Question about Intel SUPERMICRO X5DP8-G2-0 E7501 CHIPSET DUAL XEON, 8xDDR ,DUAL IDE, LAN, U320 SCSI&ATI RAGE XL... Motherboard
No boot, casing problem?
I have a couple of computers and one of the 1U "cases" might be causing my motherboard to ground. It works in another case but not the one it's supposed to be in. Weird, huh? I checked for any loose screws or anything that would cause it to ground when I took the motherboard out of the bad case. I've tried reseating CPU's, memory, etc. but can't figure out what is causing this not to boot. Any other tips on what to look for?
  • Add sand Dec 27, 2006
    I tried another powersupply and it still wouldn't work. One thing I forgot to mention was that sometimes the computer will fire up for two seconds before cutting off. This happened on a couple of different power supply's that I tried. It's either hit or miss.
    Problem Solver:
  • 4 Answers
What is the powersupply in the 1U case. Is it sufficient for this motherboard? Try using the powersupply from another case that you know works with this board and see what happens. The larger standard ATX powersupply won't "fit" the 1U case but you should be able to run wires to allow you to test with.
Posted on Dec 27, 2006
SOURCE:
CS35-TL motherboard
I believe what you are seeing is the monitor displaying "no input signal". My question at this point is, how do you know the motherboard is running? Are you getting the single beep for successful post? or are you just hearing the fans kick on when power is applied and assuming its working? The computer kicking on but not posting can be caused by a grounding issue from the mother board to the case. You can buy small rubber washers at the hardware store to place between the case and the motherboard were the screws go in. This will eliminate most grounding issues. If what I have said is not the case, then please clarify your post some.
Jan 27, 2012 | DFI CS35-TL Motherboard
Pulled out video card, plugged it back in. Computer isnt booting
Good day..!Does your power supply working?.try to boot it up out of your casing,maybe there is static or grounded in your casing,or try to use other video card..and let that video card boot to other computer,so that we can determine what part is not working..If in case the video card is working,so probaly the problem was your motherboard sir..thanks
Aug 18, 2011 | MSI X58A-GD45 LGA 1366 Intel X58 SATA...
Booting problem and hang
Make sure that the motherboard is not being grounded, meaning that it should not touch any metal inside the case, this can cause an instant short which will make it not boot.
May 02, 2011 | Mercury PVCLE266 Motherboard
I have an Asus p5w dh deluxe MB and it will not boot. It starts, beeps once, then shuts down.
Try removing one DIMM (stick of ram), and booting. If that doesn't work, remove the other DIMM (assuming you have two), and try to boot again. If that fails, roll up your sleeves and get to troubleshooting.
Is this a new build? If so, take the motherboard out of the case, leave it on either the motherboard's box that it came in, or anti-static bags, and leave only the power connected to the motherboard. Try booting it to rule out a short coming from a misplaced stand-off inside the case. If it boots, check where your stand-offs are inside the case, making sure none are contacting the actual circuitry on the back of the motherboard.
If all of this fails, you may just have a bad motherboard, contact the manufacturer for RMA procedures.
Mar 03, 2011 | ASUS P5W DH Deluxe Digital Home Series -...
Installed a GA H55M USB3 motherboard in a Raidmax Tornado case. When I go to turn it on their is power for about for about a 1sec and the fans turn a couple of times and a couple of seconds later their is...
I once had something similar happen to me. Triple check to see that all connections are secure to the motherboard - a loose 20 pin ATX cable was the culprit in my case.
Hope that helps. Good luck!
Dec 09, 2010 | RaidMax Tornado ATX238WRP Black SECC Steel...
My Dell XPS 410 computer will not start, won't do anything.There is however an LED light on the Motherboard labled Stdby Led, this is lighted but the compter won't do anything? I am needing someones...
Your computer power button may not be working, or the CPU may be bad and it can also be the motherboard is faulty.You need a new case or fix the power button or try another CPU in the computer or replace the motherboard.
Aug 16, 2010 | Dell XPS 410 PC Desktop
P4C800-E Deluxe Motherboard: I plugged in my ipod to a USB port and my system j...
Guest
The cause for this is there was a short some where. It could have been the USB port, the cable or the IPOD its self.
You might try another USB port on the computer to see if you have the same problem.
If your computer will not boot then you might need to clear the flee power offf the system. You can do this by unpluging the AC power and holding in the power button for 30 to 45 seconds. Then plug back in the system and it should boot.
If the computer will not boot then you may have a ground issue. This does not happen much any more but I had this happen on a friends computer once where the case was worped and when i put my USB drive is the computer did the same as yours. The issue was the force of me putting the USB drive in shifted the board and caused it to ground out. So you may need to take everything out of the case and reseat the motherboard.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
May 18, 2010 | ASUS P4C800-E Deluxe Motherboard
PC wont Boot/start
try another graphics card if you have a working spare
Feb 16, 2007 | Foxconn NF4UK8AA-8EKRS Motherboard
Problem with motherboard MSI 925XE
A couple things: Is the BIOS giving you an error beeps? Also, does the motherboard have Integrated graphics? Sometimes if the Integrated graphics are enabled, it can cause the graphics card to not display at all. You also might want to check that the CPU doesn't have too little or *more likely* too much thermal compound on it. If the thermal compound is on the bridges of the CPU, this can cause the machine to start, but not boot to the BIOS.
Oct 08, 2006 | MSI 925XE Neo Platinum-54g Motherboard
Help no power
This is a typically problem when you don't have the motherboard proerly seated. Some part of the board must be touching the metal contacts when you screw down the board to the case which causes a short. Try to reseat the motherboard and also make sure you're using washers in between where you screw down the motherboard to the case. That should fix your issue (Unless there's something wrong with the motherboard all-together).
Oct 05, 2006 | A-Top Alien Gaming ATX Case
Intel SUPERMICRO X5DP8-G2-0 E7501 CHIPSET DUAL XEON, 8xDDR ,DUAL IDE, LAN, U320 SCSI&ATI RAGE XL... Motherboard Logo
78 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Joe Negus
Joe Negus
Thomas F. Schneider
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
