed). The washer works great!! This piece of info, I hope could be useful to your site to advise people to look for this simple solution. If it was not for your outstanding site, I would not have known where to start on this problem and would have probably tossed the washer out the back door and bought a new one
    Washer Basics: Filling with water:
    The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
    No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
    Brigadier General:
  • 3,614 Answers
What is the model maker of the unit...
check the control settings made on the unit. and also check the water level was functioning properly.
My washing machine wont fill up with water, what would the problem be, ive cleaned the hose at both ends so its not blocked?
usually the hot and cold water solenoid fail stopping water to flow
replaceable part
location
in where the hoses attach to the washing machine
May 09, 2016 | Washing Machines
My whirlpool washing machine wont stop filling with water after the wash cycle
your post is vauge
does it over flow
you mean it wont stop the rinse cycle
did you check it for a reset
do a factory reset
the machine will fill with water until the flow sensor and level has filled
so check and clean the machine
i find a couple of dishwasher cleaner tabs thru it first will clean all the flows and pipes and use a 60 deg long wash for whites
i think all the electro is aok so must be dirt
Sep 24, 2014 | Whirlpool Washing Machines
Washing machine stopped working. The lights come on but water wont start filling
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 25, 2011 | Washing Machines
Why wont the washer start filling ?
heatman101
Sep 25, 2010 | Kenmore 23822 Top Load Washer
Washer wont take in hot water
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
heatman101
Sep 23, 2010 | Hotpoint Ultima WF860 Front Load Washer
Washer wont fill
heatman101
dhjd
May 20, 2010 | GE WBSE2090A Top Load Washer
Hi there my hotpoint washing machinewma 54 fills up without the machine being on
Hello. your fill valve is faulty and needs to be replaced.
here is how the fill valve is supposed to work:
The fill valve--which is about the size of a coffee cup--is sometimes also called a "water inlet valve." It controls the entry of hot and cold water into the machine. The valve has three major components:
  • A hot-water solenoid
  • A cold-water solenoid
  • A mixing valve body
The inlet valve has three hoses connected to it, for :
  • The hot water from the house
  • The cold water from the house
  • The water directed into the washing machine's inner tub (either hot or cold, or both) to fill it with water
When electricity flows to one or both solenoids, water flows through the valve into the washing machine's inner tub. When the electricity stops, the water also stops.
Aug 21, 2009 | Washing Machines
Washing Machine Rinse and Spin lights are on
its the problem of drum getting blocked by any clothes getting tucked up.also try to move the drum manually with the machine off.if it makes any noise its the faulty motor.or drum has lost its alignment.it needs to be reseated properly in that case. -------------- The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
Jul 23, 2009 | Tricity Bendix AW1400W Front Load Washer
My washing machine wont stop filling with water
sounds like the hot cold water valve is bad,you also have the water level switch,the switch has a water level hose on it,some times the hose comes loose,chech y=that also,let me know what you find-mike
Mar 17, 2009 | Kenmore Washing Machines
Washing machine wont stop filling up
see if the water coming in is hot or cold by turning the water faucets off and on to see if one fills and the other dont and replace the valve
Feb 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
GE WBSR3140DW Top Load Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
