Question about Roper RAS6233KQ Top Load Washer
Not getting clothes clean
We have changes detergents adjusted water levels and temperatures but our clothes come out with a film on them
Try using less detergent and putting white vinegar in the rinse water. You can pour 1/4 C. or a little more into the automatic fabric softener dispenser for the final rinse, or put it in by hand.
Posted on Nov 27, 2008
Whirlpool adp252 not rinsing clean
Hello
Clean the internal parts of the dishwasher. Use a clean wet cloth and wipe down the inside including the racks and the sprayer arms. Remove the upper arm by unscrewing the center bolt. Clean both sides before replacing.
Check the water pressure. The dishwasher requires inlet water pressure between 20 to 120 psi. If the water pressure in the line is too low, proper rinsing will not occur.
Check the water temperature. The dishwasher performs at optimal levels with 120 degree water. Check the hot water heater for needed adjustment.
Use the right detergent. The dishwasher requires detergent designed specifically for dishwashers. Other detergents will leave spots, residue or food on dishes.
Set the machine to the proper cycle. The dishwasher offers a variety of cleaning cycles. Select the appropriate cycle for the type of cleaning required.
Load the dishwasher properly. An overloaded machine will result in dishes not being cleaned thoroughly.
Sep 12, 2011 | Dishwashers
My dishes are not getting clean, the cycle seems to leave them covered in bits of detergent and a white hard film. We've had it for three years, and this just started about a month ago
If your dishes or glassware appear with a white film or a white powdery residue or spotted following a complete wash cycle, adjusting the amount or type of detergent you?re using and adjusting your hot water heater?s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you?ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
If the film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature.
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn?t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don?t use extra-hot settings such as ?Power Scrub,? and use the ?Energy Saver? dry cycle.
2) Adjust the detergent amount.
3) Don?t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading?dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home?s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20?120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn?t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals?the more grains per gallon you have, the more detergent you?ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn?t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn?t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn?t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren?t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
Please rate the solution if you feel I've helped you
Sep 02, 2010 | Kenmore 15872 Dishwasher
We get a white film on dishes and silverware after running then dishwasher. It 's getting worse gradually over time. What is the cause and how do we correct it.
Aug 24, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
I have a white film over the dishes and they are not getting clean
Aug 22, 2010 | Bosch 24 in. SGS43C12 Classixx...
Dishs are duty and glasses have white film & dirty
Jun 10, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Film on glasses
If your dishes or glassware appear filmy or spotted following a complete wash cycle, adjusting the amount or type of detergent you’re using and adjusting your hot water heater’s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you’ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn’t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don’t use extra-hot settings such as “Power Scrub,” and use the “Energy Saver” dry cycle.
3) Don’t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading—dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home’s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20–120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn’t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals—the more grains per gallon you have, the more detergent you’ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn’t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn’t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn’t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren’t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
May 07, 2010 | Whirlpool 24 in. DU1148XTP Built-in...
White film on all dishes and silverware
Apr 27, 2010 | Kenmore 24 in. 16019 Built-in Dishwasher
Dishwasher not cleaning the dishes anymore, leaves a film on
Apr 10, 2010 | Kenmore 24 in. 16299 Built-in Dishwasher
Dishes, glasses & silverware have white film, look unclean!
May 11, 2009 | GE 24 in. Profile PDW9280JSS Built-in...
We have an Admiral Dishwasher that won't clean all the dishes properly. It leaves white film residue on some of the dishes and silverware. Have tried different products to clear this up with nothing...
Apr 04, 2009 | Admiral 24 in. DDB1501AWW Free-Standing...
Roper RAS6233KQ Top Load Washer Logo
59 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
