Question about Moen 3867 Four Function Hand Shower With Slide Bar
Power in shower
Triton shower goes from hot to cold & has no power on hot water cycle -----triton t 90si
Blessedbygod
  • 85 Answers
SOURCE: Shower water temperature regulation
The temperature is adjustable. The valve has a disc you pull off the front of valve and then rotate the seat I believe counter-clockwise. If you get the paperwork for this valve from moen it is very explanatory. I can help further if needed, Let me know!
Posted on Nov 11, 2009
jeff_drakesr
  • 155 Answers
SOURCE: no cold water from Moen 2253 tub/shower valve,
Here is a quick check to see if the cartridge may be at fault allowing the cold and hot to mix. Turn off the hot water supply, with hot water supply off turn faucet on. Turn to the hot and cold sides, If you have only cold water then your faucet cartridge is at fault or the cartridge housing is worn. Shut all supply valves and remove cartridge and inspect housing for signs of wear. If wear is visible a new shower valve is needes. If none visible replace cartridge. I have included a link of a PDF file an exploded parts list. I hope this helps in solving your problem. Please rate if the answer helps in any way. Good Luck and have a great week. Jeff
Posted on Apr 05, 2010
  • 119 Answers
SOURCE: & One Handle Tub & Shower Faucet : i have a moen shower faucet and i get not hot wate...
these valves can be adjusted by removing the handle and adjusting the white gear that regulates the hot and cold that come out, try going more to one way if it gets colder then go the other way.
Posted on May 19, 2010
  • 1340 Answers
SOURCE: Posi -temp shower fixture. Can't
That sounds like the thermocouple within the heater to me.There are 2 sections within the thermocouple.A reference section(what you want it to be) and an actual reading section.The difference between the 2 twists 2 pieces of metal which are different elements and causes a signal to activate/deactivate heater.It is simple but surprisingly accurate usually within 2 degrees F.Whatever is going on,it seems awful backwards.Checking the heater is definitely the best first choice.The shower hood is not likely to affect the system unless it had it's own heat or something.That is not the 'normal'function though.Also,after you do get it fixed,we have our water temperature set so that taking a shower requires very little cold water.Saves on water and power because hot hot water is only really needed if you have infants.Ours may be about 140F,150F,160F,don't remember exact and it's hard to access.Set a temp and let sit 24 hours and try it after it's fixed.Probably adjust in about 10 or 15 degree increments,depending how far off it feels compared to what is tolerable.Good luck,Greg If you have any questions or need more help,just comment here and I will get an autolink to your post and reply ASAP.Greg
Posted on Nov 30, 2010
packrat1948
  • 528 Answers
SOURCE: One of my showers (witch is only 5 feet from the
Lets watch a video
http://www.youtube.com/watch?v=J-SNBNijfQc
The hot and cold being reversed is an easy fix. When he took the handle off and exposed the cartage the small stem in the middle there are two flat spots on the stem with the screw hole in it just take some pliers and turn the stem 180% you don't have to turn the water off for this. DON'T TAKE THE KEEPER OUT FOR THIS!
If cartage dosen't want to come out as mentioned in the video be ferm with it but don't get ruff. If the cartage was hard to get out it is a good idea to sand or clean the hole it came out of some very fine sand paper wraped around a pencel well do the trick. If you do sand use a squirt bottle and wash any debree out of the hole.
Posted on Jan 30, 2011
Testimonial: "Thank you! I final got my shower back."
Triton cara shower has power and water to it but nothing comes out
CHECK YOUR POWER SUPPLY BOX MAKE CERTAIN THAT IT IS INDEED ON IF SO IT MAY BE A BAD CIRCUIT BRAKER MAY NEED TO REPLACE IT.
Apr 15, 2014 | Camp Chef Triton Hot Water Shower Heater
Triton showers after runs hot then after a while goes cold
Is it possible that you don't have enough water pressure, electric shower heater elements will cut out if the water pressure gets too low, try increasing the water flow.
Apr 13, 2014 | Kitchen Appliances - Others
Triton caselona water temperature
Sorry to ask but are you gradually increasing the water temperature from cold to medium to hotter. Let it run a little while hot and cold mixes to give you your desired level. Also try cleaning the showerhead to remove any build ups (a maintenance issue).
Jul 15, 2013 | Home
My Triton t80si shower "cycles " going hot then cold then back to desired temperature - only just started happening no problem with flow of water
It sounds like the cartridge has to be changed. Pressure balance is not working in the cartridge.
Apr 13, 2013 | Home
My triton 90si goes from hot to cold and keeps
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Nov 09, 2009 | Rubinet 41RBHOBK H2O 1/2 Temperature...
Triton Leona shower - when it is first turned on the water runs cold, as soon as the hot water begins to flow thru the shower trickles and then 1/2 wat thru the shower the cold water bursts into action and...
yes the hot side could be pluged with something . or cartridge has somthing in it. if the shower is new solder could have got into the valve. you need to make sure the water is turned off the the house and take it apart.
Jun 15, 2009 | Orange G1600 Series Emergency Showers
Triton T90si electric shower temperature stuck on hot.
It sounds as though the valve is not closing and opening properly. I would have a proffesional come out to have a look. I could also be the control board not working correctly or a combination of both.
Mar 22, 2009 | Home
Moen 3867 Four Function Hand Shower With Slide Bar  Logo
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
