Question about Mustek PVR-H140 Digital Media Player
To change the hard drive
Is it possible to use a hard disk capacity of greater than 40 Gb ?
  • Anonymous Mar 07, 2009
    Okay I try but i think the boot is blocked.
    The screen stay on the PVR screen.
    I have no solution to reset the firmware. Do you know how to flash the firmware ?
    I try with the new hardisk and the last but no success.
    The warranty has expired a long time ago.
    Thanks;
  • 22 Answers
Yes, No Problem The PVR-H140 is fitted with a Standard Laptop IDE Drive, though be careful not to damage the connector as it is quite delicate, if you can afford it you may want to fit one of the new solid state drives, this will have the advantage of using a lot less power so considerably increasing the battery life..
Also be aware opening the unit may invalidate your warrenty if you have one.
Posted on Jan 14, 2009
I have hard disk model MPC3043AT with capacity of 4 GB. The card (located exactly opposite in direction to 40 pin interface connection, with one end connected to PCB and other end is going down in disk...
You can't repair it, but you can change it with an identical one. Find a similar hdd and look at PCB it's a serial, if it's identical you can swap them after you resolder ROM chip from the damaged PCB to the new one. But this method it's use for recovery data and could be expensive.
Mar 18, 2011 | Fujitsu Desktop MPC3043AT 4.32 GB ATA-33...
Why is my acer hard drive divided into two(2) seperate drives with 36 GB in each drive
One half of the disk contains the program application while resourcefulness is attained from the remaining spaces. Usually the computers disk spaces allows only least application programing from the manufacturer, where a greater faction of the sapces are memory spaces with capacitis to display prorgams with several codes.The computer adjust according to what is requested either of memory, storage spaces.
Feb 14, 2011 | Acer (91.AB033.041) 73 GB Hard Drive
Too small capacity
Depends on what you are using the hard drive for. For example if this hard drive is going to be used for multimedia then I would recommend a hard drive around 120Gb to 1TB, but if it's for a small office with MS Windows XP installed it should be just enough to host the operating system and a limited amount of programs, hope this help, best of luck
Feb 02, 2011 | Seagate Barracuda 7200.7 40 GB Hard Drive
How do i change it back to 20gb
> how do I change it back to 20GB.
What is it currently showing as? Zero?
Any 20GB disk-drive is probably _many_ years out-of-warranty.
Take a sledge-hammer to it, so that NOBODY can possibly read your data,
and then responsibly recycle the disk-drive.
Spend $50 to buy a new disk-drive with TWENTY times the capacity of your "antique" drive.
Nov 03, 2010 | Seagate U6 (ST320410A) 20 GB Hard Drive
Getting slow
Disks seem to go slower as they fill. There is a general rule to never let a drive get down to 10% of capacity. Defrag regularly. Some freebies are better than the windows defrag program such as JKDefrag.
Aug 12, 2009 | SmartDisk FireLite 40 GB Hard Drive
Bought 2130 from work . The IT person there removed both hard drive and the shuttle in which the hard drive is loaded, need specs on replacing these Model #'s a drawing if possible. I have a samsung model...
Ask the IT person for the shuttle/carrier for the hard drive, it does not affect the company's data. You can also ask the IT person for the details and hard disk capacity so you can purchase a replacement hard drive.
This model Compaq uses a 2 1/2" IDE hard drive probably 20 to 40 Gb capacity, It is near impossible to purchase one with this small capacity, you might get a 80 Gb capacity or higher.
Aug 08, 2009 | Compaq Evo N800c Notebook
My system is not stable
Can be virus...hardware..or o/s issue
  1. Try taking unwanted files or prrgrams
  2. empty the temp folder
  3. Scan using latest anti virus
  4. Defragment
  5. if still same. Try formatting and re-installing the o/s..
  6. if still the same check replacing HDD ...or M/B
May 22, 2009 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Regarding hard disk updation
you need to buy a new harddisk with much more capacity.but for the drivers, it can be downloaded
May 08, 2009 | Intel D845GVSR Motherboard
Maximum HDD capacity of an ACER Travelmate 212 TX
Yes you can install a 20 Gb hard drive but I doubt you can buy a new one with that small capacity. The smallest capacity hard drives are approx. 80 to 100 Gb or greater.
You most likely can buy a 2nd hand drive but you don't know its quality, it may have had a hard working life and you don't know how long it will last, but then, if is very cheap that may not be a problem.
Mar 31, 2009 | Acer Computers & Internet
I want to increase the storage capacity my Hard disk.
hi,
You can use SATA hard disk.
you said you already have 40gb. so, your pentium 4 mother board can work with full performance with upto 80 gb.
My suggestion for you is to get another 40 gb and install it ,so it makes 80 gb as total.
Other option is , There are external hard disks available for reasonable cost. you can go for it.
Your RAM is ok too.
Hope my info helps you.
Bye.
Sep 25, 2008 | Computers & Internet
Mustek PVR-H140 Digital Media Player Logo
169 people viewed this question
Top Mustek Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mustek Audio Player and Recorder Expert? Answer questions, earn points and help others
