Question about Canon ES50 8mm Camcorder
Canon ES 50 does not work with battery but works w/power supply
Have tried 3 different batteries but all with the same results, Nothing
  • Anonymous Mar 14, 2009
    I have the same problem. I bought a new battery and fully charged it but it wont work. It only works when directly plugged in.
Battery could be worn out mine doesnt even take charge anymore.You can still buy batteries for this camcorder for ES 50
Posted on Jan 13, 2009
Can I substitute a 625A 1.5v battery in place of a 625 1.35v for a Canon TX ??
The voltage difference is not appreciable so it should work given that it fits perfectly into the place of the other battery.
To be on safe side I would just run it past one of the tech specialists at Canon. The higher voltage would result in a little more current entering the apparatus.
Jun 16, 2017 | Canon Office Equipment & Supplies
My scale is not measure correct results. Already tried resetting, replacing batteries, etc. Nothing seems to work. Please help!!
Your body composition can change throughout the day reading differently in these types of scales. Eating, working out, or different times of the day will all change your results. Try using it in the morning only and on an empty stomach.
Jun 22, 2014 | Withings WS-50 Smart Body Analyzer - Black...
My Toshiba SDP93S portable DVD player won't work.
The power supply adapter may be dead, should be tested, if okay! remove the main battery will load player down in some cases. If still no result! cheaper to replace than repair.
Apr 02, 2012 | Toshiba SDP93S Portable DVD Player
BIOS wont start
Check the battery voltage. The battery may have failed and is overloading the AC pwer supply.
Aug 28, 2009 | Acer Aspire 5315 Notebook
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
APC external Backup battery is not working plz
It may just need a new battery. The UPS will do a self test on the battery when you turn it on. It may have tried to read the battery and the result came back as "failed". The batteries last about 3-5 years, even less if you live in an area with bad power. The batteries are very easy to change. You can buy replacements at www.batteryinternational.com/apc-backups-es-be350es-ups-battery-ups-batteries-f1.html
Jun 08, 2009 | APC Back-UPS ES 350 - UPS ( external ) -...
Canon PowerShot A630 power problem: NiMH batteries no longer work
I dont agree, I have tried several different batterie types and the batteries are draining almost instantly with the camera and they are not actually being drained. I think the camera itself is at the end of its life...as I have used rechargeable batteries for the last few years and now they wont even show as being charged on the camera. It stinks Im in your same spot now...no batteries are lasting even the brand new lithium ones...it has nothing to do with the battery "juice" but something with the canon supply power not recognizing/recieving the juice. Im not a canon expert, but I think the problem is more than the battery here Steve and im confused at the solution as well.
Apr 02, 2009 | Canon PowerShot A630 Digital Camera
Battery won't charge/no power to unit
Charger seams defective. get new charger and try.
May 29, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
Overseas Use
Yes. The power supplies and battery chargers supplied with all Powershot Digital Cameras are designed to work on input voltages from 100-240 volts (50/60 Hz). The only item that you may need is a plug adapter that allows you to plug the U.S. type power supply or battery charger into the foreign type wall outlet. Plug adapters should be easily available at a local electronics store.
Aug 31, 2005 | Canon PowerShot S10 Digital Camera
Canon ES50 8mm Camcorder Logo
136 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
