Question about HP PSC 1610 All-In-One InkJet Printer
HP PSC 1610 Jams 1/2 way everytime now
My HP1610 pulls a sheet of paper. doesn't print feeds 1/2 way then jams I clear, and it repeats same thing, over and over and over again, no matter what I do, it repeats leaving printer worthless. help please!!
  • patchrally Nov 23, 2008
    I can't agree with you, it seems like its a "memory" issue, where it is locked up into doing the same thing over and over..If I hit OK, it feeds the paper out the rest of the way..then pulls another sheet and stops in the same position
    Sergeant:
  • 291 Answers
The gears of the paper feeder tray are worn out or got cracked.it needs to be changed.the assembly of six gear set will cost u near to $30 .
Posted on Nov 23, 2008
Paper jam always.
Helo have you tried to check on the driving gears it but try to call your technician to check on it otherwise you may spoil your printer
Jun 16, 2017 | HP PSC 1610 All-In-One InkJet Printer
The paper feeds fine, but then jams half way thru. Its like it keeps feeding when it should be printing, then stops and jams
i have the same problem with my hp 900 inkjet...i tried to google but i can't find any answer on how to solve this problem :(
Jan 18, 2011 | HP PSC 1610 All-In-One InkJet Printer
HP PSC 1610 All-In-One paper jam 1/2 sheet
Throw this thing out as it is clearly rubbish. HP inkjet printers will **** the life and money out of you. Get a Brother HL-2170W and you will have care free printing for cheap.
Cheers old chap.
Mar 19, 2010 | HP PSC 1610 All-In-One InkJet Printer
Paper jams at every feed - even after I clear the jam...
Make sure all paper has been removed from the paper path.
Even a small scrap will cause a jam.
The other thing you may want to do is clean the paper rollers with alcohol.
This cleans any paper dust that has gathered on the rollers, and allows better paper movement.
Sep 25, 2009 | HP PSC 1610 All-In-One InkJet Printer
Paper jams with photo paper only hp1610 all in one. will print photo on regular paper any size.machine also makes a "grinding rotating" noise
Paper can jam inside the printer for a number of reasons.
  • Open the cover to the printer and look inside to see if there are any pieces of paper or debris that may be blocking the print path.
  • Be sure to unplug the printer before touching anything internal to avoid electric shock. If there is something blocking the print path, remove it, close the printer, and try printing again.
  • You can also check inside the printer to see if any components have come loose.
May 08, 2009 | HP PSC 1610 All-In-One InkJet Printer
Jamming paper
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Dec 30, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP paper jam
That is usually caused by the paper feed rollers being cover with paper dust. Take a clean cotton pad and alcohol and clean the rollers :turninig each roller as you clean it. if it has a rear dor, open it to get better access to the rollers.
Please remember to rate all users who assist you for free :)
Sep 03, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
Printer jam
hve u tried removing the paper jam from a proper place.hp has provided a door behind the printer to clear paper jam.open that door n check out 4 any paper part left out in it.wish u success
May 31, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
Out of Paper. Load Paper Error
Check
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265823&cc=nz&lc=en&dlc=en&product=422000&dlc=en&lang=en
HP PSC 1600 and 2350 Series - Paper Jam or Paper Feed Problems"
When the all-in-one detects a paper jam, the following message appears: Paper jam: Press OK to continue . The computer might display the following message: There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. This document will assist in correcting paper-feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. s.gif Clearing paper jams
Jul 28, 2006 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
185 people viewed this question
Ben Johnson
