Question about Car Audio & Video
Radio will not load or eject cd's
I have a ford 6 cd radio
it had 6 cd's in it and i ejected 1
now it shows no cd's and will not load or eject
  • cascio49 Dec 26, 2008
    loaded 1 CD into player. Will not play or eject and neither will radio. Lights are on showing Track 1. Panel is getting hot
  • saidmalek97 May 12, 2009
    ford visteon cd 6000 car cd very low sound
  • 199 Answers
Hi , the mechs on this unit are awfull. my advise is pop off the top. get your cds out, and buy a new unit, not a ford 6 disc.
Mark
www.blueice-electronics.co.uk
Posted on Nov 25, 2008
6 disc CD player won't play, eject a loaded CD or load a new CD
You may have to remove the radio and disassemble it remove the jammed CD. Unfortunately, there is no easier solution for the problem.
Aug 31, 2016 | Car Audio & Video
I have a MB GL 450, 2008. It has a problem with CD Changer, it loaded 6 CDs before and worked great. But display start to show that "CD is being loaded" from yesterday. No lights that indicates...
If you have a magazine-type CD changer there may be a CD jammed in transit between the magazine and the player mechanism. Disassembly may be required to find and fix the problem.
Feb 20, 2014 | Mercedes-Benz Cars & Trucks
My Ford Explorer 6 disc cd has 1 cd stuck in it and it won't eject, play or let me load other cd's. How do I get the cd out?
take the radio out and take it apart and move the sensor out of the way and take the CD out you might have to replace the CD sensor
Feb 24, 2012 | Ford Cars & Trucks
Jammed cds in a 6 cd changer ford ranger 2002
sounds like the tray inside was misaligned when the cd went in. and it probally sent the disc into a occupied slot. you will have to remove radio and disassemble to repair. also try just unpluging radio and plug back in. sometimes it resets the radio and will start ejecting the cds
Feb 05, 2010 | OEM Systems Car Audio & Video
2002 Ford Exp Sport Trac - Pioneer 6 cd changer states cd error
CD CHARGE NEEDS TO REPAIRED OR REPLACED FIND A USED ONE ON COPARTS .COM
Sep 30, 2009 | 2002 Ford Explorer Sport Trac
CD player not working correctly
Try turning off the radio and disconnecting the battery for 1 min and then reconnecting the battery. Turn on the radio and see if that reset the radio so you can get your CD out and try cleaning the CD player with a cd player cleaner. Note you have to make sure the radio is off before you disconnect the battery. Good luck and hope this helps
Jul 29, 2009 | 2003 Ford Escape
6 disc changer will not eject cds==
One common solution is to disconnect the negative battery cable for 10minutes. When you reconnect, the stereo should reset itself and allow you to eject your CD's . Best of luck!
Greg
May 20, 2009 | 2003 Mercury Mountaineer
Ford 6006e cd changer with e 3 error keeps happening
The only way to do it is to remove the radio using DIN radio removal tool - then you will have easy acces to remove cd's if you do not have this tools try to use coat hanger (do small catss on the ends)
(you can try to hold eject button and swich off - swich on button - probably it will not work but try few times
Good luck,
Kamil
May 11, 2009 | Car Audio & Video
2005 ford expediton 6 disc cd changer
06 expedition 6 cd player and having the same issues,,, Disconnect battery and all 6 cd are stuck inside. "Error cd" shows when pushing eject. Looked everywhere and nothing shows how to fix it. I dont want to buy another radio/cd player for something that ford should know and how to fix?
Nov 14, 2008 | 2005 Ford Expedition
Have a Blaupunkt AM FM Radio/In-Dash Ch Cgnager (6 stacker) in a 2003 Holden Commodore. After ejecting the 6th one of the CD's succesfully, get "CD Error mech" message and it will not eject the...
We eventually tried loading another CD to fill the one vacant spot we knew was in the changer even though we'd tried that before without success. This time it seems that we fluked it just as it was trying to eject CD 1 again and - somehow - the CD we were tryng to insert must have lifted the rim of the one that was stuck and it suddenly ejected. The remaining 4 CD's that were inside the changer but not even recognised, then started re-loading so it appears that they were all jammed up together. Once they'd reloaded we were able to eject them all successfully then reload.
We're not sure but think that it may have happened when the eject button was originally pressed once to eject CD 6 then, in error, held down for a 'eject all' procedure and the changer has become confused with both instructions.
Jun 01, 2008 | Blaupunkt Car Audio & Video
Car Audio & Video Logo
267 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
