Question about Tokina AF 80-400mm f/4.5-5.6 ATX840AF Autofocus Lens for Pentax AF
Poor focus with Tokina 80-400 on Nikon D70
I seem to have problems getting sharp focus with my Tokina lens on the D70. It works fine with a Nikon 18-200 but on recent wildlife shots there was no in focus aspect at all - yet OK on others. High shutter speeds seem to make little difference although I do have to get down to an aperture of 5.6 to get good speed. Even with poor depth of field at that aperture, surely some of the picture should be in focus?Do I need to work only with smaller apertures?Focus is set for the single, centre point and the camera always says it has acquired focus,
2 Suggested Answers
  • 73 Answers
SOURCE: I'm using Tokina 12-24mm f4 on my Canon EOS 20D.
Most likely something bad has happened. It out of warranty, usually its 5 years. This is a pro job, getting to anything inside a lens is a very special job. There are a number of places to send it out. Check http://www.acecam.com/srindex.html and write to one or two of the places for estimates. It could be $150 or more plus shipping and taxes. A new one is about $400+, you could check around the many on-line camera stores for a used one. Could be a simple electronic part or the iris blades are bad.
Posted on Jul 27, 2009
Can I use TOKINA lens 28mm-210 lens with this Nikon body or can I use with other NIKON body D 700?
Tokina makes their lenses with a variety of mounts. A lens with Canon mount, for example, won't fit onto a Nikon. Assuming you get the lens with a Nikon mount, then yes, you can use it with a D70 and with a D700.
Apr 16, 2011 | Nikon D70 Body Only Digital Camera
What type of lens works with this Nikon N8008s AF 35mm SLR? Thank you, Larry
Any of the Nikon Auto Focus(AF) lenses should work fine with it. There are also a number of fine aftermarket lenses made for your 8008, by Sigma, Tamron, Tokina, Quantaray and others. Be sure you get the Nikon AF lenses, as they make the same lenses for Sony and Canon. You cannot use the Lenses made for another brand, as they will not fit, work right, and can damage your Nikon.
Jan 25, 2010 | Nikon N8008 AF 35mm SLR Camera
I can get my 50mm lens to work with my d70 nikon.
If the lens has an aperture ring, make sure it is set on the largest f number. Make sure the lens is mounted fully on camera. Oherwise an AF 50mmm f1.8 lens should work on a D70 with no problem
Oct 24, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
I just bought the Tokina SD 12-24 F4 (IF) DX wide-angle lens for my D70, and it does not autofocus. I'm being told by the company I bought it from that i am past their 2 week return policy. Does this lens...
Only the MkII version of this lens has an autofocus motor built in, the MkI relies on a motor in the body of some Nikon AF SLRs to autofocus. The D70 does not have an inbuilt AF drive motor, so if you have the MkI lens then you can only use it in manual focus mode on your camera.
Aug 03, 2009 | Tokina 12-24mm f/4 Pro DX for Nikon
Automatic focus not working
The D40x only autofocuses with the latest AF-S (and old professional AF-I) lenses. Most traditional (screw-type) AF lenses from 1986 through today will not autofocus on the D40x. If your lens says "AF-S," you're fine.
Most lenses sold today for the D40x are AF-S, and so is the included 18-55mm kit lens. Many non-Nikon lenses from Tamron, Tokina, Quantaray, Sigma and anyone other than Nikon still won't autofocus on the D40x. Try before you buy, but honestly, there isn't much the included 18-55mm lens won't do.
Autofocus systems are fast, but not usually instantaneous. You have to hold the shutter down halfway as you compose the first shot so the AF system can focus and lock, and then the camera fires instantaneously when you press the shutter the rest of the way. See Preventing Shutter Delay for more.
Jul 14, 2009 | Nikon D40x Digital Camera
Tokina 80-200 2.8 AT-X compatibility issue with Nikon D50
I have one that had the same problem...it needs to be re-chipped to work with the newer camera's. It worked great on my N80 just not on my D-50...I got the F-- error when the exposure meter shut off. Send it to thk photo to be rechipped....takes about 3 - 4 weeks, gets cleaned and re-calibrated for about $83.
Nov 21, 2008 | Tokina 80-200mm f/2.8 AT-X 828 AF PRO Auto...
Poor focus
Are you using a DX lens. Do you know if you have the camera's auto focus set to AF (auto focus) or M (manual)? There are many things that effect the focus and as an added note, any shots over 1/60 shutter speed in normal light should be in focus without the need of a tripod.
I shoot a D80 and a D70 and I have excellent results and very clear pictures, I'd be will to bet that either your lens is incompatible with the camera or it's just a setting. I'd be happy to help if you could give more info to your settings.
Jul 18, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D100 lens interface problem
This normally means that you have forgotten to set the lens aperture control to it's minimum aperture (the highest number). On the D100 the aperture control is via a wheel on the camera body instead of via the physical control on the lens aperture ring.
May 26, 2008 | Nikon D100 Digital Camera
It wont focus or take pictue
Hey harleymomma,
If the d70 is set to AF-S mode focus has to be achieved for the shutter to be allowed to take the photo. In some exposure modes the aperture must be locked down on the smallest aperture. I would also make sure the contacts are clean that allow communication between the body and the lens. Of course you need to make sure the body and the lens are set to autofocus. If none of this works I would have it looked at by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 20, 2008 | Tokina AF 80-400mm f/4.5-5.6 ATX840AF...
FEE display contant
defective focus lens circuitry, you need pro fix.
Sep 14, 2007 | Nikon D70 Digital Camera with 18-50mm Lens
Tokina AF 80-400mm f/4.5-5.6 ATX840AF Autofocus Lens for Pentax AF Logo
108 people viewed this question
Top Tokina Cameras Experts
Steve
Tony Parsons
Tony Parsons
Are you a Tokina Camera Expert? Answer questions, earn points and help others
