Question about IBM ThinkPad T30 2366 Notebook
IBM Lenovo Thinkpad R61 gets 1 long & 2 short beeps on startup
7742-cto model Thinkpad R61 running Vista. When I press the power on button I get 1 long & 2 short beeps, then nothing. I have tried:
- Combinations with and without battery & AC adaptor
- Removed CD drive and HDD
- Unplugged & rearranged the 2 1G Dimms
- Held down F1 & ThinkVantage buttons
- Opened it up and looked for loose connectors etc
- Searched the web
- Shook it and bumped it
No Change in symptoms.
1. Anything else I can try?
2. Any diagnostics I can run?
3. Any good place I can send it for service?
Thanks, Ross
  • Ros Maed Nov 26, 2008
    Thanks, still no change. I am shopping for a motherboard fixer.
  • 177 Answers
Try this:
Open two RAMs, clean them properly and connect only one RAM then try. If nothing changes, then remove the RAM and insert the other one. And try again.
If this fails too, then there is a good chance that you have motherboard related problem
Posted on Nov 26, 2008
How to reset lenovo thinkpad r61?
Please follow the steps below to reset the lenovo to factory settings
Note: All your data will be lost. So keep that in mind.
So take the backup of your data first in a separate HDD or flash drive.
1. Switch off the Computer
2. Press the power button and then immediately start tapping f11 key on the top of your keyboard.
3. You will hear a beep sound and then stop pressing it.
4. You will get the screen says windows is loading files. Wait untill it finishes.
5. Select the default language which is US and Click on next .
6. Enter your login credentials (username and password) if you use to login to the windows.
7. Then you will get the system Recovery Options screen where you need to select the last option "Lenovo Product Recovery"
8. Again preferred language will be English US and hit Next.
9. Accept the terms and conditions and hit next and then hit Yes on the warning.
10. Then it will start resetting the Lenovo Think pad to the factory default with no previous data. Same as when you purchased it.
If you have any query you can ask before restoring the Computer.
Hope this helps you. Reply if that fixes your issue.
May 07, 2014 | Lenovo ThinkPad R61 Notebook
I am hearing 4 beeps 4 times during power on, but system does not start- IBM thinkpad lenovo R 61
Usually this means that the memory is defective or has been removed or popped loose in its sockets. Try to reseat the memory DIMMs or replace them.
Sep 24, 2013 | Lenovo ThinkPad R61 Notebook
Remove dent
IBM/Lenovo ThinkPad R61 Notebook PC >
Bottom Case Cover, (Base Enclosure),
Keyboard/Palm Rest Cover Bezel,
Palm Rest Cover,
Not advertising for seller nor website. Just examples.
Here is the free HMM from Lenovo Support.
It is the Hardware Maintenance Manual. The Service Manual.
Shows and details how to replace the above parts,
Also USE an ESD wrist strap, and have it's alligator clip attached to a good ground source.
Here is an average example,
For additional questions please post in a Comment.
Or click on Reply at end of solution, and post.
May 19, 2013 | IBM Lenovo ThinkPad R61 Notebook
How many ram bank is available in IBM lenovo thinkpad R61i model laptop?
Click here for the ram specs on the R61. Click here for the ones on the R61i. This should have all of the information you need. Please rate =]
Mar 04, 2011 | Dynamic 2GB RAM Memory Upgrade for the IBM...
I hv lenovo thinkpad r61.. i hv drivers bt,itss nt
The same model ThinkPadcan have different types of network, video and audio drivers and unless youknow exactly which one is installed in your ThinkPad, you need to download allthe drivers and install each driver until you find the right driver. When you download thedrivers, write down the device driver and it's file name so you have a recordof which driver you are installing and which directory the unzipped files arelocated on your hard drive. Go to the IBM/Lenovo WEBsite - support/download page and download the latest Windows XP or Vista devicedrivers for your model computer, Use this link: - You can download thevarious drivers and then you click on and run the various driver files, theywill then unzip and expand into a sub folder on C:\drivers Then install thevarious drivers from this folder (run the set-up file).
Dec 02, 2010 | Lenovo ThinkPad T61 Notebook
Lenovo thinkpad R61 audio driver not working
There are audio drives for this laptop, they will work for Windows, XP, Vista, & Windows 2000. They are on this site:
Just install and the laptop should recognize them. It if doesn't then that means the onboard video is bad.
Apr 21, 2010 | Lenovo ThinkPad R61 Notebook
I am trying to search & install the audio driver of lenovo IBM thinkpad r61i for xp2
do not look at the free scan for drivers ..your driver is a little down the page just download and run ...ya might also keep it so you never have to do this again ...( keep it in a different partition than C if you ever format C partition will still have the driver )
Good luck ...and rate me please :P !
have a great day !
Apr 08, 2009 | Lenovo ThinkPad R61 Notebook
Lenovo r61
Please look here:
Drivers and software - ThinkPad R61
Communications: Bluetooth
Bluetooth Enhanced Data Rate software
Windows Vista
03 Apr 2008
Windows XP, 2000 25 Aug 2008
Microsoft Bluetooth support
Windows XP 21 Sep 2005
Nov 04, 2008 | Lenovo ThinkPad R61 Notebook
Lenovo Thinkpad R61 7732 Hissing Sound
try running a test on youe battery frim control panel
try and boot the system in safemode and check if it works there if Yes then its an OS issue if no the boot in bios and reset the setting to default and try agian
Jun 16, 2008 | Computers & Internet
IBM ThinkPad T30 2366 Notebook Logo
1,246 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
