Just wondering what the factory carburator settings are for weed eater model GTI 17 XPJust wondering what the factory carburator settings are for weed eater model GTI 17 XP
You can't post conmments that contain an email address.
The fuel line is self bleeding, if there is a lot of air in the pipe there must be a hole in the pipe or the filter is not completlt submerged in the fuel.
Your carburator is clogged.
1st make sure you have FRESH gas.
Empty and clean the fuel tank
Remove and disassemble the carburator and soak it in fresh gas for about 15 minutes to disolve any gunk.
Using a can of small carburator cleaner ( available at Lowes, Home Depot etc.) blow out all the ports.
reassemble and refuel with clean fresh gas
The little carbs clog easily
I would advise you to leave both sides with 235 45 17 this tire size would provide you with better handling and improved comfort also tires wil be more protected of suffering damage in the sidewalls caused by bumps and potholes just remember to keep them inflated at 38 +/- 2 psi.
here is a link to poulans website for user manual pdf files.......altho due to age the gti17t is not listed, may be able to find one on the net for sale...hope this helps!!
Are you sure that that the replacement is the correct one. Also, why did you have to replace the carburetor . Did you verify that the carburetor was the problem? Did the weedeater run by priming? Did you check the pump and lines? If these methods were tried and did not reveal the problem, then I suggest that you get professional help.
hi my name is hector and i have a problem. i nedd know who is the name of carburator or the description of carburator of the suzuki swift nlx or gti 16 valvules
