Question about Sony DAV-C450 System
5 DVD disc changer doesn't open
When I turn on the DAV-C450 and try to open any of the discs (1-5) there is a little noise,but the changer never opens. I'm also unable to find a DVD that was in disc 2 slot. I've taken the case apart and looked for the disc, but don't see a thing. I've turned it off and on with no difference.
Are you using discs with labels that you out on your self? I had a similar problem before and my label peeled off in the player causing it to get stuck., you might just have to take it apart, and get the label out.
Posted on Nov 06, 2007
My older Sony Home Theatre/DVD player sometimes will not output any sound.
Sony eSupport - DAV-HDX500 - Support
https://esupport.sony.com/.../model-home.pl?...DAVH...
Sony CorporationHCD-HDX500 - DVD/Receiver Component for Home Theater System ... How to troubleshoot if there is no sound or intermittent sound from the speakers.
[PDF]DVD Home Theatre System - Sony
https://docs.sony.com/release/DAVHDX500.pdf
Sony CorporationDVD Home Theatre. System. Operating Instructions. DAV-HDX500/HDX501W ... not expressly approved in this manual could void your authority to operate this ...
Sony DAV-HDX500 No Sound : hometheater - Reddit
https://www.reddit.com/r/.../3nenei/sony_davhdx500_no_sound/
RedditOct 4, 2015 - My Sony DAV-HDX500 only plays sound when using the built in dvd player. ... Sony system you have does have a digital optical input so that's ...
Jan 10, 2016 | Sony DAV-HDX500 System
Disc tray wont open
Get a paper clip and look at the face of the drive.. There is a small hole, insert the unfolded paper clip in the hole and the drive will release. Good luck
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Apr 18, 2014 | Sony DAV-C450 System
Sony DAV-C450 disc jammed. How can I remove them
first of all just take screw driver and open it then see what is the main problem to fix it
May 15, 2010 | Sony DAV-C450 System
your two options would be to remove the cover and disk tray and than remove the disk while nothing is in your way your other option would be to pry it open using a flathead screwdriver which could damage the tray motor and gears neither is suggested if the item is still under warranty or you lack general assembly skills
Mar 30, 2010 | Sony DAV-C450 System
It can't play dvd from other zone, how can I set up my equipment to play any dvd?
Now this is for the Sony DAV-450. If that is not your unit may I get the right make and model #.
1) Go into the services menu by
A) - Turn your C450 on with no disc inside.
B) - (ON THE EQUIPMENT NOT ON REMOTE) Press and hold both the Display and Stop keys while turning the volume control to the right. When your TV screen fickle, release the buttons. You should be seeing the Service Menu now.
This should be fairly easy. I got to this step without any troubles.
2) Instead of buying their remote control I used my PALM with OmniRemote (http://www.pacificneotek.com/software/OmniRemote.zip) and Sony_DVD_hack.pdb (http://dev0_2000.tripod.com/).
3) I send numbers 1 to 5 with the PALM as suggested and tried it a number of ways such as sending 1,1 2,2 3,3 etc.
I did NOT see any "data reset" or anything else displayed on the screen as reported in the forums elsewhere. That's why I kept on trying for about an hour with various codes and just as I was about to give up, lo and behold, I tried playing a region 1 DVD and it WORKED. The morale of the story is that keep a bunch of DVDs (with various codes) handy and try it out.
While pressing the buttons 1, 2, 3, 4, 5 I did not notice anything unusual except button 2 would put the display into some kind of toggle mode but probably it is irrelevent and safe to ignore.
Enjoy! If this works please rate 4 thumbs for the free answer.
Mar 08, 2010 | Sony DAV-C450 System
Program play prohibited
This can happen if you have the "repeat" function turned on on your DVD player.
Nov 10, 2008 | Sony DAV-C450 System
LG home 5 disc dvd changer
defective call customer support or bring it back to were you bought it
Jul 21, 2008 | LG 1000W XM-Ready 5.1-Ch. Home Theater...
DVD player does not play
Display of my DAV C450 does not work
Jan 13, 2008 | Sony DAV-C450 System
DVDs won't play
Hi Pookie, This is an easy fix. All you need to get is a CD/DVD-Player Laser-Lens Cleaner for about $5.00. You can get these at Best Buy, Circuit City, Radio Shack, or any similar place. Use this, and let me know how it works for you. Best regards, nightdiver
May 27, 2006 | Sony DAV-C450 System
Sony DAV-C450 System Logo
472 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
