Question about HP LaserJet 1018 Printer
HOW to Print an envelope
Can you please tell me...Where to Start~ like where do you go..to put the info~ that you want typed on the envelope? notepad? already tried and didnt work..I understand the part about..how to put the envelope in the printer..and make the Settings..But Nowhere..even owners manual...does it Tell You...How to put the Info...on the envelope
Any Help would be greatly appreciated!
I have a HP 1018 printer
Thaks in advance~ Al
    Problem Solver:
  • 8 Answers
The info would come from the PC or laptop on which the printer has been installed. So type your info down on any document in the PC. Place an envelope in the paper tray (usually the manual feed is used for printing on envelopes) and click on print on the PC.
Posted on Nov 24, 2008
Duplex printing FS-2100D
in back of machine there is a fuser unit there are 1 or maybe 2 small green buttons or switches on it that is the envelope setting push the button or switch to put it back in normal paper mode
Sep 14, 2017 | Kyocera Office Equipment & Supplies
Printing envelopes
HI,
Try this one.Make sure the HP paper size setting needs to be "plain paper," not "automatic.
Aug 17, 2008 | HP Photosmart 3210 All-In-One InkJet...
I have an HPPhotosmart C5280. I want to print on an evelope 8.2 x 5.5 for a wedding invitation. The printer tells me paper mismatch every time I try it. I set it up every time on the computer, it prints...
The easiest way to print an envelope is to use Microsoft Word. If you have the software installed, go to start and then create new office document and click blank document. When the document opens, click on help and type in envelope. This will give you instructions on how to create an envelope and save a copy to your document. When you save a copy to your document, it gives you a picture of an envelope which helps to create it. Then click on file, and slide down the print and click ok. Creating the envelope through Word helps to change the printers paper settings. Word will send a signal to the printer to tell it what type of paper and size of envelope you are creating.
Hope this helps?
Jul 18, 2011 | HP Photosmart C5280 Printer
Everytime I try to print an envelope using my Canon imageRUNNER 1023iF I get an error message. I'm using a Microsoft Works Word Processing program. I have loaded the envelope tray and nothing happens...
To get rid of error, unplug machine.
Sett. the correct paper size ( size of envelope ), paper type (envelope ), both on printer properties ( when you prompted to print ) and on machine ( when you put envelope on bypass, machine auto ask you ).
Do not forget to tell printer that he needs to take paper from bypass ( printer properties )
Hope that helped
Jul 04, 2010 | Canon imageRUNNER 1023 Black and White...
I have a Xerox Phaser 6180MFP and when I print #10 standard envelopes and #9 renturn envelopes the envelopes come out with badly pressed wrinkles on the end of the envelope that comes out last. I have...
I am looking for a diagram on how to print envelopes with my phaser 6180 mfp - when I put the envelopes in, it keeps telling me that I need to put paper in. where can I find such diagram?
May 21, 2010 | Xerox Phaser 6180N Laser Printer
Printing envelopes
It starts with your software. You must have a program which allows you to enter info that can be formatted to print on an envelope(Word or another word processing program).
When you start a new document you tell the program what you want to do. Once the data is entered it is a simple matter of manually feeding the envelope into the printer. Envelopes should not be bent or have dogears or damaged because they can damage your printer. You may have to try the envelope a couple times until you get it fed the correct direction. Another option is to print labels using Excel and print up a whole sheet of labels at a time. Good luck.
Aug 05, 2009 | Epson STYLUS CX5900 Printer
Ricoh laser printer will not correctly print my envelopes - need someone to help me calibrate the printer or the word program to effectively print envelopes
what model? you must tell the printer what envelope type is in the bypass (must use bypass) usually type 10. also must tell word in print properties to feed from bypass, again usually type 10 envelopes
Aug 04, 2009 | Computers & Internet
Just purchased - read instruction book but no mention of envelope printing. Can you advise please?
Not much to it...put in an envelope and use your word processing program - MS office for example, to select "letters and mailings", select "envelopes" (or similar) and type in the info or use your database, and print. In other words, it's not something that would necessarily be in the manual of your printer, because it is more related to the software you use.
Jul 27, 2009 | HP DeskJet D2560 InkJet Printer
Canon Imageclass MF 6550 - Can't print labels... help!
I have called canon with this problem more than once and they keep telling me that I am using a "paper" that is not supported. I finally gave up and ended up telling them that I am now going to use my cheap HP printer because it can do what it's suppose to.
May 05, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
Printing envelopes
did you put these envelopes right way (portrait/landscape) also you have to change in printer menu paper source paper type from plain paper to envelope.
Mar 24, 2008 | Konica Minolta magicolor 5430 DL Laser...
203 people viewed this question
Ben Johnson
