Question about Averatec 3200 Notebook
Flash Drver Can u please tell me where i can downloa a flash driver for the AVERATEC 3200 Thanks
  • Francisco Cortes
    Francisco Cortes May 11, 2010
    I'm confused or the question is not properly fomulated.
    if you need a driver you need to post what device you need the driver for and the operating system you have.
    if you have a flash drive (not driver) and the reason why is not detected by your system is because your missing a driver for it my suggestion is the following:
    if your flash drive is a relatively new and the operating system is 2000, xp or vista.. you may not need a driver ,hoping that your flash driver works fine, as the system will have everything it needs to work with your flash drive and if the flash drive is not working properly, you may have a hardware problem instead of a driver problem.
    if you have a flash drive relatively new (not damaged) that you're trying to connect to a windows 98 system with usb support you need to post the details of your flash drive in order for us to help you finding the driver that you need it to make the device work.
    post back with more info.
Lost Installing CD cant install to windows XP my computer is averatec 3200 series
here they are , I could not find free cd:
Averatec 3200 XP Windows Driver Recovery CD Restore DiskThis is an automated 3200 XP drivers recovery cd. The 3200 drivers are supplied in a special windows friendly format. This means that your Averatec 3200 XP Laptop will automatically find and install all the drivers for your system, with hardly any user interaction. If you have installed a new windows operating system and half of your Laptop just wont work (with errors like no sound no internet or bad graphics) then this is exactly what this CD has been designed to fix repair. You can also use this CD Disk If you just need to return you.....lots more averatec 3200-series drivers information here.
http://www.user-guides.co.uk/Averatec/AveratecDrivers/Averatec.asp?keywords=Averatec+3200-Series+Drivers&recor=1
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 18, 2010 | HP OfficeJet J4580 All-In-One Laser...
1 usb port cant detect a flash drive but can detect other usb devices
I'd say its the flash drive thats faulty .Try it in another computer to see if its recognized.If not the flash drive itself is bad.That port recognizing other devices says it functioning as intended.
Oct 24, 2010 | Averatec 3200 Notebook
Drivers
Hi My Dear,
Heres a big help for you I provide you link : http://www.notebookera.com/notebook-drivers/s_1233_1.shtml just download your drivers there.... happy installing
ERNZ
Feb 03, 2010 | Averatec 3200 Notebook
My Averatec laptop's screen is going out and if
Seems to me the inverter is gone if you replace the inverter it will work like a charm
Dec 31, 2009 | Averatec 3200 Notebook
How can install the drivers for the wireless
You will need to download the drivers off the averatec 3200 website and then install them. I checked and its a .exe file which means it should be very simple. If you have no internet on the laptop you will need to download them to a flash drive or burn to cd via another computer.
Sep 23, 2009 | Averatec 3200 Notebook
Averatec 3700, no sound
Hi
You are most likely missing the sound drivers on your laptop. You can obtain them from here.
http://www.trigem.com/us/support/drivers.asp
Let me know if you need further assistance.
Thanks,
Ekse
Aug 13, 2009 | Averatec 3200 Notebook
My averatec series 3200 notebook cant detect my usb device
The flash disk could be faulty, especially when it draws too much power, and this will cause the USB ports to shut down and the other USB devices won't work until the faulty device is removed.
Mar 11, 2009 | Averatec 3200 Notebook
Looking for averatec 3200 video drivers!!!
Which model do you have? There were 9 models of this notebook made but you can find the drivers on this website.
http://cr.am/framed.php?url=http%3A%2F%2Fwww.averatec.com%2Fcustomercare%2Fdownloads.asp&ref=driverguide
Dec 30, 2008 | Averatec 3200 Notebook
Drivers/averatec 3200
i need drivers for averatec 3200
Oct 02, 2008 | Averatec 3200 Notebook
Averatec USB ports
Hi, A couple of things you can try: 1. In your Device Manager, un-install all USB instances then reboot. Win XP will auto detect and auto install back the USB drivers; 2. On reboot, again in your Device Manager, all instances of USB Root HUB, right click, click on Properties, Power Management tab, un-check "Allow the computer to turn off this device to save power." 3. Download, install and use to format flash drives the HP Drive Key Boot Utility (cp006049.exe) available at http://h18023.www1.hp.com/support/files/server/us/download/23839.html If for some reason none of the above will for you, you may need to install an external/powered multi-port USB 2.0 Hub. Hope this be of some idea/help. Post back how things turned up or should you need additional information. Good luck and kind regards.
Oct 05, 2007 | Averatec Notebook
Averatec 3200 Notebook Logo
Top Averatec Computers & Internet Experts
Rommel Balcita
General Systems...
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
