Question about Ovens
Fan oven the fan in my fan oven has stopped working. what is the problem and how can i fix it?
  • calum-rm Jan 15, 2009
    The Fan on the lower oven of my AEG Competence (D5701-4-M) has stopped working. The oven still works (gets hot) but on each of the switch settings that requires the fan - it simply does not start spinning. I would like to know the most likely cause and how easily can it be fixed.
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 8 Answers
What type of stove is it? More info please.
Posted on Nov 23, 2008
Can you diagnose the fault & advise me how to fix my hotpoint electric cooker please?
This video shows how to test and replace the faulty heater element on the fan oven on a Hotpoint double oven.
Sep 26, 2015 | Hotpoint Ovens
Beko built in oven fan makes a noise like it's catching on something, now the fan has stopped
you will need to change the motor
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2014 | DeLonghi DEBIGE 2440 Electric Double Oven
I have a fan forced chef classic wall oven and the fan has stopped working....why ould this have happened/
There has several reasons the fan could have stopped working:
-It is possible the fan wiring/connections have become loose or unplugged
-It is possible that the fan motor has worn out or become jammed over time due to debris
-If you recently cleaned your oven, the fan could have stopped working if it came into contact with any caustic oven cleaner.
Hope this helps.
Feb 28, 2011 | Ovens
The fan oven has stop working can i fix the problem
If the fan is working o/k, then you need to replace the oven element located at the rear of the oven compartment behind a removeable cover.
Oct 03, 2010 | Stoves 720EF Electric Double Oven
Fan oven stopped heating
Is the fan working in the oven if not then check if the clock needs resetting.If the fan is working then it is more likely that the ring element around the fan has failed.Check also if the thermostat light comes on,this is an indication it may be ok.
Hope this helps.
May 25, 2010 | Ovens
The fan assisted oven has stopped heating up how can i fix this
If the fan is working o/k, then you needs to replace the oven element located at rear of oven compartment.
Please rate my solution.
Thanks.
Oct 29, 2009 | Belling XOU270 / XOU271 Electric Single...
Fan making loud noise
Hi
does the noise start as soon as you turn the fan oven on?
does the noise stop as you turn off?
just depending what make and model you have there is two fans
in it 1 is the fan motor inside oven at back and other
is the cooling fan which is at top of oven .you just need
to find out which one it is and just replace . then should be back to normal
regards dan
Mar 19, 2009 | Belling XOU174 Electric Single Oven
Neff 1861 oven fan stopped working
Fitting new bulb would not cause fan to stop working.
If it is getting hot, then there is something wrong with fan, try spinning fan by hand, it should be free, and continue to spin under it's own momentum.
Hope this helps.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Neff B1861 Single circotherm super...
Bosch convection double oven,ovens won't heat,only broilers work
If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
Plz rate my\solution.
Thanks.
Dec 17, 2008 | Bosch Ovens
Ovens Logo
95 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
