Question about Sharp LC 20VM2 20 in. Flat Panel LCD Monitor
Sharp LC 20VM2 problem
I have two Sharp LC 20VM2 monitors which when powered up, power LED turns green, then shifts to red, diplay is blank with no backlight. PSU is giving out the correct voltage, all fuses are okay and when inverter board enable is grounded the backlight fires up no problem, no image at all though. I have 2 of these monitors with this identical fault which makes me suspect it is a common fault on these units - anybody have this problem and know which IC to change or where to look ? Thanks in advance/.
  • Burswood Aug 01, 2008
    My company has several LC 20VM2 monitors. They were used continously for years as digital signage, then, within three months 5 of them failed. They were working when unlpugged, but would not power back on or bring up a system menu for the screen.
    Does anyone know if there is a fault with the power adaptor or something easily fixable within this type of monitor?
  • Anonymous Mar 29, 2009
    the when the power button is hit.. the green light will come on for about 3 seconds then switch back to red... i've tried multiple inputs, vga, and all three av inputs for audio and video and s video.. with to avail... help please
SOURCE:
SOURCE: Sharp TV powers off after 15-30 seconds
FOR SHARP LC-13AV1U TV - is it lighting up with in 5 sec
Posted on May 11, 2009
  • 152 Answers
SOURCE: display blank - green led on and goes to orange
kilo2_tango2, You walked into this one!!! Let's cheer everybody up with a few laughs first. "where do I start looking??? Maybe in your pocket for lots of 10s & 20s. You will need them to do a swapout for a refurbished unit from SHARP, IF???? they even have a swapout program. "so psu probably ok" Well, maybe yes, maybe no. Is this psu a little black box that lays on floor, or are you refering to a internal to the monitor "switch-mode-power-supply" unit? By the way, you didn't even calculate for us the approximate number of "on" hours this unit has!! Ahh...Yes! You did type "display blank"!! I will assume that it is or was connected to a PC capable of displaying the WIN-desktop screen?? If such was the case, did you even do the "flashlight" test to see if the data made it to the screen? even if the CCFT's aren't lit up BRIGHT-WHITE on rear of LCD panel? Due to a INVERTER BOARD failure to supply 800-1200 v ac to light up the CCFT's. Well, k2t2 I hope some of this was helpful. Got to run now! I'm louie12fix on fixya or lmistyrel@aim get back to me if any of this made sense..
Posted on Sep 27, 2009
  • 7 Answers
SOURCE: I have Sharp LC-32D40U that will sometimes power
www.fixya.com/support/t218409-picture_goes_out
Posted on Jul 03, 2010
eagle338
  • 4889 Answers
SOURCE: I have Sharp Aquos LC-65D64U
It sounds like a backlight inverter to me. I am 99% sure. The buzzing noise you mentioned kind of confirms that, so does the backlight turning off. If you want to test them, then you are gonna need a multimeter. I will see if I can find a schematic in my collection, but be aware that this is a highvoltage device we are dealing with. May not be a good idea to test it yourself if you have never worked on electronics before. The sets hold nasty voltages for several days after its turned off and unplugged, and can injure you if you are not careful. I don't mean to scare you but its my job to tell you. If you want to proceed then I'm game.
Posted on Nov 01, 2010
vinceisaac
  • 2432 Answers
SOURCE: Sharp Aquos LC-C3237U no picture backlight OK green light on
check if their is a signal on voltages around 3.3v at the inverter board if none their is a problem in the board which is in the processor.
Posted on Aug 31, 2012
Need to troubleshoot a Sharp 70" LED TV: Symptom: No Picture, not responsive to controls.
Hello Doug,
I would suggest to test all the voltages in the power supply, If all the voltages test OK then It's more likely that the main board is causing the LED not to be responsive.
May 09, 2018 | Sharp Televison & Video
Sharp LC-50LE442U does not turn on. RED standby LED is lit, when I try to turn it on, the LED turns green but screen stays black. LED then stays green, won't go back to red when turning off.
You cannot tell if capacitors are bad just by looking at them. they need to have a meter called an ESR meter to test them, I can tell you with almost certainty that it is a capacitor in the power supply that has failed. The whole board is Sharp 9JY0950CTN02000 Power Supply Board (09-50CTN020-00) LC-50LE440U LC-50LE442U
May 27, 2016 | Sharp AQUOS LC-50LE442U 50" LED TV...
Sharp aquos model lc-13s2u-s . When first turned on , the red/green standby/power on led blinks for several minutes before finally turning green
The power supply may be failing. The blinking will continue for longer and longer periods until eventual total failure.
Sep 10, 2014 | Televison & Video
LC-42DH77E Sharp No picture Green led comes on then red LED comes on after a short while RED LED flashes twice then reoccurs .
maybe its on power supply try to check at power supply section check nearby parts of regulator ic if you can, test those passive and active parts using vom if those parts are ok then the regulator ic is defective
Apr 30, 2011 | Sharp LC40E77U LCD TV
My lcd model # 1901FP when power on dispaly on after 2sec diplay off at this time power led show green .again power on /off button off and on the same (power on dispaly on after 2sec diplay off at this...
Hi, This is a common problem with LCD monitors and is usually a result of blown capacitors or it could be a failed backlight as the inverter will shut down if it detects this. You will need to open up your monitor and you will be able to see if any capacitors have "blown" but failure of a lot of components will cause this symptom.
Oct 14, 2009 | Dell UltraSharp 1901FP 19" Flat Panel LCD...
Monitor comes on for a few seconds then goes blank.
Your looking at profesional repair. It could be DC/DC convertor, Monitor unit or PC/IF unit. (last two are expensive)
Jan 22, 2009 | Sharp LC-M3700P 37 in. HDTV-Ready LCD...
Sharp Aquos wont turn on
this is either a power problem or the screen needs re-gasing
Jan 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LC 20VM2 20 in. Flat Panel LCD Monitor Logo
67 people viewed this question
Top Sharp Computers & Internet Experts
Jason Harris
Jason Harris
Siul Oyaratgam
Joe Negus
Joe Negus
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
