Question about Nautica Raceway N15520G Watch for Men
Nautica n15520 manual pls help
Can somebody help me whit a manual for the nautica N15520 watch.
email address:yo_bizar@yaho.com
jerryg50
  • 1689 Answers
SOURCE: nautica watch
The waterproof seal is not woking, or one of the controls was used while the watch was wet, and water came in to the watch. If this is not serviced soon, there will be eventual damage to the movement of the watch.
Jerry G.
Posted on Sep 15, 2008
SOURCE: manual nautica watch
I cant aline de hands in 60 line both hands
Posted on Nov 17, 2008
escapement
  • 2334 Answers
SOURCE: discolored white nautica watch band
If your watch band have UV sensitive pigmentation in it, there is nothing you can do, but buy the new band.
Find your nearest jeweller and ask to clean watch band in ultrasonic cleaner for 1 hour. If this kind of cleaning doesn't help, that means your watch band is UV sensitive and is and will be discolouring more and more by the time.
Alternatively you can try to clean it with the lighter fluid (ZIPPO). Soak a soft cloth in to lighter fluid and clean the band. Start with a small area inside band to make sure the fluid is not reacting as dissolver, as some resins react quite vigorously and tend to transform into chewing gum sort of state.
And again- if this cleaning doesn't help, the band is UV sensitive and discolouring is taking place.
That discolouring is happening becouse some of the colour pigments used in resin manufacture are sensitive to ultraviolet light and when exposed to sunlight or daylight, they react in a chemical
way, changing molecular structure, wich we see as the colour change.This process can not be reversed and this is why the band can not be cleaned.
Do not forget to rate please.
Posted on Jan 25, 2009
  • 2501 Answers
SOURCE: Where can I buy a new White Resin Nautica watch band.
If you go to the web site www.nauticawatches.com and select "service center" you will be able to see all the service centers. Choose your nearest and ask them.
Posted on Jan 26, 2010
Testimonial: "THANK YOU"
escapement
  • 2334 Answers
SOURCE: replacement band for my nautica watch N17524G
Follow this link and contact Nautica: http://www.nautica.com/helpdesk/index.jsp?display=store&subdisplay=contact Rate me plz.
Posted on Mar 04, 2010
Testimonial: "excellent work ! thanks a lot !"
How much is this Nautica watch the dial turns and the face is dark royal blue
Dale, Google search your make and model # to find watch value.
I found no nautica watches with that exact outside dial. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon ca watch nautica men Watches
http://nauticawatches.com/
Metal Bracelet
https://www.google.ca/search?q=Nautica+watch&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwi_8NiisIjOAhUlyoMKHVh0CeIQsAQIZA&biw=1024&bih=681
Jul 23, 2016 | Nautica Watches
Tip
NAUTICA watch manuals/instructions.
Follow this link: http://www.nauticawatches.com Click on WATCH INFO, then click on WARRANTY & MANUAL. Be aware - you will not be able to download manual unless you register your NAUTICA watch. Those are site rules.
on Jan 28, 2010 | Watches
Where i can buy a new strap for my nautica watch or where is the service center here in the philippines more better f you have service center in iloilo city??tnx
You might be able to buy the watch line at this website
Nautica watchstraps
In Philippines you can also contact distributor for Nautica watches
Distributor
TIME DEPOT
380 Del Monte Ave.
DSL Bldg.
Quezon City, Phillippines
Phone: 632 743-5219 EXT: 26
Fax: 632 731-7753
Email: inquiry@timedepot.com.ph
Or Nautica support at
TIME DEPOT
UNIT 306 LEVEL R3 POWERPLANT MALL ROCKWELL CENTER
AMAPOLA COR. ESTRELLA STREET
MAKATI CITY
Phone: +632.659.6723
Fax: +632 7317753
Jul 31, 2014 | Watches
Cannot adjust Nautica A31504 alarm !
Nautica are not giving opportunity to download user manuals, but you should be able to get information by following this link: http://www.nautica.com/helpdesk/index.jsp?display=store&subdisplay=contact Ask them to assist you.
Feb 24, 2011 | Nautica A31504 Watch
I want to buy wristband for my nautica n 135 30
This is a proprietary fit band. Only the manufacturer carries the band. You will want to contact Nautica's watch department customer service directly at:
custserv@timex.com
Nautica watches are produced by Timex, so this is the correct email.
Specify the model number, serial number, band number (if you see one on the reverse) and request price and availability for the band.
If the band is not available, they may be willing to offer you a new watch as replacement.
Feb 04, 2011 | Nautica Resin Round Chronograph #N14537G...
I need manual owner please nautica A36508
Hi
Please go to the following link.
http://safemanuals.com/zearch_7902.php
There on the lower right side you can see that "
Find user guide for NAUTICA
Please neter the no "A36508" as reference no.
Once you enter this no and click on search you will be asked about your email id.
Just mention the id. The maual will be mailed to you later.
Hope this helps.
Regards
TDCL
Jan 29, 2011 | Watches
Hi can you help me get the instructions manual
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all NAUTICA watch manuals.Rate me, please
Mar 15, 2010 | Nautica Windseeker N14505 Watch for Men
Where can I buy wristband for my nautica N14537G
Follow this link: http://www.nauticawatches.com Register your watch and find all the information available there. Be patient - this site is very slow for opening windows Rate me, plz.
Jan 28, 2010 | Nautica Resin Round Chronograph #N14537G...
Where can I buy a new White Resin Nautica watch band for Nautica N14537 Wrist Watch. Armando Mendizabal amendizabal@mayan-spa.com
Jan 25, 2010 | Nautica N07574 Wrist Watch
Nautica Raceway N15520G Watch for Men Logo
327 people viewed this question
Top Nautica Watches Experts
Jerry Greenberg
Jerry Greenberg
Are you a Nautica Watch Expert? Answer questions, earn points and help others
