How do I make my car doors lock automatically when the car starts moving? The car in question is a Ford Mondeo 2.0 Estate Titanium (Oct 2006 model)
It sounds like it has been deactivated so we are going to reactivate the auto lock.
The numbers I will be saying will have to do with getting this to work so:
you will need to put the key in to the ignition switch.
1= is back to listen to the radio
2= is to get key out
3= is just before you start
4= is for starting your car
When we do this 1 and 4 will not be used
Do this and we will hope that it works like it should:
1: Turn the ignition with you key up to on( don't start)
2: Press the power door lock control 3 times
3: now turn the key back once (to off position)
4: Press the power door unlock control 3 times
5: ok turn the ignition back up 1 time. (The horn should chirp)
6: Then press the unlock control, then press the lock control, again (horn will chirp 1's) If auto lock
was activated.
7: Turn the ignition back 1's, Then the horn should chirp once to confirm the procedure was completed.
Nikki2913
How do you get your Ford Ranger 2001 to automatically lock doors when you put in drive or start driving....like many cars do?
ford mondeo 1993 radio locked out completely, only showing CODE.....
