Need code for jvc tv for BD-512 universal remote control
Need help to tune jvc tv to bd-512 universal remote control need a code
5 Suggested Answers
josh1856
  • 105 Answers
SOURCE: remotecontrol code
One of these codes should work:
013, 031, 044, 074,119,120,121,122,123,162,167,170,182,195,205
Hope that helps!
Posted on Jan 30, 2008
  • 88 Answers
SOURCE: bd 512 universal remote control i need instructions and code to tune into video
Your manual is available free from the following address:
RC Files: Miscellaneous - Universal Remote Control Manuals Search (1)
Glad to help, please remember to rate this solution if you found it useful,
erch.
Posted on Mar 19, 2008
IrishDruid
  • 2712 Answers
SOURCE: universal Remote control BD-512
You can find the remote control codes for difrent brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 02, 2008
SOURCE: Remote control code needed
i have a connect- it bd512 universal remote control i need a code to programme in to my tv it is a baier please help!!!!!!!!!!
Posted on Mar 03, 2009
  • 7 Answers
SOURCE: what is the code for bush tv with the bd-512
try 022
Posted on Sep 12, 2009
What is universal remote code for bd-2000 on rcrno4gr remote
Remote code for HP BD-2000 Blu-ray player - AT&T Community
https://forums.att.com/.../Remote.../Remote-code...BD-2000.../467...
AT&TDec 2, 2012 - I have an HP BD-2000 Blu-ray player that I recently lost the remotecontrol for. I do not see HP as a manufacturer on the DVD list when I try.
Universal Remote Control Codes List - TV SAT DVR ...
removeandreplace.com/2013/11/10/universal-remote-control-codes-list/
Nov 10, 2013 - We compiled this universal remote programming code list to make it ..... Looking for a code for a orion vcr I have a 5 digit universal remote by rca -rcrn04gr and I ... remote control code (s) for a samsung blu ray dvd player bd-fm51 /ZA ... Please, could someone to give me the code for DENON AVR-X2000.
Programming the RCA RCRN04GR Universal Remote
voxrightnow.custhelp.com/.../programming-the-rca-rcrn04gr-universal-r...
Jul 28, 2010 - Program your Remote. To use this universal remote with your home entertainment system, first you need to program it to control your devices.
[PDF]Rcrn04gr - Universal Remote Control Codes
Jan 19, 2016 | HP bd-2000 blu-ray player with 1080p...
Tuning tv using universal remote control bd 512
Check this link to download the user manual to this remote control. It has all details.
bd 512 instruction manual edited
Feb 06, 2014 | Philips Televison & Video
I've BD 512 universal remote control,and i need code for Durabrand DVB-T CG5660-M digital set top box.Please help!!!
i need code for a durabrand dvb- digital set top box me remote is a bd-512 universal remote control
Jan 14, 2011 | Audio Players & Recorders
WHAT IS THE CODE FOE A BEKO TV ON A BD-512?
There is no such thing as a 'universal' remote; even the 'learning' remotes do not learn from every original. There may not be any code for all the devices you own. I suggest always checking the remote manufacturer's website for codes on all equipment you wish to control before buying any remote.
If you need an original remote, try remotes.com
Feb 15, 2010 | Beko 142746 TV
Bd 512 universal remote control i need instructions and code to tune into video
erch.
Mar 19, 2008 | Televison & Video
Mar 11, 2008 | Televison & Video
Remotecontrol code
Hope that helps!
Jan 08, 2008 | Jensen JER-422 Universal Remote Control
Televison & Video Logo
137 people viewed this question
Top Televison & Video Experts
Electro Med Services...
