Question about VIA Vectro VT6212 (A62124) Serial Adapter
The system comments that this is not a usb 2 device
Dear hearts
Just plugged in the VIA Vectro VT6212L 4 Port USB 2 PCI Host Controller to my old Duron Athlon motherboard and when i connect usb 2 devices the balloon pops up and says it would be better to connect this device via a faster usb2 interface ... well i reckon it shouldnt be saying that if this PCI interface is working properly unless it is working at optimum speed and i can ignore the comments.Is there any way i can check the speed transfer rates ?
  • paul_bennett Nov 25, 2008
    Hi electech
    your advice is spot on. Thanks.
    also when I pulled the 4 way USB hub I had being using for convenience
    and plugged a USB 2 device directly into the card port I didnt receive
    any comments about reduced speed this time.
    So I reckon it's sorted.
    many thanks again
    regards Paul Bennett UK
  • 905 Answers
First thing is that message just means that your device will work at a reduced speed
second is that a high speed port or enhanced usb port is required to work it at enhanced speeds
to check if your usb port is enhanced goto : control panel / system properties / hardware tab / device mannager / then scroll down to usb controllers and see if it says enhanced next to your usb port if it does then you will need to get the updated usb driver for the enhanced speed
electech
Posted on Nov 23, 2008
  • jason Nov 25, 2008
    well then if your 4 hub does not support high speed then it won't work but if it does then you will need then drivers for it work at the high speed rate
COMPAL EAL51 barebone
Here you go:
1394
VIA OHCI Compliant IEEE 1394 Host Controller
BATTERY
Microsoft AC Adapter
Microsoft ACPI-Compliant Control Method Battery
COMPUTER
ACPI Uniprocessor PC
Diskdrive
Universal HDD
DISPLAY
Mobile Intel (R) 915GM/GMS, 910GML Express Chipset Family
HDC
Primary IDE Channel
Secondary IDE Channel
Intel (R) 82801FB/FBM Ultra ATA Storage Controllers - 266F
INFRARED
SMC IRCC - Fast Infrared Port
KEYBOARD
Keyboard 101/102 keys Microsoft Natural PS / 2 Keyboard
MEDIA
Audio codecs
Video Codecs
Midi Control devices
Legacy Video Capture Devices
Legacy audio drivers
Microsoft Kernel System Audio Device
WDM Audio Compatibility Driver Microsoft WinMM
Realtek AC'97 Audio
MOUSE
PS / 2 mouse
NET
1394 Adapter
Remote network engine Miniport (IP)
WAN Miniport (PPPOE)
Parallel Direct
IR
Realtek RTL8139 Family PCI Fast Ethernet NIC
WAN Miniport (L2TP)
WAN Miniport (PPTP)
OTHER DEVICES
PCI Modem
PCMCIA
Generic CardBus Controller
PROCESSOR
Intel Processor
SDHOST
SDA Standard Compliant SD Host Controller
SYSTEM
Generic Bus
Button ACPI resource sixed
Button tie / Untie ACPI
The system CMOS / real-time clock
Direct access memory controller
Programmable Interrupt Controller
Microcode update device
Microsoft System Management BIOS Driver
Software Device Enumerator Plug and Play
Logical Disk Manager
Manager volumes
Intel (R) 82801FB/FBM SMBus Controller - 266A
Intel (R) 82801FBM LPC Interface Controller - 2641
Intel (R) 82801 PCI Bridge - 2448
Microsoft ACPI-Compliant Embedded Controller
Microsoft ACPI-Compliant System
Microsoft Composite Battery
PCI bus
PCI standard host CPU bridge
ISAPNP port
Terminal Server Device Redirector
ACPI
Terminal Server Keyboard Driver
Terminal Server Mouse Driver
System Timer
UNKNOWN
PCI FLASH memory
USB
Intel (R) 82801FB/FBM USB2 Enhanced Host Controller - 265C
Intel (R) 82801FB/FBM USB Universal Host Controller - 2658
Intel (R) 82801FB/FBM USB Universal Host Controller - 2659
Intel (R) 82801FB/FBM USB Universal Host Controller - 265A
Intel (R) 82801FB/FBM USB Universal Host Controller - 265B
USB Root Hub
USB Root Hub
USB Root Hub
USB Root Hub
USB Root Hub
VOLUME
Generic volume
Jun 19, 2012 | Computers & Internet
Cant find driver for SimpleTech 250gb external hd. Is it available?
Should not be necessary. It is recognized by the system automatically. Try connecting to another port, check the data cable and the connection to the unit, it may be corroded or loose.
Sep 13, 2011 | SimpleTech 250GB USB2.0 7200 RPM External...
I have no driver of VIA VT6212L 4+1 Port USB 2.0 PCI Controller Card
what is your operating system? windows or linux?
if windows, what version of windows?
go here http://www.via.com.tw/en/support/drivers.jsp
step 1 choose your operating system (e.g. microsoft windows)
step 2 what version of operating system(e.g. windows xp)
step 3 select the type of driver (usb)
step 4 select your product (click the VT6212)
download it and install
its free and no charge
Jul 26, 2011 | Computers & Internet
Memory upgrade
I like all the information you gave. However the information you are looking for is in the manufactures web site. goto search engine and enter your computers manufactures name followed by the word "support" find the site and then look up the details for your computer. The reason I say this is because each slot can only control a certain amount of memory. The manufacture will tell you what each slot can control and also the type of memory supported by your motherboard. THIS IS VERY IMPORTANT> never mix memory. Make sure of speed and capacity. If you mix diffrent speed and capacities the results could end in total failure.
Sep 19, 2007 | Computers & Internet
Via Vectro VT6212 adaptor not recognized by WindowsXP SP2
is the usb 2.0 card driver properly installed?,is there any conflict?
Feb 24, 2007 | VIA Vectro VT6212 (A62124) Serial Adapter
USB connection problem using Windows 98 Second Edition.
The cause of this problem can be traced to both the computer's hardware configuration and Windows 98SE (Second Edition). PhotoMAX cameras and other devices featuring USB (Universal Serial Bus) connections may not work with computers running Windows 98 Second Edition and equipped with the following computer hardware: * an AMD processor (350 MHz or higher) * VIA Technologies USB Host Controller or SiS 7001 USB Host Controller To find out what USB Host Controller is on your system: 1. Click Start > Settings and choose Control Panel. 2. Double click the System icon. 3. Choose the Device Manager tab. A window similar to the one shown below appears. 4. Expand the Universal Serial Bus controllers listing by clicking on the "+" sign next to the listing. 5. Note the type of host controller in the listing. The example above shows the SiS 7001 PCI to USB Open Host Controller.
Sep 14, 2005 | Polaroid PhotoMax PDC 1300 Digital Camera
Sep 14, 2005 | Polaroid PhotoMax PDC 1100 Digital Camera
Sep 14, 2005 | Polaroid PhotoMax PDC 700 Digital Camera
Sep 14, 2005 | Polaroid PhotoMax MP3 Digital Camera
Sep 14, 2005 | Polaroid PhotoMax Fun Flash 640 SE Digital...
VIA Vectro VT6212 (A62124) Serial Adapter Logo
569 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
Abhinandan  Patil
Abhinandan Patil
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
