Question about HP Compaq nc6220 Notebook
USB-device is not recorgnised
One of the USB devices is not recognised on my Compaq nc6220. This without having any external USB device connected to one of the 3 standard USB ports. Windows XP professional SP3 is installed.
rigth after startup, the balloon in the right lower corner starts up, and this repeats every 10 seconds. clicking the the balloon, the error window starts up, specifiying the location of the not recognized device in bold. (this window however remains white, and nothing is specified)
After half an hour to 45 minutes, the computer starts bieping. can this be so that there is a hardware / shortcircuit problem?
  • dcristescu Dec 20, 2008
    the fact that we have the same rather new software - damned sp3 - mkes me hope this is perhaps driver related. wishful thinking? :S
    with me it's an external hard disk that is recognized on other computers
    'someone have a clue?
2 TB G-Raid External Drive connected with Firewire cable is not recognised after Reboot my PC
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Mar 16, 2012 | Acomdata USB 2.0 2 TB External Hard Disk...
Hi, I'm installing widows xp in HP Compaq nc6220, but after setup loading files the mesaage (bottom of setup screen) "Setup is starting windows", then it did'nt contiue the installation,...
1 many times the the CD cant load as the files in the CD are corrupt or the CD is not read by the drive corectly...so get a new WinXP CD
2 try an external CD drive if your BIOS alows to boot from USB drive....(connect the external CD drive to the USB and make necessary changes to the BIOS boot seq in the BIOS screen...
BIOS screen can be enabled by pressing the F1, or F2 or the Del key as on as you start the PC
3 once in BIOS screen look for boot seq and change the boot drive to the foll
1st boot device - USB CD / DVD rom drive
2nd boot device - internal CD rom drive
and so on
if you can do the above then try the WinXP installation using the external CD rom drive....
else there is a little complicated method of using a pen drive thru USB (will discuss that later) provided your BIOS alows booting from USB
for more PC related issues visit my website
reg
kris
suresh_krishnan1961@yahoo.com
www.sureshayyar.110mb.com
May 18, 2011 | HP Compaq nc6220 Notebook
My samsung HM160HI external harddrive is not recorgnised by my laptop.I have tried different laptops,PCs and cables with the same results.This harddrive have been working 100% for the past year.
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 23, 2010 | Samsung SpinPoint 160GB SATA150 5400RPM...
USB applications unable to access Driver
reinstall ur o.s. and everything. (Backup ur files 1st)
Jul 03, 2010 | HP Compaq nc6220 Notebook
The emachine model KAWE0 is with operating system windows xp sp1 doesnot recognise any usb device.
Good day sir, hi, usually its one or two ports that does not recorgnise a usb device, but if all ports does not recognise the usb device, check the CMOS setup. check this out;
  • one or two ports does not recognise the usb device, this is a local fault, try to check the CMOS setup, this could also be the port itself is the faulty one having loose connection.
  • all ports does not recognise the usb device, this is a system fault, check again the CMOS setup if the USB port is enabled, check the USB device itself also. to make sure use another pc to test the usb device.
A computer virus can also cause the usb port to malfunction, run an anti virus software, if possible you can reinstall the XP and test the USB port afterward.
If all else fails, you can buy a USB card and plug it on the expansion slot on your PC.
Nov 04, 2009 | E-Machines eMachines Desktop PC
Tomtom home does not recognise device
Plug it in to the PC. Open the PC program. After it is fully loaded, turn on the Tom Tom. You must choose the option to Operate the device. When you are done, make sure you wait until it is shut down, before you disconnect it. Take it outside and try it.
Aug 07, 2009 | Tomtom ONE GPS Receiver
USB-ports
try to install the USB port drivers .
Feb 07, 2008 | HP Compaq nc6220 Notebook
Problem with USB ports on PA286A port replicator
is the usb port not detecting any other device or just to your docking station or if you plug any usb device and you get the message like not supported or may have a problem can you do that test and give me some more info
Jan 05, 2008 | HP Compaq nc6220 Notebook
HP Compaq nc6220 Notebook Logo
195 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
