Question about Bosch HBN 9163 GB / 9163 GB hot-air Double Oven
Bocsh HBN 91.. oven trips, fusebox mcb
I have a bocsh HBN 91.. fan assisted oven .. and when the oven nears operating temprature it cuts out the trip in the fuse board ,,
when the power is put back on and the oven reaches temprature ,, with the oven heating indicator out . everthing is fine and works ,, it appears to only happen as the oven reaches the required temprature
it is a problem
  • derekja May 22, 2009
    I have the same problem but I think it may be related to the fan assist unit I am unsure how to resolve. Imay swopout the fan unit and see if that helps.
    Derek
  • 1462 Answers
SOURCE: fan oven not heating, bosch hbn 202t
the fan oven element is separate from the grill element. the problem is that the circular element round the fan is blown. remove the back panel of the oven and you will see the element. replacement is easy. on most bosch, the element is removable from inside the oven but for some you have to remove the oven and take off the back casing
Posted on May 04, 2007
grandadfixer
  • 99 Answers
SOURCE: bosch hbn s gb
oven element would need model and ENR No. to supply
Posted on Oct 12, 2008
  • 134 Answers
SOURCE: MAIN OVEN DOESNT WORK
Hi
Pretty certain nofuse. Suspect switch. Guess would be as element blew it took out contacts on oven switch
Posted on Feb 20, 2009
  • 27 Answers
its the element not the stat
Posted on Mar 10, 2009
barkencoa
  • 3463 Answers
SOURCE: PRIMA FAN ASSISTED COOKER - FAN WORKING BUT NO HEAT?
Hi.
You will need to check the oven element, it probably needs replacing.
Please rate my solution.
Thanks.
Posted on Jul 14, 2009
Stanley cooker trips when heating comes on. Clock not working
heater has the highst possiblity that causing the tripping of unit .check also before calling ur tech maybe ur MCB tipping due to evrload of
Feb 22, 2015 | Ovens
Bosch HBN 91 Sticky Fan
Yes you can oil the shaft...but the problem is within the bearing itself. You might be lucky and only have to oil it once...but chances are your bearing will sieze again...I suggest you remove and replace the fan.
Dec 02, 2013 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
Hob is tripping fuse box
If the hob is tripping the RCB or MCB on the consumer unit, there is a fault, usually in the elements or halogon heaters, you will need a multimeter to define but please ISOLATE FROM MAINS POWER BEFORE OPENING ANY PANEL
Some electrical knowledge would be helpful, check each element seperatly, you may have to carefuly disconect each heater on the hob, unless you know which blows the mcb, check all connectings to see thay are secure, work round the hab reostates, make sure there is no shorts to ground from elements, with temp control down at zero. Check wiring into mains as a loose connection will cause heat and mcb to trip.
If it is wired into the same outlet as an oven disconnect oven in case the other appliance is causing the problem. it is realy a question of eliminating causes one at a time, working round the affending appliance to define what is the cause.
Hope this is helpful
John
Jun 06, 2011 | Ovens
My zanussi FM9232 fan assisted oven is not heating up, the fan is working
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Nov 04, 2010 | Zanussi Ovens
Belling oven xou592 bottom fan oven not heating up fully. Fan works and orange thermostat light on but does not heat up. Before this happened it tripped mcb in consumer unit.
You need to fit a new oven element.
This is located at the rear of the oven behind a removeable cover, where the fan is
It is a fairly straightforward job to replace.
Hope trhis helps with your problem.
Dec 15, 2009 | Belling XOU592 / XOU593 Electric Double...
Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Oct 09, 2009 | Smeg SE250XUK Stainless Steel Electric...
My tricity bendix electric cooker/oven trips all electrics
H iyou can get the electrics cheched that will rule that out but it sounds like a short on the oven it could well be the element in the oven which you should be able to replace as its only 3 years old
Jan 07, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
Faulty electric oven (Ignis AKL828/AV)
I think you will find that it is the oven element that has shorted, causing the trip to go. The fan will still work, but with no heat.
Remove inner rear panel of oven, there you will see the element.
Remove and replace.
Plz rate my solution.
Thanks.
Dec 30, 2008 | Ovens
Fan Oven blows Fuse over 175 Celcius -Baumatic BT2760SS
Hi, I was cooking and my oven jut went off, looked in fuse mains box and had tripped. So put back on and now the fan works but no heat...Can you give me some idea what it mite be.
Sep 18, 2007 | Ovens
Bosch HBN 9163 GB / 9163 GB hot-air Double Oven Logo
375 people viewed this question
Top Bosch Ovens Experts
Oloyede Monsuru
michael_t919
Are you a Bosch Oven Expert? Answer questions, earn points and help others
