Question about Toshiba Satellite Computers & Internet
Toshiba tempro has stopped working ?
Whenever i start my laptop the following messege popup during window startup"toshiba tempro has stopped working".somebody help me,how to solve this issue.thanks
  • Toshiba Master
  • 6,771 Answers
Try a system restore before this became a issue.
Posted on May 17, 2012
admin734
  • 268 Answers
SOURCE: toshiba laptop problem
Ah , that simple means you have some corrupt files.....we can try a couple of things before getting too dirty:
  1. I would first suggest starting the computer up and tapping the "F8" key...it will take you to a black screen with white lettering. There will be an option near the bottom that reads "Boot Using Last Known Good Configuration" , select that option.....If you are able to get into Windows , we are done! If not proceed to step 2
  2. Ok , when you bought your computer you should have received a Windows XP disc..we are going to need that. Insert the disc into the cd drive and restart the computer. At one point it is going to say something along the lines of "Press Any key To Boot From CD" , when you see that press something on the keyboard.......It will now load up a blue screen.
  3. When that blue screen is done loading , you will see an option to enter the "Recovery Console", select that. This is going to bring you to a screen resembling DOS
  4. Now, type in the following commands with pressing Enter after each line.
    md tmp
    copy C:\windows\system32\config\system C:\windows\tmp\system.bak
    delete C:\windows\system32\config\system
    copy C:\windows\repair\system C:\windows\system32\config\system
  5. Now restart the computer and see if it boots into Windows , if it does not go back to the recovery console
  6. This time use these commands:
    md tmp
    copy C:\windows\system32\config\software C:\windows\tmp\software.bak
    delete C:\windows\system32\config\software
    copy C:\windows\repair\software C:\windows\system32\config\software
This should get you back on your feet, if not let us know and I can give you some further assistance!
Posted on Sep 30, 2008
sandrew
  • 2961 Answers
SOURCE: Laptop Freezes During Startup, before I can press any buttons or anything.
It could be a corrupt bios, which can be deleted with the removal of the bios battery or by the 'JBAT1' terminal to pins 2-3 then back to 1-2. The bios is probably set to halt on all errors and thats why it only goes so far. If there is no action at all; then there is a power failure to the motherboard or the processor has failed. Depending on your notebook age is whether it's economical to repair.
Posted on Jan 04, 2007
SOURCE: toshiba tecra A3
Have you tried starting windows in safe mode? or did you try the other choice of last known good configuration?
Paul
Posted on Jan 12, 2009
kamal1984
  • 1383 Answers
SOURCE: i have a eee asus laptop. I cannot startup the
you have to fix error on harddisk.
If you have winrecovery disk you can boot your computer with winxp recovery disk then boot computer with recovery disk then type in recovery console prompt "chkdsk /r" then pres "y"
then it fix error on harddisk.
Posted on Jul 13, 2009
  • 107 Answers
SOURCE: Hi, toshiba tecra A9 with windows vista fails to startup
the easiest way to save your data is to get a usb to ide (or sata) connector and plug the drive into another computers usb. Hopefully the hard drive is not too far gone and you can copy your data off. I would like to suggest that the hard drive is bad and you may not be able to save much. if you save your data I suggest that you try to reinstall windows and if this fails test the hard drive for errors
Posted on Jul 15, 2009
Toshiba Satellite A305-S6837 is in a "DO -LOOP" with the following:
Use the Windows Install disc and load on top of previous version. Do not do a clean install, this will delete all previous settings and data.
Jan 06, 2013 | Toshiba Satellite A305-S6837 (4400 mAh)
My toshiba nb200 would not start. During startup, after the "Toshiba" appears on the screen, it will just stop, and the monitor would sometimes be blue, red, or white. What could be wrong with...
1.Does the windows logo appear at start up?
2.Try to use other computer monitors and attach it to your laptop, then restart it. tell me what happens.
Mar 29, 2011 | Computers & Internet
About an hour ago, done a Toshiba Tempro BIOS upda...
Oh dear that's the worst thing that can happen during a bios update. the bios chip is probably now useless rendering the laptop useless. You will need a new motherboard I am afraid to say.
Jul 25, 2017 | Toshiba Satellite Pro L300D-EZ1002X...
Screen says windows didn't start properly...help! :(
Acctualy you hadn't specified, that the computer is working and then you find this messege every time, or that the computer is not working and this messege appears every time, First if the computer is working properly and you recieve this messege every time, so you must check if you were closing the computer properly (closing all windows before shutdown), Second if this didn't work and the screen still appears, thats means there is corrupted system files due to many factors (from it Infection with a virus), and you must reinstall your windows.
Jan 08, 2010 | Toshiba Satellite A105-S4384 Notebook
Booting is delay so much time
Try the following steps:
1. Tap "F8" key while computer is starting
2. Select "Safe Mode" from the startup options menu.
3. If the computer boots in safe mode, restart the computer and check if the problem still exists
This could happen if the BIOS update has created some changes which are not compatible with Windows Vista. Try updating the BIOS again.
Mar 25, 2009 | Microsoft Windows Vista Home Premium with...
Laptop won't start up in Windows due to a missing or corrupt file
No all you have to do is follow its instructions and use the Windows XP cd and during startup boot to the cd and during installation choose the repair option.
This will not make you lose any files and then you will be able to get in and back to work or whatever it is for again.
Dec 18, 2008 | Toshiba Satellite A100-S8111TD Notebook
C/windows/system32/command.com parameter incorrect at the startup. Hitting 'ok' wouldn't work out either.. what to do.. and yeah i ran spybot in the safe mode when this happened on the subsequent...
This worked for me after the others didn't, get REG cure and fix your system, it seems weird to fix a virus remover with a virus remover but it works and I'm only 11!
Aug 31, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
736 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
