Question about HP (311185-001) Motherboard
Asus NRL-LS P4 MB power on issue
Help!! my server with asus nrl-ls mobo powered down after a std ms windows update process and when i tried to restart the system by pressing the power button, there was no life in the system at all. the only sign of life was the green led showing power to the mobo and the network activity lights. any ideas??
  • 661 Answers
Unplug the power wait for 30 secs, then plug in and retry
Posted on Jul 26, 2007
"the system intruded chassis opnened
The NRL_LS has a connector for a microswitch on the case, to detect if the case is opened.
Look for jumper J2, between the battery and the bios chip, at one end of a long connector CON1.
There should be 2 adjacent bare pins at one end of J2.
Place a jumper block on them, and the system should start normally.
The manual is here +NRL-LS Cover.P65 - ftp.asus.com.tw
Look at item 9 on page 2-22, referring to jumper J2
Feb 09, 2011 | ASUS NRL-LS Motherboard
Asus mobo flashes on startup, no video
You should unplug the power cord from the power supply, pop out the cmos battery, switch the bios reset jumper to the 2 and 3 pins, wait about a minute, put the jumper back to 1 and 2 pins, put cmos battery back in, plug in power cord to psu and turn on pc. If you have any issues with this process please refer to your owner manual for the motherboard or look one up on their website. Please let me know if this fixes your issue.
Apr 30, 2010 | ASUS M4A77TD Motherboard
I have asus p5kpl-am in g31 motherboard, i have installed windows 2003 server but display and Network drivers are not working. Can you provide me display drivers for windows 2003 server. i shall be...
Don't see a Server2003 Driver Set on the ASUS Web Site. You can use the XP Drivers. Goto: usa.asus.com/support/downloads find your motherboard. To start look under the 775 Socket... they ask that first then locate P5KPL-AM/PS.
Once installed... MS update will correct or update the Drivers.
Run all of the MS updates after you install all drivers...even external drives. Then load your add-on software last... AntiVirus, etc...
Jan 24, 2010 | ASUS P5KPL-AM SE Motherboard
I have bios version 1008 on the computer. Should i update the bios version to the newest one? The fans are always running, they never shut down
Actually if your MOBO are working fine as of now no need to update the BIOS version. Updating BIOS version may affect some parts of MOBO so no need to update the BIOS version.
Regards
nicole
Oct 03, 2009 | AMD Asus A8V Deluxe Socket 939 Motherboard...
Asus mobo totally dead, no post, no beep, no power switch. help me please..
have you checked the power supply to make sure it is turned on, if so then proceed to the power cable and make sure it is plugged in to the back of the computer and the wall socket, if everthing checks out there take the side panel off of your computer and check to see if there are any little lights on the mobo if so then you know the mobo has power if it functioning properly the next step would be to replace the mobo with a new motherboard.
Mar 07, 2009 | ASUS P4R800VM MOTHERBOARD...
P4 3.2ghz to DC E2200
You probably should just because of the video card you are running. If your computer has a spot for a fan on the cabinet that isn't being used, it wouldn't hurt to drop one in.
Aug 06, 2008 | ASUS P5P800 SE Motherboard
ASUS P5B-VM DO Motherboard
Please update your BIOS if necessary to do some fixes, optimization, and even hardware or software support.
May 28, 2008 | ASUS P5B-VM DO Motherboard
My Asus mobo P5ld2 cant turn on
Did you try to unplug all AC Power; remove internal surface battery; and then jumper the 'reset' pins from 1-2 to 2-3 ? Leave in this state for about 5 minutes- then replace battery; re-jumper back to pins 1-2- replace AC power cord. Sometimes wiping out the BIOS setup information and restarting/re-setting it up will do the trick!
Apr 12, 2008 | ASUS P5LD2-VM Motherboard
Computers & Internet Logo
179 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
