Question about Epson laser Printer EPL-6200L Laser
Epson epl6200l photoconductor dirty
My Epson epl6200l photoconductor drum got stained with toner after a couple of paper-jams and prints white bandes all over the print. Can't get it clean. Am I to lay hands (i.e. rub it clean with a towel) or not?
  • william11979 Mar 12, 2009
    i do have the same problem with your printer... the solution of my printer which is the drum is dirty is i clean it with a cloth. thats it
When i am printing a small dots black appear.. what is the problem? photoconductor unit? were can i buy one here in the philippines?
Posted on Apr 11, 2008
My printer is blinking green light in every 5 seconds. i am give test print but is not came to print
Ready and Error Lights (EPL-6200L only)
The Ready (green) and Error (red) lights on the top of the printer may be the first indication of trouble. The status of the lights, on, off or flashing, indicates your printer status, as described below. The Status Alert window in the EPSON Status Monitor 3 utility indicates what type of error has occurred and offers you a possible solution. Look through this section to find the kind of problem you have, then try the recommended solutions in the order they are presented until your problem is solved.
a. Error light (red)
b. Ready light (green)
Status/Error/Warning
INDICATOR LIGHTS
Ready
Error
Service Required (controller error)
OFF
> Service Required (engine error)
> > Service Required (protocol error)
> > Output Paper Jam
> > Paper Jam
> > Paper Out/Feed Jam
> > No Developer Cartridge Installed
> > Wrong Developer Cartridge Installed
> > Installed Developer Cartridge is Not a Genuine EPSON Product
> > Developer Cartridge Memory Error
> > Toner Out
> > Front Cover Open
> > Output Cover Open
> > Printing on Incorrect Paper Size
> > Unsupported Paper Size
> > Time Out Error
> > Insufficient Memory to Print Current Page
> > Paper Size Warning
> OFF
Not All Pages Are Printed
> OFF
Warming Up
> OFF
Replace Photoconductor Unit
> OFF
Toner Low
> OFF
Installed Developer Cartridge is Not a Genuine EPSON Product Warning
> OFF
Sleep mode
> OFF
Ready
> OFF
Printing
> OFF
Processing Data
> OFF
> Note: > If the problem remains after trying the suggestions in this section, contact your dealer or a qualified service representative for assistance.
Control panel: Error light on
A controller error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If all the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Control panel: Ready and Error lights flashing
A print engine error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Control panel: Ready light flashing, Error light on
A protocol error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Output Paper Jam
Control panel: Ready and Error lights on
Indicates that there may be a paper jam inside the printer. Open the printer's output cover, remove any jammed paper, and close the cover. The error will automatically clear itself and the jammed page's print data is reprinted.
Paper Jam
Indicates that there may be a paper jam inside the printer. Open the printer's front cover, remove any jammed paper, and close the cover. The error will automatically clear itself and the jammed page's print data is reprinted.
Paper Out/Feed Jam
Indicates that there is either no paper loaded in the printer, or there is a paper jam in the feed slot.
If no paper is loaded, load paper into the MP tray, then open and close the printer's front cover. See Loading Paper for instructions on loading paper.
You can clear the error by pressing Continue on the EPSON Status Monitor 3 window that appears.
If paper is loaded, then there is a paper jam in the feed slot. See Clearing Jammed Paper for instructions on clearing paper jams. The error is automatically resolved upon clearing the jammed paper and opening and closing the printer's front cover.
Either the developer cartridge is not installed or is installed incorrectly. Check to see if the developer cartridge is properly installed and follow the instructions under Developer Cartridge to install or reinstall it.
Either the installed developer cartridge is defective, or it is not the right one for your printer model. Replace it with a new or correct developer cartridge by following the instructions under Developer Cartridge.
Control panel: Ready light on, Error light flashing
The installed developer cartridge is not a genuine EPSON product. The use of such products may damage the printer and cause the print quality to decrease. Remove the currently installed cartridge and replace it with a genuine EPSON cartridge by following the instructions under Developer Cartridge.
To continue using the currently installed developer cartridge, press Continue on the EPSON Status Monitor 3 window that appears to clear the error.
A memory read/write error has occurred. Try reinstalling the developer cartridge or replacing the current cartridge with a new one by following the instructions under Developer Cartridge. If this still does not resolve the problem, turn the power off and then on again.
Toner Out
The developer cartridge is out of toner. Replace the developer cartridge by following the instructions under Developer Cartridge. To clear this error and print a single sheet, press Continue on the EPSON Status Monitor 3 window that appears to clear the error. After that, this error will occur again until the developer cartridge is replaced. If you set the Toner Out Error setting to Off, you can continue printing even when this error occurs.
Front Cover Open
The printer's front cover is open. Make sure that the printer's front cover is closed properly by opening and closing it again.
Output Cover Open
The printer's output cover is open. Make sure that the printer's output cover is closed properly by opening and closing it again.
The paper loaded in the paper source does not match the required paper size. Replace with paper of the correct size and click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
The specified paper size is not supported by this printer, or the paper feed direction is incorrect. To continue printing from the page after the page that caused the error, click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Time Out Error
Data transmission from the computer to the printer is interrupted and a timeout error has occurred. Click Print Again on the EPSON Status Monitor 3 window that appears to resume printing. If printing does not resume, or if you want to change printer driver settings, click Stop.
The printer does not have sufficient memory to print the current page. To continue printing from the page after the page that caused the error, click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Paper Size Warning
The size of the paper that fed through the printer does not match the specified paper size. Click Close on the EPSON Status Monitor 3 window that appears to dismiss the warning.
This warning is displayed if an Insufficient Memory to Print Current Page error has occurred while Auto Continue is set to On. Click Close on the EPSON Status Monitor 3 window that appears to dismiss the warning.
Warming Up
Indicates that the printer is warming up to process and print data.
Control panel: Ready light flashing (flashes at longer intervals than usual)
Indicates that the photoconductor unit is close to the end of its service life (less that 5%). Prepare a new photoconductor unit to replace the current one. See Photoconductor Unit for instructions.
To temporarily dismiss the warning, click Close on the EPSON Status Monitor 3 window that appears. Resetting the photoconductor unit also clears the warning.
Toner Low
Indicates that the developer cartridge is nearly out of toner. Prepare a new developer cartridge to replace the current one. See Developer Cartridge for instructions.
This is a warning to inform you that the installed developer cartridge is not a genuine EPSON product. The use of such products may damage the printer and cause the print quality to decrease. Remove the currently installed cartridge and replace it with a genuine EPSON cartridge by following the instructions under Developer Cartridge.
Sleep mode
Indicates that the printer is in energy-saving mode. The printer goes into standby due to inactivity. If the Sleep mode is enabled, the printer goes into standby in 15 minutes.
Ready
Indicates that the printer is ready to print.
Printing
Indicates that the printer is printing data.
Processing Data
Indicates that the printer is processing data.
Mar 18, 2015 | Epson laser Printer EPL-6200L Laser
Address label possibly stuck in printer
turn off the lights and close door in your office..use a pen light to look inside for a white reflection..let me know if that yields anything..
Oct 13, 2008 | Epson AcuLaser C900 Printer
I have a new photoconductor unit in my epson CX11N aculaser printer and now it is printing anything in colour with a white stripe down the left hand side about 4cm in
Hi
Try taking out all toners and reinstall them. Turn on unit, without Photoconductor, wait till you get error install photoconductor. Insert photoconductor and try printing again.
Hope this helps
Mar 26, 2010 | Epson AcuLaser CX11N All-In-One Printer
Install photoconductor
the photoconductor is commenly refered to as the "drum" .. its the cylindrical part that picks up and transfers the toner to the paper .. the error message might be telling you its time to replace the drum (they do wear out) or perhaps its not detecting the fact that it is in place .. the photo conductor drum is user replacable so it comes out without too much trouble .. sometimes its part of the replacable toner tank .. it would get automatically replaced when you change toner in that case .. be very careful with the photoconductor drum .. any scratches, finger prints or other damage will show up in the printed output .. dont expose it to bright light ...
Oct 01, 2009 | Epson AcuLaser C4100 Printer
Epson Aculaser C1100 will not print properly after changing black toner
I have had this problem with a couple of our C1100's the solution is simple but a bit fiddly.
open the lid and remove the photoconductor unit. what you need to do is clean the glass panel through which the laser shines (it is there honest). It id directly behind the toners but down near where the paper sits. Look at the photoconductor and see where the blue roller sits in the printer. This roller has the laser shone on it and then picks up the toner relaying it onto the belt in the photoconductor.
What i did was get a wad of strong tissue and use a screndriver to wedge it down the rear of the toners (in between the toners and the black plastic bar as you look into the printer with the photo conductor removed) and then slide it back and forth. I actually learned this one form some Minolta QMS printers we have, but the glass plate was in plain view on those.
Basically what we had happen was that some toner had dropped onto the glas and was blocking the laser from hitting the roller and this lead to blank (or faded) strip along the length of a page.
I suppose a smallish paintbrush would do the same thing.
Sep 24, 2008 | Epson Aculaser C1100 Printer
Toner being deposited on back of page
point check
1.Hallo your rollers are dirty and smudged
2.Is your fuser unit O.k (clean)
3.is your paper good quality or are you using coated paper the wrong side? thereby staining the fuser unit (the hot part of the printer)
4. Most unlikely but have u ever turned your printer upside down??? or excess sideways tilt thereby releasing waste toner from the bottom of the printer to the roof then to your paper???
if all is nay then remove all toners and give your machine a gool blowout
labatt
Apr 26, 2008 | Epson Aculaser C1100 Printer
HP Laser Jet 4L Printer Model #C2003
Try lowering the toner density using the printing software or the printer menu.
Feb 03, 2008 | HP LaserJet 4L Printer
Epson AcuLaser C1900 paper jams and almost no ink
If paper jam occurs frequently, wipe the pickup roller with a clean dampened cloth. Follow the steps below:
  1. Open Cover AB of the printer.
  2. Open the cover below the paper path roller.
  3. With a clean dampened cloth, wipe the pickup roller.
  4. Close Cover AB.
If the glass on the print head filter is dirty with toner, wipe it with a clean cloth. A vertical white line may appear in the printout. Follow the steps below:
  1. Open the front cover.
  2. Tilt the waste toner collector and pull it out.
  3. Grasp the handle of the print head filter with your fingers and gently pull it straight out of the slot. (**Note: Be careful not to spill toner that has accumulated on the print head filter. )
  4. With a clean cloth, wipe the glass surface of print head filter.
  5. Hold the print head filter by the handle and gently insert it all the way into the slot.
  6. Reinstall the waste toner collector.
  7. Close the front cover.
The print quality problem might be something as simple as turning off the Toner Save mode using the printer driver or the printer's control panel menus.
There may be a problem with the photoconductor unit. You may need to replace the photoconducter unit.
Or it might be something rather more serious (hopefully, not)Print out a status sheet. If a blank page is ejected, the problem may be with the printer. Turn off the printer and contact your dealer.
Jan 04, 2008 | Epson AcuLaser C1900 Printer
Epson c1100 print problem
you can try this:
remove the toner and photoconductor then tip it GENTLY from side-to-side
reseat them and print
Dec 18, 2007 | Epson Aculaser C1100 Printer
Epson C1100 Print quality
no this is not a photoconductor problem. your fuser unit is faulty, it is not getting up to the correct temprature to "fuse" the toner to the paper hence why you are able towipe the toner from the page. Hope this helps Cops Pete@wedotoners.com
Oct 10, 2007 | Epson Aculaser C1100 Printer
Epson laser Printer EPL-6200L Laser Logo
499 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
