Question about Whirlpool Duet GHW9150P Front Load Washer
Laundry comes out very wet
Whirlpool washer ultimate care III i checked made sure washer is level water seems to drain out but wash remains wet
  • 706 Answers
Hello tcburns07,
If possible, can you cycle a very small load of wash ( perhaps a towel or two) on the lowest setting to validate that : the washer is spiining up to normal speeds while draining water and that the water being drained is complete? Chancves are you have a either a blocked filter that limits water from completely draining, something in the drain pump or a restriction in your drain system. You could also have a worn belt that drives the pump. The test I suggested will at least determine if your washer is capable of draining all of the water from even a small wash load. Try that and let me know the results.
Posted on Nov 23, 2008
Lsw9750pw3 clothes still wet
If there is water remaining after the drain then the drain pump must be checked. Also check the TILT of the washer and must be inclined to the drain side.
If the clothes are wet then the SPIN RPM is insufficient or the program cycle time is not adequate. Please try with another cycle or check the motor, belt, capacitor as the RPM is low.
Jun 28, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
The clothes are still wet at end of wash cycle, it appears that the washer is not spinning.
Broken drive coupling most likely. These machines are great but I have 2 rules when it comes to these. No heavy stuff and leave the water level on high. You set the water on low for a small delicate item and the next person comes along throws in a basket full never sets the water level and BOOM the drive copling is broken. A comforter or rugs will do it too. Take all of those things to the laundry matt and your washer will love you for that.
I have a manual and 4 videos, coupling, lidswitch, pump, and agitator repairs HERE
Topsloshers blues featuring advanced repairs is HERE
Feb 16, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
What is the acuwash sensor
Washer temperature sensors and water level settings
The temperature of your washer's water varies with your laundry care needs. Standard washer models typically feature three temperature settings: Hot/Cold, Warm/Cold, and Cold/Cold—and higher-end models often offer as many as six or seven temperature settings. Temperature plays a key role in the effectiveness of your detergent—pairing the right detergent with the right setting for your fabrics and soil is important, as this will help reduce damage, prevent detergent residue, and provide the best wash across fabric types. For the best fabric care, look for washing machines with automatic temperature control (ATC). A sensor will control water temperature and ensure cold washes are above 60 degrees (F) to dissolve detergents, and warm washes do not exceed 93 degrees (F) to help prevent shrinking and bleeding.
The amount of water you use for each load also affects washer performance. Doing laundry is a bit like a science project. You need to make sure you are using the right volume of water, with the proper amount of detergent based on the dirt level of the laundry being cleaned. Too much of one component can result in a less-than-perfect outcome. Standard washing machines allow you to select water levels for different size loads, but some models offer more water-level options. Washers with automatic water levels use sensors to determine load size and adjust water level for best cleaning and rinsing performance. You will generally find these options in higher-priced top-loading washers. A benefit of front-loading washing machines is that most come with this automatic water-leveling feature.
Whirlpool® AccuWash™ temperature control sensor provides a temperature-controlled wash.
this is an article from the whirpool website, u can get a manual printed or downloaded by going to and going to owners center and typing in ur model number.......
May 21, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Water overflow when tub is emptying during spin cycle
It sounds more like you have a drain problem that a machine problem. Try draining into the laundry tub and check that the tub drains quickly enough. If not, you have a plumbing problem...Good luck...Nomess
May 14, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a Whirlpool Ultimate Care II Washing Machine. Lately, the spin cycle does not remove all the water. How can I fix this? Thanks. Bill
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 09, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care II stops after filling
Hi, could be faulty timer, faulty water level switch, faulty start capacitor for motor, or faulty motor. always put clothes in machine before starting. you can empty machine by lowering drain hose to flow level.
Aug 02, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
Water leaked from bottom of washer
Check the pump right where the motor shaft goes into it. The pump seal can leak right there and the water drips directly onto the floor. It will continue to run out after the cycle till the remaining water drains out of the tub and drain hose.
Jun 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II does not completely drain.
Mine will do this if clothes are left in it for a long period of time. The pump will not drain all water out because the will dry out the seals if they do. Your wet clothes dripped in the tub raising the water level to the bottom of the drum and that is why you have wet clothes. Remove clothes as soon as they are done, use cycle signal to avoid this.
Apr 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care 2 water wont stop filling...over flowing everywhere.
Your level switch hose has come loose.first open the display panel to check in back of water level switch,and look for a hose that is not attached to the back of it.
Jun 07, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine works, but wont do spin cycle- clothes sopping wet but clean
first off check to make sure its spinning at all. although the waters draining is it really spinning? are the clothes stuck to the side walls as if they had??if so i would tip machine back and look on floor and around the inside of cabinet approx 12 in. from ground level looking for oil,( transmission oil) . if present youll need a new transmission and clutch assy
Mar 04, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Duet GHW9150P Front Load Washer Logo
71 people viewed this question
Dan Webster
Dan Webster
Sal De
