Question about Compaq Presario M2000 Notebook
I cant put laptop into standby mode theres no orange light anymore I click start then click turn off computer then theres 3 options standby turn off restart theres is no light anymore behind the optio
Standby mode cant put laptop into standby mode,i click start the three option boxes come up but no light behind standby mode.
Acer one with windows 7 ultimate fall into sleep mode
A laptop computer is typically set to conserve battery power. One of the common settings called standby, sleep mode or hibernation turns off power to the screen and the laptop itself after a preset time limit passes without any mouse or keyboard activity. It can be inconvenient for the computer to shut down while you're working on an open page or during a download. Change the setting if you don't want your laptop to going into automatic shutdowns
Turn the laptop computer on with the power button if it's not set to turn on upon opening. Allow the system to boot up. Open the panel for adjusting the sleep settings. This varies among the popular versions of Windows operating systems. To change the sleep mode setting on a laptop running Windows XP, click the "Start" button, and click the "Control Panel" selection. Choose the "Performance and Maintenance" selection, and click on "Power Options." Click the "Power Schemes" tab, and click the drop downs next to "Turn Off Monitor," "Turn Off Hard Disk," "System Standby" and "System Hibernates." Select "Never" for each drop down in both the "Plugged in" and "Running on Battery Power" columns. Click the "Hibernate" tab and click to remove the check mark in the box next to "Enable Hibernation." To change the sleep settings on a Windows Vista laptop, click "Start," "Control Panel," "Systems and Maintenance" and "Power Options." Then click "Change Plan Settings" under the currently established plan. Click on the "Advanced Settings" tab and select the "Never" option on the "Sleep," "Sleep After," "Hibernate After," "Display" and "Turn off Display After" drop downs. Click the "OK" and "Save Changes" buttons to confirm the settings. To change the sleep settings on a laptop running Windows 7, click the "Start" button, choose "All Control Panel Items," select "Power Options" and click "Edit Plan Settings." Click the drop downs for "Turn off the Display" and "Put the Computer to Sleep." Choose "Never" for both and click the "Save Changes" button.
Feb 06, 2013 | Acer Aspire One PC Notebook
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
Won't go into sleep mode
Which operating system ?
A menu opens.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
I cant get my monitor out of power saving mode? What do I do?
There are various steps to fix this issue.
Step 1.
For Vista and Win 7 PC
1.Go to Control Panel - Power Options
2.On the Left side there is a column - " Click Change when the computer sleeps
3.Click the drop-down box which says Put the computer to sleep and select 'Never' for both battery and 'plugged in'
4.Click 'Save changes'
For Windows XP
1. Go to Start - Control Panel - Power Options
2. Under the Power Schemes Tab, set the Standby and/or Hibernate Options to 'Never'.
3. Click Apply/Ok and you're done.
Step 2
1. Right click on the desktop and click Properties.
2. Click Screen Saver + below you will find Power Click on that
3. You will see Settings for Home/Office Desk power scheme and in Turn off Monitor slect Never and click Apply.
Thank you for contacting FixYa
*Please rate this solution with Thumbs Up
Nov 26, 2010 | Gateway FPD1530 15" TFT LCD Flat Panel...
How do i turn off sleep mode
For windows Vista
For Windows XP
3. Click Apply/Ok and you’re done.
Mar 10, 2010 | Computers & Internet
Enable standby and hibernation in my laptop again
You can manually re-enable the Hibernate option via command prompt using these instructions:
  1. Click the Start button.
  2. Select All Programs > Accessories
  3. Right-click on Command Prompt and select Run as administrator .
  4. At the command prompt enter
    "powercfg -h ON"
  5. Close the command prompt window.
Nov 27, 2008 | Toshiba Satellite L25-S119 Notebook
Stanby mode
Goto control panel, performance and Maintenance, Power options, Power options property, hibernate tab, enable,apply, advanced tab, select how you want to stand-by or hibernate unit, apply.
Mar 17, 2008 | Toshiba Satellite A205-S4617 Notebook
Compaq Presario M2000 Notebook Logo
344 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
