Question about HP Compaq Presario V2000 Notebook
It will not power on
After using my computer I put it in stanby mode. Approximately 1 hour later, I went to start it and it would not turn on. It was not plugged in at the time, so I plugged it in. It still would not start. I removed the battery, nothing. I let it charge overnight and still NO POWER. There is no reset button and I have tried the HP customer support (using my other comp.) but I cant get connected. The computer had been operating fine until then. I had just recently installed internet explorer 7(which was a pain), I dont know what else to try. Any suggestions?
#3 three you rock. fixed my problem entirely!
Posted on Mar 11, 2007
  • 4 Answers
Last time I had that happen I had to replace my hard if you try what the other gentleman said and it dosent work find out the make and model of your hard drive and they useually have pretty good warranty and fair support you can useually get a diagnostic program for hard drive if you can get to the internet on another comp you can download and copy to floppy disk then go into your bios and change boot up sequence so it checks floppy first unless you dont have a floppy if not burn to cdrom disk and make cdrom first in boot up process.
Posted on Jan 02, 2007
  • 624 Answers
Not to takeaway from the excellent posting from Sandrew but from your initial description I wasn't sure if you had removed the battery and at the same time disconnected the A/C power source and let sit for a few minutes. I typically disable both the suspend and hibernation modes by default on my users PCs but occasionally they reactivate it. This procedure usually solves the problem for me.
    President:
  • 2,961 Answers
If you are able to get to the motherboard, can you locate the CMOS battery (flat 3V disc shaped battery). If you are able to remove it for 10 minutes or so; or locate the 'JBAT1' terminals on the motherboard and move jumper or similair from pins 1-2 to pins 2-3 for a few seconds then back to pins 1-2. Either of these should erase the bios settings which may be corrupt, stopping the boot up or bringing from standby. I'm not sure if this will be possible for you to do as this is for normal desktop pc motherboards, although the proceedure will be the same.
  • andrew pester
    andrew pester Jan 02, 2007
    Yep; i agree Tom dissable anything other than on and off, keeps these problems at bay.
I just connected the main board A1727318A to Sony tv KDL-32XBR9
How many blinks do you have?
Main Power 2 Times (PS Board, G2CE Board)
DC Alert 3 Times (BM3 Board, G2CE Board)
T-Con 4 Times (T-CON Board)
HDMI 5 Times (BM3 Board)
Backlights 6 Times (Inverter Board)
Temp 7 Times (BM# Board)
HFR Error 8 Times (LCD Panel)
I hope that it will help you.
Apr 02, 2015 | Sony Televison & Video
When tv goes on stanby it starts scanning
The firmware corrupted. Contact the authorized service centre.
Apr 09, 2014 | Televison & Video
My display screen goes on and off
I find sleep mode nothing but trouble, eventually corrupts window files over extended use, go into power options, go to stand by and select never and click apply, next go to hibernate "top right" and click, make sure the check box is clear, if not! remove check and click apply and restart your laptop.
Apr 04, 2012 | Sony VAIO Computers & Internet
Dell 4400 Main power in house went off while using my computer and then went back on about an hour later. Now when I try and restart the PC, the power button light turns yellow like it is in sleep mode...
The power supply or mother board probably went out. Did any other items in the house stop working? This happened to me years ago and the electric company reimbursed me for damages.
You can try unplugging the power cord for a few minutes, then retry listen for any beeps from the computer. If it is powering on but nothing on the screen and no beeps *********** board is probably toast.
Dec 10, 2010 | Dell Dimension 4400 Power Supply ** FREE...
When I disconnet the sync cord and go to turn on the sansa e-250 it doesn't turn on
Make sure player is fully charged. 1. Connect the player to the PC. 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode, then connect it to the PC.
3. Leave the player connected for approximately 2 hours to charge. 4. Disconnect the player from the PC. 5. Verify if you can turn on the player. 6. Reset the player if necessary.
SOLUTION 2 - Reset the player. Resetting the player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.+
Feb 13, 2010 | SanDisk Sansa e250 MP3 Player
It froze up
Make sure the player is fully charged.
  • 1. Connect the player to your computer.
  • 2. Make sure the computer detects the player.
  • 1. Turn device OFF.
  • 2. Slide the Hold switch down to Lock (orange color showing).
  • 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Next Be sure the battery is charged
  • 1. Leave the player connected for approximately 2 hours to charge.
  • 2. Disconnect the player from the PC.
  • 3. Verify if you can turn on the player.
  • 4. Reset the player if necessary. To reset the player:
  • 1. Press and hold the Power/Menu button for approximately 20 seconds.
  • 2. Release the Power/Menu button.
  • 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Or try and see if it will come on with out the battery but hooked to your computer.
Feb 02, 2010 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa froze on song screen, wont unfreeze
Make sure the player is fully charged. 1. Connect the player to your computer. 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode, 1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary.
To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Then try and see if it will come on with out the battery hooked to your computer, which I see you have done but did you change modes MSC to MTP . next delete the song it keeps hanging on and re-copy it back on to the player from a different folder or re-rip it from the CD and copy it into a new folder then re-copy to the player.
Feb 02, 2010 | SanDisk Sansa E280 MP3 Player
When in stanby i loose all power
the red light means it is in standby mode if u dont like the red light take out the plug the red light will come back after u blug it back in can u help me with my wii problem
Aug 21, 2008 | Nintendo Wii Console
Acqua Indiglo Digital Watch
My watch has 4 buttons (2 on the left, 2 on the right) plus the "Indiglo" button. Use the "Mode" button (lower left) to move between the time and the stopwatch. When seeing the stopwatch, hold the "Mode" button. This will get you to the alarm setting mode. Press the "Mode" button again to switch to the time setting mode. Use the "Start/Stop" button (upper right) to move from seconds > minutes > hour > date > day of week. Use the "Spl/Reset" button (lower right) to change the numbers.
-AP
Dec 04, 2007 | Watches
Lp600 went dead
i had the same problem with my 2 years old infocus lp600. on the mains section of the power supply board you have 4 100uF/16v and 1 4,7uF/35V electrolyt condenser of a 85 degree type. that means it will work 2000 hours at 85 degree (celsius). since the power supply only switch off the lamp in standby with no fan the power supply get hot- i think about 70 degree. so after two years in stanby it is evident that this condensers loose halve of their capacity - after switch off no new start. changing this condensers with new ones of 105 degree type will solve tis problem. and for the future - no more stanby.
Aug 14, 2007 | InFocus LP 600 Multimedia Projector
HP Compaq Presario V2000 Notebook Logo
90 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
