Question about Ovens
Oven shuts down in middle of cooking
Thanks for your help but we never use the fan and it is as if the entire power in the oven shuts down except for the digital display and the noise it makes is disturbing im waiting for it to blow up or something but as i said it starts working again after about an hour or so
  • Ovens Master
  • 3,463 Answers
HI.
What is the make and model of your cooker?.
I do not know the answer at this stage, more information would help.
Cheers
Posted on Nov 24, 2008
Temperature when using frigidare oven, keeps getting hotter and does not cool down
Good Afternoon Andrea,
I see that you're having issues with your Frigidaire oven, and the heating element being red hot the entire time you were cooking no matter how much you turned the temperature down.
I suggest giving your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for at least 2-3 minutes. When power is restored to your oven, you will need to set the clock by entering in the time and pressing start. Preheat the oven, to whatever desired temperature, and if it is still running hotter than it should be, I suggest you contact your local authorized technician. I hope this is helpful.
-Best Regards-
WP
Apr 22, 2014 | Frigidaire Ovens
GE Built In Wall oven JTP25SOH6SS wont completely shut off
The cooling fan will stay on for a long time after using the oven. It should shut off after a while. If it is running all night for instance there is a great possibility that a relay is stuck on the control board.
Apr 13, 2014 | GE Ovens
Kitchenaid KEMS378sss fan noise
Does it keep heating food? You do not run it without the fan very long and maybe it will shut off or down when it senses the fan stopped and might stop cooking. You want to isolate it is the fan and not the magnatron (cooking device). It is pretty new for that but always a posibility.
Do you have a straight vent fan that you can turn on without cooking? try that and see what you get. If it does the same, I think you have a defective fan.
e
Nov 19, 2011 | KitchenAid Architect Series KEMC308KSS...
Oven shuts off in middle of cooking/baking. stove top burners work just fine.
GE oven - SHUTS OFF ON IT'S OWN
I have a built-in GE Electric oven - model #JTP20B0F7BB. It shuts off in the middle of cooking sometimes, but not all of the time. It does it about 1 out of 4 times that I use the oven. Any help would be appreciated?
Apr 17, 2011 | Jenn-Air Ovens
The oven is not work or better say works for little be and going off. could you please help or please let me know what telephone should I call?
Hi,Everything operates normally, but the oven shuts off after varying amounts of time. This could be a faulty magnetron, bad cooling fan (or just built up dust and grime block ventilation grilles), bad thermal protector, faulty controller, some other intermittent component, or bad connections.
  • If resetting it allows cooking to resume immediately, if even for a few seconds, I would not suspect the magnetron or thermal problem as no cool down time is required. It could be bad connections in the controller or elsewhere, a marginal door interlock switch, or a controller problem. Jiggle the door to see if this will cause it to shut off.
  • If the magnetron was overheating, you would not be able to resume cooking until it cooled and the thermal protector reset. If it just stopped working (i.e., the filament opened), everything would appear normal but there would be no heating. If the magnetron were shorting, there would likely be a loud hum associated with the periods where there was no heat.
  • If it is not possible to resume cooking for a few minutes indicating that something needs time to cool off, then the magnetron could be faulty but check for the obvious cooling problems first: blocked or dirty ventilation grill. Determine if the magnetron cooling fan is operating by listening for its sound or looking through the ventilation opening in the back of the oven. If it is not, there could be a broken or weak belt, gummed up or lack of lubrication, other mechanical problems, a bad motor, or bad connections.
  • Extremely high power line voltage may also result in overheating on a poorly designed or oven where the components are marginal.
  • Make sure the stirrer fan is turning normally. Should it gets stuck, some models may sense this and shut down/restart.
Hope it helped..
Thanks for using fixya....
Oct 20, 2010 | Ovens
PRIMA FAN ASSISTED COOKER - FAN WORKING BUT NO HEAT?
Hi.
You will need to check the oven element, it probably needs replacing.
Please rate my solution.
Thanks.
Apr 27, 2009 | Bosch HBL 5032 Electric Single Oven
Glad to hear your problem is solved.
Perhaps you would like to leave me a positive feedback.
It would be greatly appreciated.
Nov 25, 2008 | Ovens
Lower oven
hi
shut off power to the unit, let it sit for a while then turn the power back on. test the oven again, if the code comes back call 1-800-Jenn-Air and ask them what the code means.
Apr 02, 2008 | Jenn-Air JJW8430D Electric Double Oven
Fan on Whirlpool GBS277
In the middle of cooking roast beef I get a display of E1 F2.
Help please.
Jan 17, 2008 | Whirlpool GBS307PR Electric Single Oven
Bosch HBN 455 Oven Cooling-Fan Issue
After the oven is switched off, the after-run of the cooling fan is controlled by an electromechanical thermostat switch. The fan can switch back on, due to residual oven heat that accumulates within the oven's outer case and reactivates the cooling fan temperature switch. Considering yours is making buzzing sounds and activates on and off, the fan's thermal switch may have dirty contacts or just be defective and require replacement.
Sep 12, 2007 | Bosch HBN 455 Stainless Steel Electric...
Ovens Logo
63 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
