Question about HP 9200C Digital Sender
Second and subsequent pages in scan are blue
HP Digital Sender 9250c
Model CB472A
Serial Number SGBJ7780DL
Firmware date code: 2007012648.011.1
When emailing multiple pages, the sent document's (.pfd, .jpg) first page is normal, but second and subsequent pages have an aqua background with white typing, instead of the standard black type on white background. Can't seem to get all pages normal.
Research on Internet indicates that this is not a rare occurrence, but I've not found an explanation nor solution.
  • 1 more comment
  • Anonymous Jan 07, 2009
    my HP 9250 will not power up
  • how we be Jan 15, 2009
    I have the exact same problem. No idea what causes it.
  • denurdaneta Feb 28, 2009
    I have the same problem. Does anyone have a fix for this? Help..
We called the HP tech and they replaced the board, seems to be te only solution
Posted on Nov 10, 2009
Hp digital sender 9250c show continue turn off then on .what is the problem and how can i solution this problem
Depending on what operating system your running. You need to make sure your product is plugged in through a usb connection. Now if your computer doesn't find the product that's ok you just need it to be plugged in. then you need to download the proper drivers for it. For instance if your running windows 7 64 bit, you need to download the drivers making sure you have 7 64bit drivers. In this case you want to install the firmware update make sure you see a yellow smiley face after the firmware is installed to your Digital Sender
1422807-h20565.pngDrivers Software Firmware for HP 9250c Digital Senderh20565.www2.hp.com
Mar 18, 2013 | HP 9250c Digital Sender (CB472AABA)
My digital sender disp show continue turn off then on what can ido now
My hp digital sender 9259c need an RFU upgrade
Jul 02, 2012 | HP 9250c Digital Sender (CB472AABA)
What is error code 22 hp digital sender 9250c
Depending on what operating system your running. You need to make sure your product is plugged in through a usb connection. Now if your computer doesn't find the product that's ok you just need iticon1.pngto be plugged in. then you need to download the proper drivers for it. For instance if your running windows 7 64 bit, you need to download the drivers making sure you have 7 64bit drivers. In this case you want to install the firmware update make sure you see a yellow smiley face after the firmware is installed to your Digital Sender
[img src="http://i.fixya.net/uploads/images/1422807-h20565.png">Drivers Software Firmware for HP 9250c Digital Senderh20565.www2.hp.com
Aug 02, 2011 | HP 9250c Digital Sender (CB472AABA)
HP 9250c digital sender is giving error login failed code 22 using common access card
Jun 29, 2011 | HP 9250c Digital Sender (CB472AABA)
I'm forget admin password on hp 9250c. Please, how recovery admin password.
Cold reset for HP9250C
A cold reset resets the values of permanent storage variables to factory default. Often this is necessary
for clearing the HP MFP Digital Sending Server IP address.
The following items are cleared during a cold reset:
Embedded Jetdirect IP address
SMTP IP address
LDAP IP address
Embedded Web server password
All control-panel configurable items
The following items are NOT cleared during a cold reset:
Local address book e-mail addresses
Real-time clock (date and time)
Page counts and maintenance counts
Product serial number and formatter number
Service ID
Event log
To perform a cold reset
1. Turn off the digital sender.
2. Turn on the digital sender.
3. Immediately after turning on the device, press and hold down the #6 key (do not wait for the memory-count). When the three status LEDs are illuminated, release the #6 key.
4. Press the #3 key four times until the display shows COLD RESET.
5. Press the #6 key once to initiate the cold reset. The product will continue its boot-up sequence.
Oct 04, 2010 | HP 9250c Printer
How to update the frame ware of our digital sender 9250c
the firmware probably does not even need to be updated unless you are having a problem
Dec 02, 2009 | HP Digital Sender 9250c scanner Printer
HP Digital Sender 9250C Color Scan Problem
We purchased 2 HP scanners 9250C and have the same issue. Send it back to HP, they make some correction for firmware, after 1 day, everything is ok.
Dec 06, 2007 | HP Digital Sender 9250c scanner Printer
HP 9200C Digital Sender Logo
491 people viewed this question
Ben Johnson
