Question about Memorex Televison & Video
DVD Player will not play in color?
We recently purchased an Memorex Progressive Scan DVD player, but it will not play the disc in color. Is there an additional setup piece we are missing?
  • boutimepc Nov 23, 2008
    We did get it to work. Appears to have been a color setting on the DVD player. Thank you.
    Sergeant:
    Champion:
  • 331 Answers
I dont think so  the DVD palyer is playing the videos that means the Player is connected properly
i would suggest you to check the color settings either of the DVD player (you might find how to do this in the manual,  would be easy) else check  wheather the color setting on your tv  are not set to SCEAM on the video mode.
hope this helps otherwose  please do post back and pls dont forget to rate the solution
Posted on Nov 23, 2008
"The Descent" movie does not play on my DVD (Memorex) player - but plays on my other DVd player (Samsung)? Why?
Maybe it the wrong region for the Memorex DVD
U.K is Region 2U.S is Region 1
Some other places require Region 3 or 4. It all depends on where you got it.
Feb 26, 2012 | Televison & Video
My memorex combo dvd & vhs player is not working right. can you help me? the vhs player works fine, but the dvd player display's a split screen on the tv with a large yellow box with the word PSCAN....
PSCAN is a short form for Progressive Scan - a line scanning format used for High Definition TV. Standard TVs use Interlaced scanning. On your DVD/VHS player, the VHS is an analogue signal recorded in interlaced mode so is fine for a standard TV. The DVD is a digital signal and cazn be processed for progressive scan output in order to produce a better picture on a High definition TV (or a TV capable of handling progressive scan). If you cannot to your TV via the HD outputs then you should be able to set the DVD player to output interlaced instead of progressive scan.
Mar 05, 2011 | Memorex MVD4540 DVD Player/VCR
Why does my dvd player have two pictures with PSCAN displayed across the screen?
The progressive scan it´s for high definition Tv´s and if you´ve got standard tv need to disable that function
Jul 16, 2010 | Memorex MVD2022 DVD Player
My Memorex MVD2042 Progressive Scan DVD player says no disc
the lens is located on the inside. you will have to remove the top casing, once you do you will see the dvd player, then you will need to remove the top bar that runs across it. you will see a yellow sticker on....undo the screws and the you will see the lens.....
Nov 16, 2008 | Memorex MVD2042 DVD Player
Memorex DVD player
if you cant get it to work will you be will to sell the remote let me know needs one bad cant play my mp3 on it anymore email me at josocuervo@yahoo.com
Dec 29, 2007 | Memorex MVD2042 DVD Player
Memorex DVD player
I just had this problem and did a search on the web and found the solution. There is a switch on the back of your DVD player for Progressive Scan. Turn it off and the message will go away and your player will work.
May 28, 2007 | Memorex MVD2042 DVD Player
GOLDSTAR DVD/VIDEO PLAYER
Remove any discs from the unit. Make sure your tv is on the blue screen. It should say "Progressive Scan Mode"....After removing the disc(s) from the disc changer, close the changer, press and hold the stop button on the unit, not the remote, for 5 seconds or more and it will reset to normal playing mode. Progressive Scan is typically only for TVs that use Progressive Scan....most normal TVs do not use progressive scan mode. Hope this helps...It worked for me!!!!
Jan 20, 2007 | Goldstar DV7411N DVD Player
Two screens and "pscan" issue
Look on the back of the dvd player. It has a progressive scan switch. Switch it off. Now it should have one screen.
Oct 04, 2006 | Memorex MVD2022 DVD Player
Memorex dvd player pscan split screen
Memorex MVD2042 - The only switch on the back of the unit had gotten bumped when something fell behind the unit, thus causing the same issue mentioned here. Looking at the front of the unit, the switch is straight back from the disc tray on the left. (of course, if you're looking at the back, it's on the right side) This switch is for "Progressive Scan" either "on" or "off" Thanks, Wizard_Yo
Jul 03, 2006 | Memorex MVD2022 DVD Player
Televison & Video Logo
343 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
