Question about ADIC FastStor2 LTO (90024202)
Adic faststor2
The job failed with the following error: The request could not be performed because of an I/O device error.
Try changing the autoloader SCSI ID and the tape drive SCSI ID at the front panel:
Use this option to view or change the SCSI IDs used by the autoloader. The autoloader occupies two SCSI
IDs, one ID is assigned to the autoloader and the second ID is assigned to the tape drive.
The default SCSI ID for the autoloader's SCSI controller is 0. The default SCSI ID for the tape drive is 5.
You only need to change a SCSI ID if there is another device, or devices, already assigned to these IDs.
NOTE: This option is primarily used if the autoloader is in an error state. However, any
backups that have not been verified as complete should be considered lost.
NOTE: If you changed the SCSI ID, you may also need to cycle power on the host
system and reconfigure your backup software before you can use the
autoloader. Consult your hardware and software manuals for more information.
Posted on Jun 27, 2008
How to recover data from transcend hdd when not appearing in disk management and not showing under my computer. system detects it first with clicking sound but after sometime error appears as device d
Use hirens boot disc look for programme in hard disc tools called test disk.it will check and repair mft which should then allow the drive to be seen and then fix errors.failing that route try and get spin right which will fix bad blocks.
Sep 08, 2014 | Transcend Storejet 25m2 500 Gb External...
Laserjet 2605 49 error
Error 49 is a firmware error. Try following these steps:
1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. You can try reprinting the job to see if it was a temporary error. 3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certainprint job, try upgrading the printer driver and / or firmware.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. Turn the printer off and delete the print queue. Then reboot printer AND computer, reconnect cables, and try printing again. 6. Remove all EIO devices from the printer (JetDirect cards, hard drives, etc.). If 49 error goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing. 7. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error. 8. Remember to reconnect all cables that connect the printer to the network or computer. 9. If the error persists, replace the firmware DIMM. 10. If error persists, replace the formatter.
Mar 10, 2014 | HP LaserJet 2605dn Printer
TRYING TO INSTALL EMPIRE EARTH 2 AND KEEP GETTING ERROR : DEFAULT COMPONENT ,E:DATA2.CAB,THE REQUEST COULD NOT BE PERFORMED BECAUSE OF AN I/O DEVICE ERROR. HOW DO I FIX THIS ? MY SYSTEM IS WINDOWS XP ....
A I/O device error would point to a faulty installation source. Is the CD/DVD in good shape ? no scratches?
Try cleaning it delicatly and install again. If this fails try to copy CD contents to your local drive and install from there.
Nov 11, 2009 | Video Game Consoles & Games
Request could not be performed because of an I/O device error
Search for a reset on the device--mine requires a paper clip to reset
Aug 27, 2008 | Audio Players & Recorders
"The request could not be performed because of an I/O device error"
if like that u just reformat your memory card with your phone..
or not u use other phone to reformat it..
May 02, 2008 | Nokia N70 Cellular Phone
TAPE LIBRARY PROBLEM
As I understand it, the SNC is basically a Fibre/SCSI Bridge... and what you are seeing is the FC light being on means that the SNC is connected to the Fibre SAN... but there drives aren't connected to the bridge. Check out http://downloads.quantum.com/scalar/S24/omUsersGuideSNC4000.pdf for information on how to connect to the SNC and run the discovery process. You'll most likely have to connect via serial connection, and the document I included does a great job of discribing that process. I'd suggest that you request an IP Address from your IT folks beforehand, so that you can configure it on your IP Network whaile you're at it.
Jul 24, 2007 | ADIC Scalar 24
Drive is not accessible. I/O Device Error
Drive is not accessible. The request cannot be performed because of an I/O Device Error
When accessing the above said error occured
Jan 26, 2007 | Matsunichi MF326 MP3 Player
ADIC FastStor2 LTO (90024202) Logo
392 people viewed this question
Top ADIC Computers & Internet Experts
Alun Cox
k24674
Are you an ADIC Computer and Internet Expert? Answer questions, earn points and help others
