Question about HP Photosmart R707 Digital Camera
Memory Card When memory card is inserted it says format unknown or just freezes. We have tried another memory card with the same result. The fault is intermittent. It works happily just using the cameras own memory without the card, although this doesn't give me enough storage.
  • 5 more comments
  • Anonymous Feb 11, 2008
    the memory card is unpredictable. many times when camera is booted up, statemebt appears card is unreadable.
  • Anonymous Mar 07, 2008
    When i try to upload my photos it stops at certain ones. so i tried to delete the pictures and they wont delete. it freezes my camera or it will delete and then an orange screen pops up and i cannot view my photos anymore and i have to turn the camera off and then the pictures that i just tried to delete are there again. i cannot get it to work.
  • Anonymous Mar 28, 2008
    Often on booting the sd card is unreadable. Does not depend on card, does not go away with formatting the card.
  • tera2tera May 07, 2008
    it doesn't recognize the card. it is unable to format the card. the messages are: "card is unreadable" then "card has wrong format" and "pres ok to format card"..."processing" ...."unable to format"
  • jozsikam Jul 02, 2008
    I've the similar problem as tera2tera: yesterday, I made a lot of pictures without any problem then charged the battery during the night and this morning the memory card's format in unknown and it isn't possible to format it.
  • Anonymous Aug 08, 2008
    Cannot read memory card. Card needs to be formatted,will not formatted.
  • thenols Nov 24, 2008
    It happens about once a month to me. I power up the camera, red screen saying, "CARD HAS WRONG FORMAT" -- I tried the firmware reset thing, and the same thing happened still. I've tried 2 separate memory cards and they both do the same thing every now and then. VERY FRUSTRATING!
I had the same problem, and I found that a firmware reset solved the problem.
To do a firmware reset, open the battery bay, remove the battery and the SD card, and then insert a paper clip into the tiny hole in front of the little "+ -" sticker on the battery door. Hold it for 6 seconds, and remove. After this, I reinserted the battery, and the turned it on and able to read the memory card
Posted on Aug 13, 2008
I have the SAME problem.....deciding whether to just get new camera. Mine is only 3 yrs old though. When I called HP tech support they wanted $30.00 just to diagnose & "possibly" repair.
Posted on Jul 24, 2008
    Problem Solver:
  • 8 Answers
Did you format the card in the camera?
Posted on Feb 18, 2007
Hi, my memoricar appear like corrupted and when a try to format it the phone (Nokia E63) freeze. waht can i do.
IF YOU ARE NOT FORMATED YOUR MEMORY CARD TO USE 2003SERVER WINDOW GO TO MY COMPUTER MANAGE DISK MANAGEMENT , RIGHT CLICK ON CARD AND FORMAT IT FORCEFULLY
NEXT STEP :- TO USE HP FORMAT UTILITY TO FORMAT IT
NOTE :- BEST RESULT YOU ARE USE 2003SERVER
May 17, 2011 | SanDisk 2GB microSD Memory Card
What does CHA mean
Nikon says this about CHA:
When a Memory card is inserted into a D-SLR camera, the camera checks the card for compatibility and usability. There are three possible results of the test:
1) Camera detects valid Memory card, displays number of remaining images in top LCD
2) Camera displays "FOR" in top control panel LCD. The camera has detected a valid disk partition map, but was unable to read the first sector of the Memory Card. Formatting the memory Card using the cameras format option, should resolve this condition and allow the Memory card to be used.
3) Camera displays "CHA" in top LCD. The camera has detected an invalid partition type or is not working properly. Reformatting the memory card may allow it to be used. If an approved memory card causes the camera to display the "CHA" indicator contact the memory cards manufacturer for assistance.
(Nikon's list of "approved" memory cards can be found here.)
Please note that the default disk format used in Windows XP is FAT32 and if a card is formatted with this setting on an XP system, a D1 series camera will report "CHA". Reformat the card as "FAT" to use in the D1 series camera.
When the CHA error is shown, typically the camera will freeze and require that the battery be removed from the camera before it can take another picture. After that picture has been taken, the camera freezes up again for many owners.
Some owners have success removing and either re-seating or inserting a new memory card in the camera.
Some owners have success clearing the error by removing the lens and then reinstalling.
The key to these "fixes" is that they don't all work for everyone. You might need to return the camera to Nikon for repair. You can arrange for Nikon service here.
I hope this helps and good luck. Please rate this reply
. Thank you.
Apr 06, 2011 | Nikon D90 Digital Camera with 18-105mm...
My 6300 restarts automatically when i insert any memory card why?
hi
there are some phone that will restart when memory card is inserted automatically for first time. but make sure that your phone will support the memory card that u use. if still problem arises kindly try your memory card in other phone if it works properly means the fault is in your mobile. kindly format the phone and try it. this will fix your problem..
thank you
Dec 19, 2010 | Nokia 6300 Cellular Phone
Shutter stays open. says turn off and on when
cameras : My Camera Freezes When I Turn It On Or Take A Picture
P, td, li {font-family: arial, u; font-size:9pt; margin-top:0px;margin-bottom:0px; word-spacing:1px;} If you camera freezes when you power it on or when you try to take a picture, you may have a defective memory card. To test your camera and the memory card, follow these steps:
  1. Power off your camera.
  2. Remove the battery from your camera. If you have a memory card inside the camera, remove that as well.
  3. Clean out any dust or debris inside the battery compartment, and then re-insert the battery into your camera.
  4. Power your camera on without the memory card installed.
  5. Take a picture.
    • If your camera takes a picture, re-install the memory card, and then go to Step 6.
    • If it does not take a picture, your camera requires service. To set up service, click the Create Online Service Request button below.
  1. Format the memory card in the camera, and then take another picture.
  2. Important: Formatting erases all pictures and other data from the card. If you have pictures on the memory card you want to keep, download those pictures to your computer before you format the memory card.
    • If your camera does not take a picture with the formatted memory card installed, replace the memory card.
    • If the issue still persists after you’ve installed a new memory card, your camera requires service. To set up service, click the Create Online Service Request button below
Jul 25, 2010 | Samsung L77 Digital Camera
When I insert my 4gb memory card my phone will freeze up completely. Is it the card or my phone?
The problem is from the phone, restore the factory settings of the phone and try to insert the memory card into the phone again.
If it does not read it, try a smaller sized memory card to see if it will work.
If it does not work, then the fault is from the phone.
You have to change the memory cards slot.
Take care
Jun 20, 2010 | Samsung SGH-A877 Impression Cell Phone
New memory card for phone cant format with out unknown code
Hello Tuna Heads
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Jul 09, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
    I have a coolpix s230, using the memory card to hold pics
    Try another memory card, memory card can go bad. If this does not solve the problem your camera has a fault in the SD memory card or the memory card board.
    Jul 02, 2009 | Nikon COOLPIX S230 Digital Camera
    Lg cookie freezes when memory card inserted
    hi format your memory card through the phone it will set it to your phones settings.
    Mar 30, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
    Memory card is in camera(kodak c613) Camera
    Make sure the card is fully pushed in; otherwise it could be the reader.
    You could try to insert the card into an external card reader connected to a PC.
    If it is recognized by windows, click "format".
    If that works put the card back into the camera.
    If it is now recognized, go to "menu" and format again with the camera.
    If the card is not recognized, your internal card reader seems to be faulty.
    Mar 03, 2009 | Kodak EasyShare C613 Digital Camera
    External memory
    hi had same problem,the phone will only work with 1 gb memory card, put 1 gb card in and phone see's it straight away and works just fine
    Nov 05, 2007 | LG KG800 Cellular Phone
    HP Photosmart R707 Digital Camera Logo
    185 people viewed this question
    Top HP Cameras Experts
    teddyboy
    Lawrence Oravetz
    Are you a HP Camera Expert? Answer questions, earn points and help others
