Question about KDS Valiant 6380iPTD-01 Notebook
Boiler not igniting
Vaillant turbomax plus 824E no ignition and display shows SF6 and SFh
  • 1 more comment
  • vickicove200 Jan 13, 2009
    My boiler will not Ignite, comes up with error code F75!!
    No Manual so can't reset it!!!
    Help me someone please!!
  • nichino7 Jan 21, 2009
    i have added water to up my water pressure but still the error code f 75 still comes up, and boiler wont ignite. Vaillant eco tec
  • Anonymous Feb 02, 2009
    I turned down the temperature settings slightly on the control panel and reset the boiler and it seemed to work!
    Filmmaker:
    Uploaded 5 video answers.
  • 43 Answers
Sorry, i think u have this in teh wrong category, it was filed under a laptop model called Valiant
Posted on Jul 23, 2009
Is it safe to run a Vaillant Turbomax Plus with the water gauge in red?
No, look for a small diameter pipe (1/2") supplying city water to the heater. On that pipe there should be a shut-off (make sure it is open), a back flow preventer (looks like a brass can with ribs) and a feed valve (looks like an upside down Ice Cream cone with a brass tab for a tai). Lift up on the brass tab to allow water to the boiler till the dial indicates Green. Sounds like this will need to be adjusted to keep the pressure in the boiler to manufacturers specifications.
Mar 06, 2011 | Heating & Cooling
Vaillant boiler no heating or hot water
refere to manual check for override switch loss of pressure no problem re-pressurise and check for leak top of rad valve good place to start
Oct 10, 2009 | Water Heaters
Vaillant boiler - heating OK, but no hot water.
Most likey problem is the diverter valve, not energising fully. This in turn will not move the little plastic lever arm that actuates the microswitch on the side, sending the signal to ignite.
You can buy a diaghram kit from most local plumb centres, you need to replace the diaghram and seals, don't forget the silicon grease to ensure the plunger doesnt stick. Kits less than a tenner.
You should have noticed before it stopped working completely the water had reduced in temperature before the weeks it failed.
To make sure it is a diverter valve fault, depress the microswitch if you can, when the hot water is flowing and hey presto the demand for hot water light should shine.
Apr 13, 2009 | Air Purifiers
Valliant turbomax manual
hi ian
most boiler manufacturers now days have downloadable manuals on there web sites.
just type in "vailant boilers" and flix through until you find the correct page. if they haven't a download you can request a copy on the "contact us" page .
i hope this has been some use
Jan 23, 2009 | Water Heaters
Central heating boiler problem
this is probably a faulty diverter valve. more info needed
Jan 02, 2009 | Heating & Cooling
Hi,i have a vaillant turbomax combi boiler,the radiator side is working well but when running hot tap the boiler kicks in for about 5 seconds ,hot water starts to flow then boiler cuts out,water runs cold...
Which turbomax, as there a two different models. The more modern one, with the brass CPL diverter valve, located at the front left of the boiler, was very prone sticking & jamming, this would restrict flow through the hot water circuit in the boiler, and cause cycling. Vaillant actually modified the diverter. You can identify, if it is the old type, as there is a very small hole in the middle of the diverter on the old ones, probable no more than 1mm-2mm wide. The modfied one, is much bigger approx 5mm wide. If old type, replace as this usally sorts the problem
Nov 23, 2008 | Heating & Cooling
KDS Valiant 6380iPTD-01 Notebook Logo
1,743 people viewed this question
Top KDS Computers & Internet Experts
Denise
ray
Level 1 Expert
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
