Question about Kitchen Ranges
I have an Ariston DOV 317/1 double fan assisted oven that when you use fan oven it makes a very loud vibrating noise which sounds like a cow in labour. Please advise as its driving me mad. Is it fixable or is it new oven time?
  • gjk77 Dec 27, 2008
    Similar issue, looking for a solution.
    23543 Ariston DOV 317/1(X) built in double fan oven. The fan just started making terrible noise, its still working but there is a terrible noise from it, where can I get a spare part?
  • 65 Answers
SOURCE: Toshiba DLP fan noise (52hmx95)
i constantly hear complaints about fan noise in dlptvs if you sit in front of your computer you will hear the same noise even in the next room there is no solution to the fan noise problem this product has a huge cage fan and a second and third three inch fans in it.... more than the samsung product it can be noticeable if the tv is on hard surfaces ie wood floors ,inthe corner, glass top etc the vents on the back of the tv allow for proper cooling of the lamp at shutoff so it doesnt shatter the tube its kinda like annealing glass its designed to extend the life of the lamp .... which im sure youve priced call toshiba and tell them your lamp is bad right now and get a new one for an emergency ( warranty if you can do it ) they are also improved this product is known to have short bulb life sometimes the zinging noise you hear is indicative of a bad color wheel in the light engine which would require replacement ( not cheap) toshiba will not piece out the color wheel assembly individually
Posted on Dec 09, 2006
SOURCE: fan assisted oven
i would suggest to renew the complete fan, but i found a company which sells lubricants that can bear tempratures of 550 degrees. follow this link:
Posted on Aug 16, 2007
  • 3 Answers
SOURCE: Tecnik 8525 Oven
Press and hold the start cooking and end cooking buttons together while adjusting the clock with the + and - button. Once the clock is set you will not have a problem
Posted on Dec 11, 2007
SOURCE: Oven fan noisy/broken
this noise probably means that the fan is about to stop working, this is what happened to mine. You can easily buy replacement fan off E-bay (it seems easier to find the right fan on e-bay that any of the confusing supplier sites). You then just need to remove the inside oven back and the outside electrical to replace the fan.
Posted on Jan 12, 2008
  • 43 Answers
SOURCE: Vibrating noise when cooking
In order to try to set your mind at ease I will have to explain the Basics on how a Microwave Oven Functions.
When a Microwave Oven is set to COOK ...START. It cooks at 100%. There is no lowering of the heat as with a Range ( Cook Top) Control. So in order to do the other things such as DEFROST, WARM, or anything other than 100% COOK. A COOK ON- COOK OFF system was utilized. To DEFROST, the Microve COOKS at 100% for 30% of the TIME, then IDLES for 70% of the TIME. COOK ON 30% of the TIME, COOK OFF 70% of the TIME = DEFROST This is why you can hear the CYCLE. More power is required during the ON CYCLE, thus the lower vibration. The Vibration occurs when the High Voltage Transformer is turned ON ( COOK ON).
The VIBRATION seems to have got louder with age. This is somewhat normal as there is a vibration from the High Voltage Transformer present every time the Microwave is used. screws and other metal parts seem to get loose with this vibration. There is no solution, unless you can tighten EVERY screw, nut, and bolt in the unit.
Posted on Feb 03, 2008
Beko double oven the fan has started to make a loud noise and sometimes cuts out had oven 18 months
by loud noise do you mean squeeling squaking .
then its the fan bearing just order another fan motor.
Jul 25, 2014 | Ovens
Vibrating noise about 10 mins after switching oven on
if it is fan assisted it will be the circulation fan which blows the heat evenly aroundf your ovan may be the bearing in the fan motor
Jul 29, 2012 | Neff U1421 Double circotherm Electric Oven
Whirlpool built-in double oven model# RBD305PDB12
the humming sound is coming from the "squirrel cage" fan in the back of the unit, there may be some resonance vibration from the fan this issue should be addressed by a qualified service tech, the whole wall oven needs to be pulled out, i would have him check the fan.
Aug 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Fan making loud noise
does the noise start as soon as you turn the fan oven on?
does the noise stop as you turn off?
just depending what make and model you have there is two fans
in it 1 is the fan motor inside oven at back and other
is the cooling fan which is at top of oven .you just need
to find out which one it is and just replace . then should be back to normal
regards dan
Mar 19, 2009 | Belling XOU174 Electric Single Oven
JTP15 GE Oven - vibration noise
We have a double ge wall oven. The vent fans had become really loud. I checked the price for new fans...$275 each! Plus service of $200. If your oven is not too old, go to GE service purchase a 1 year service contract for $93.00. Wait one one month till it takes effect. Call them and request service and the entire replacement is free.
Jan 14, 2009 | GE JTP15 Electric Single Oven
I have an electrolux icon double wall oven. I turned on the self-clean function for 3hrs and it making a very loud noise during the cleaning process. Is that normal?
yes, if the humming is not the loud sound then the fan may need some lubrication or if it is tripping the circuit it will need replacing , but if it seems like it is a viberating noise from the fan , then it could be that its bearings are bad , but the whole fan motor would still need to be replaced , but if it sounds like it just may be a loose fan motor , then tightening up the screws on the motor would stop the vibrating sound and or the fan blades from scraping metal( another sound you may be hearing )
Dec 24, 2008 | Electrolux ICON 30 in. Double Wall Oven
Bad fan noise from convection oven
Nov 16, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Odd loud fan type noise
what you are describing is the cooling fan. That fan will come on to keep the electronic control panel cool. It is normal for tat to come on even if your done with the oven. I dont think is should be as loud as you describe. I would try the oven again and if it is still loud I would call for service because it is new. That fan will also come on when you use the self clean cycle.
Jul 25, 2007 | Frigidaire PLEB30T9DC Electric Double Oven
Kitchen Ranges Logo
167 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
