Question about Sport & Outdoor - Others
Electric start problems
Techumsi 10 hp snowblower. Electric star will not crank at all. Zero sounnds when pushing starter. Any ideas?
Thanks Russ
    Novelist:
  • 148 Answers
It is probably the starter switch
Take jumper cables and connect the cables to the battery like you are going to jump start the battery,
make sure ignition switch is on take other leads and put the ground on metal frame of blower and put the positive (hot ) on the red wire going to the electric start to see if the starter turns the motor over
If it does then the starter switch is defective you can take it a part and see if the connections are lose
you can pick up a switch (buttn or toggle at radio shak
Good luck
Posted on Jan 01, 2009
MTD Mastercraft Snow King Snowblower (1997) electric starter stopped operating today (during a snow storm of course). Any ideas? Thanks. Checked cord - good condition. Power to the chord. David
It was running and stopped while using or it worked one day but not the next?
The Machine stopped running or just the electric starter? If just starter check to see if snow/ice built up around starter button.
Jan 06, 2017 | Garden
Why won't my Gold Star Snowblower start in the winter time?
Try using a spray starter like that used to start a car engine with a carburetor.
Feb 02, 2015 | Garden
Yardworks snow blower
Leaks are normally from bad seals or ones put on engine wrong. Many snow blowers leak oil, very common. Electric start needs to be taken apart. Rust is problem most likely. When you engage the starter it kicks out the gear to turn over engine. Carefully remove the starter from engine, try to start starter an if the pinion gear does not kick out from starter disassembly it an try to clean rust away from action. Dont break wires around electric motor careful about getting dirt an rust in winding. Try to lube spring an moving parts around gear. One other thing it could be a sheared off gear on starter also.
Mar 22, 2014 | Tecumseh Garden
Electric starter will not engage when trying to start snowblower
A common problem with snowblower starters. Rust gets all around the kick out pinion gear. When you apply power the throw out gear spring or mechanism is rusted an will not operate. Take it off engine an check for broken teeth as well. Most often is rust on starter clean if you can an lube but usually there is no fix
Jan 31, 2014 | Garden
Yardworks snowblower problem engine no starting
check out the interlock switch system, check battery with a load meter first to make sure battery is up to snuff
Nov 24, 2013 | Tecumseh Snowblower Snow Blower Starter...
Bad switch on Electric Started
hello,if it is the one i think it is to where the push button is a closed unit with no screws as far as i know there is no repair for the push button switch,how ever there is a good how to on u tube repairing snowblower electric starters,from what i have seen the push button doesn't go bad,now if the push button comea apart you can repair it which useally the black box or circut thing that cost around $40.00 found on most s 200 blowers,hope this helps,,
Jan 23, 2012 | Garden
I need a manual
Try Home Depot. They carry a wide range of snowblowers with tecumseh engines.
Jan 09, 2012 | Tecumseh Snowblower Snow Blower Starter...
Briggs and Straton 8 hp, craftsman snowblower stalls
Sounds like you coil is over heating after running a few minutes. The windings are seperating, then when it sools they make contact again. Try replacing the coil.
Feb 05, 2010 | Craftsman Garden
Starter on Sunfire won't crank
has the starter recall be done to the car yet if so it should have relay added to syatem and starter wire cut inhave with purple wire run to small wire on starter.
Dec 23, 2008 | 1997 Pontiac Sunfire
Sport & Outdoor - Others Logo
123 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
