Question about Compaq (166361-001) Motherboard
Cant find Cmos command Desktop pro
Im trying to get to cmos on a old desktop pro to change HD settings
to enable second drive . could someone tell me command. F 10 goes
to set up but not Cmos is no help. I tried life gauard floppy no help help
Need to auto enable but cant get there.
  • Mike Sicola Nov 23, 2008
    I cant find auto enable to set up 2nd hd slave .This screen look like things are missing.
  • May 11, 2010
    Setup is CMOS. That is, if you make changes through the setup screens, you are changing what is stored in the CMOS. What do you mean when you say you get to set up but not cmos?
  • 519 Answers
Have you tried the F1, F2, or Del keys instead of F10?
Posted on Nov 30, 2008
At start up the comp indicates Plug & play Config Error then prompt F1 OR F2. F2 being setup while F1 says continue. (XP system). Downloads files then indicates it is starting Microsoft but nothing...
F2 Enter Setup (CMOS settings) Use arrow keys to navigate ALL menus. CHANGE NOTHING just look. After you have seen all go back thru and write down any settings you think might apply.
things like: Plug and Play operating System (yes or no); Assign IRQ ( use automatic for all ); Reset Config Data (YES).
Then go back thru again and change settings ONE AT A TIME be sure to make note on paper what you change and old setting and new setting you are testing.
EACH time you change a setting save settings and resume boot.
Is it fixed ?
reboot and enter setup if and change that setting back, Test the settings you think may apply one at a time noting any additional errors or improvements or simply no effect.
Use your intuition, TAKE MOST EXCELLENT NOTES, change only one thing at a time at first being prepared to change it right back if a problem arises.
If you can not get it solved with a CMOS setting you could try setting it up from the beginning. Swap in a new HD, take small watch type battery out of socket on mainboard to power off CMOS chip and thereby clear it's memory. The default CMOS settings will be used. Boot from install CD and install windows all over again on new HD. Once you have a bootable machine in stall old HD as second HD so you can access it to transfer over files you wish to save, then you can erase the old HD by formatting it and have more storage space if you want it or simply remove it.
Sep 16, 2013 | Dell Dimension 8200 PC Desktop
Acer Power F5, Set up did not find any hard disk drives installed on your computer,
Have you checked on the BIOS/CMOS Setup if the SATA is enabled? It it does not work try changing your sata cable with a good one... Good Luck.
Apr 29, 2012 | Acer Power F5 PC Desktop
Dell Inspiron 546 MT : replaced cmos battery due to checkpoint error, and now receive a CMOS checksum error and asks to either press F! to run setup or pree F2 to load default values and continue. Wh
Hello there, I am the computer technician that will be assisting you today.
My name is Norman-Wynne Damstra.
Welcome to Fixya, Jbellovary.
Since the battery was removed the CMOS would have Cleared as it needs power from a battery to retain the settings.
This therefore means that the BIOS/CMOS has already been reset to defaults and this is why it is giving you this message.
It sees that the settings have changed and it wants you to tell it why.
When this screen comes up Press F2 to load defaults.
Then let it run.
You will now need to enter the BIOS/CMOS by tapping the delete key on first powering on your computer, until you see the BIOS/CMOS screen.
Now set the date and time and set the Boot priority to HDD, then DVD drive.
Also enable USB2.0 support if it is disabled. Check that your drives are being detected.
Save and exit setup.
It should now be A-Okay.
Take care!
Feb 02, 2012 | Dell Inspiron 546 MT PC Desktop
Working on a Dell 530 Desktop, installed a new WD 500gb Sata Hd and after setting up Boot in cmos cant get by following Boot to CD Boot Device not installed enter ready to continue. Need Help OS CD in in...
Go back into the Dell CMOS and try reseting all settings back to default. Restart and when it starts to boot, start tapping F12 to get to the boot menu. Try booting to the CD drive now.
***Please rate if this helps you or ask more detailed questions for more help. Thanks
Dec 15, 2010 | Dell Computers & Internet
EMachines ET1810-01 trying to install xp pro on clean hd, cmos does not show hard drive and xp says there is no hd. it is connected. how do i get it to find the hd?
You need to format your hard drive. Set your boot device to cdrom in your bios. Boot using xp cd.DO a reinstall of windows and it should give you the option to format or delete partitions on your hard drive. if that doesnt work try putting the hard drive in another computer to see if it works. Or you can buy a hard drive enclosure that allows you to use your hard drive as an external device.
Jun 11, 2010 | eMachines (ET181001) (A1803181 ON) PC...
Cant get 4600i started. powers up but will not get past intro screen. screen shows F1 to continue and when i press F1 it tells me to press it again to retry reboot, F2 for setup options.
you need to go to cmos or bios setup, set all the date and time and proper boot setting there save and exit, it is a cmos or bios failure that causes these problems try replacing the cmos battery if the message still continues
Nov 22, 2009 | Dell Dimension 4600 PC Desktop
Acer M1100 Desktop w/ a different HDD and Optical will not boot
Disconnect the hard drive and dvd from the motherboard
Power on
If you get video and cmos access power off and connect dvd
repeat and connect hard drive
getting video and cmos access has nothing to do with the hard drive...with no hard drive or optical drive you still would have access to cmos
go 1 step at a time to find bottle neck
Jul 02, 2009 | Computers & Internet
No post screen, cant access cmos settings. but windows starts as usual just a blank screen til then?
Its possible that your cmos settings were changed prior to this problem so as not to display cmos settings options at boot up. Have you tried resetting your cmos settings to fix the problem? You can do this by a jumper which is usually found on the mother board named "clr cmos" (clear cmos).
Let me know if this is of help or not.
Apr 25, 2009 | Dell Dimension 2350 PC Desktop
Cmos checksum bad...usb current status detected system shut down 15 sec
asus manual .pdf bios Version 1301 is the last one what is your version
also does your power supply support 1amp for 5VSB
Apr 05, 2009 | Computers & Internet
Need to Rewrite/Reboot Dell Desktop 2400 series and cant
Press Delete at start up, change the first boot device to your cd drive, then F10 to save settings and restart. Put your Windows XP disc in the drive and press any key when prompted to boot from the cd.
Jan 01, 2009 | Dell Dimension 2400 PC Desktop
Compaq (166361-001) Motherboard Logo
63 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
