Question about Copystar Office Equipment & Supplies
Copystar CS-1635 "Reset Originals on DP" Communication between computor and copier -- problem
n25an
  • 622 Answers
SOURCE: cs-2550 sofware
goto usa.copystar.com and search in downloads...
Posted on Dec 26, 2009
n25an
  • 622 Answers
SOURCE: Copystar CS-2550 Set up add'l scan folders - need to reset psswrd
try 6482... or call kyocera support or call a kyocera service tech
n25an
  • 622 Answers
SOURCE: Noisy Fan on Copier CS-3035
the fan is rubbing against something or its just noisy... replace it... or remove the obstruction...
shawn38
  • 200 Answers
SOURCE: What is happening when the Copystar CS-2550
The error code C-0410 indicates an communications error with the document feeder.
It normally indicates the cable between the document feeder and copier is ether has a loose connection or the cable has a short and needs to be replaced.
It can also be an issue with the document feeder driver circuit board or the copier engine circuit board.
I hope this is helpful,
Shawn
Posted on Feb 27, 2011
SOURCE: reset all originals in DP
reseat orignals on DP.
Posted on Sep 05, 2011
My photocopier is just saying reset all originals in DP how do i reset
Open and close the document feeder (where you put your pages that you want copied), take out any papers on there and place them back in the document feeder. press the start button. Good luck !
Oct 18, 2012 | Copystar CS-2550 All-In-One Printer
I am a tech and have to replace the drum on a copystar CS 1635. The service manual has been lost so I need the instructions.
open front cover, remove toner cartridge and waste toner tank. unscrew the screw below the developing unit and release the dev unit by pulling the lever. open left cover. from the front remove the screw on your left holding the drum unit. gently pull out the drum unit and replace the new unit using. the reverse procedure to be used.
Apr 20, 2011 | Kyocera Copystar CS-1635 Copier
The error message displayed is "OP".
OP means open. check if all covers front and left covers are closed.
Dec 30, 2010 | Kyocera Copystar CS-1635 Copier
Maintenance
when the machine shows maintenance it means the maintenance counter is due i.e that the life for the drum unit, heat roller and pressure roller is due. According the manufacturer they have to be replaced and the counter reset using code 251.
Nov 09, 2010 | Kyocera Copystar CS-1635 Copier
Unable download software for printer CS 1635 Vista basic
Hi!
Here is the file or click the url... and save the file automatically from your computer..
1. CS 1650 printer driver.
2. http://usa.copystar.com/americas/jsp/upload/resource/17858/0/1650VUP1.exe
Much appreciated if you rate this solution..thanks..
May 28, 2010 | Copystar CS-1650 All-In-One Laser Printer
Setting up a copier to use
hi if enter simulation 1087 1087 and select 000 inmidiatly appear d-l and press enter
after to out do you enter with arrow up and down the number 1 in the display and press enter
Jun 19, 2009 | Kyocera Copystar CS-1635 Copier
How do I get the page count for a CS-1635?
hi,
if you press and hold down the clear button for a few seconds the count will appear
please take the time to rate this fix
Apr 23, 2009 | Kyocera Copystar CS-1635 Copier
35 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
