Question about Boston Acoustics GT22 Car Audio Amplifier
Safe light where is this reset button?
  • 959 Answers
Http://mobile.bostonacoustics.com/Manuals/GT20_22Man.pdf
Posted on Nov 23, 2008
Reset gun safe combination
I have a similar safe, although it is a different brand. I have a red button under the top of the safe, around where the battery's go in. I have to hold that button until I hear a beep and a red light flashes. Then I'm required to input the new combination. This may, or may not, work for you.
I recommend contacting the manufacturer and asking them.
Apr 28, 2013 | Safe International Adg Sports Secure Vault...
Change combination of S-50EB
Hi Ronald
To change the combination on the S-50EB you need first to open the safe. Once the safe is open, look at the thin inside edge of the door (nearest the hinges) and you should see a small reset button. Press the button and the amber light will come on. Once the amber light is on, you have 20 seconds to enter a new code. It makes sense to change the code with the door open, in case there is a problem.
Aug 01, 2012 | Safe International Digital Electronic Safe...
I bought a house and have a hardline safe is there a way to reset the safe password. .
User override key to open safe.
Then:
a. Inside the open door you would find hidden a red button press this button, the yellow light will be on, input the user code in 30 seconds try 1,5,9 then press A or B to finish
b. If the yellow light keeps flashing with beeps the code is wrong( revere to user manual)
c. To change code repeat step a.
Test your new code before closing safe.
May 03, 2011 | Locks & Locksmithing
How do i change the code on a s25e digital safe i cant find the book
if its like my old woolworths one, open the door and press a red reset button on the inside of the door, close the door and dont lock, put in the 4 numbers u wish a press a A button on the keypad, or whatever ur enter button is, then lock it, then press the 4 numbers again and the A button or enter, a light should stay on and unlock :)
Feb 21, 2011 | Safe International Electronic Gun Safe...
Where do i get instructions for changing the code on my hardline digital safe. The instruction paper that came with it appears to be for another safe. the paper mentions a red button where no red button...
I had this exact same problem. Then I realized the red reset button was actually INSIDE the safe itself. So you need to enter the factory default code "159" to open the safe, then on the inside of the safe next to where the batteries are is a red button. If you press that, the yellow light will flash and you'll get two beeps. That means you can now enter your own combination. I hope this helps.
-Mike
Jul 06, 2010 | Safe International Digital Electronic Safe...
Kingavon electronic safe 28
  1. The original factory code is 1-5-9 A (or B) to open the safe. There is usually an override key for your safe in case you have lost your code.
  2. Once the unit is open, you can reset the combination by pressing the red button, the yellow light will come on. Input a new code 3-8 numbers and then either the A or B button to finish the code.
  3. Test your new code several times before locking.
  4. If you don't have an over ride key, the first three digits of the serial number should be the key code.
Feb 24, 2010 | Safe International Digital Electronic Safe...
Have a SURESAFE brand safe at work which have no instructions
Hi there all I have a SURESAFE electronic security safe MODEL-OWSAFE30ES
(1) To set your own code first on safe
(2) locate the red reset button on the hinge end of the door.
(3) Press the red button, which will illuminate the yellow light on the keypad.
(4) Now key in your new code (3 to 8 digits) and press A or B to end. Note you have 30 second to complete this step.
(5) Test your new code whilst the door is open. Safe will beep twice to confirm code has been entered correctly, and knob can be turned clockwise.
(6) Repeat process any time you wish to change your code.,
Hope this help
regards
rick
Dec 30, 2009 | Safe International Digital Electronic Safe...
Gordon item#45891 digital safe, lost code the door is open
there is red button on the inside of the door (hinge side) press this , then key in a new code
Oct 07, 2009 | Safe International Digital Electronic Safe...
I have a safewell electronic safe and no keys and lost code ex2007127402 can i have a code to over ride and open it
hi : about the stockwell safe ex200----- 2535-EA
if the safe still has charged batteries you can deactivate any sceurity code by access through a small hole on the rear of the safe, if you can get to the rear area of the safe.. You need a long screwdriver to reach to the inside of the front of the door . Their is a reset button on the inside of the door in the lower right corner area( "B" button) on the end - not on the flat face surface of the door but on the vertical face( hing plate). You'll have to feel around and push the screwdriver sideways to push the button in.it will beep . YAHOO- YUH DID IT !!!. Then you can reset your own code.if you need further instructions call me . icq. 33819110 or echarron1@cogeco.ca
Jul 26, 2009 | Locks & Locksmithing
Service engine soon light is on
How to reset (erase the light):
Open the fuse access panel on the driver side. Youll see a small rectangular red button labeled RESET.
Turn ignition ON
Press the RESET button repeatedly until you see the SERVICE ENGIN light flashing on the dash.
Press and hold the RESET button for a few seconds until you hear 5 'dings'. It will turn off.
Turn ignition OFF.
Drive safely.
Good luck.
Please rate the solution....
Jul 03, 2009 | 2003 Oldsmobile Alero
Boston Acoustics GT22 Car Audio Amplifier Logo
180 people viewed this question
Top Boston Acoustics Car Audio & Video Experts
xxxxxx xxx
Are you a Boston Acoustics Car Audio and Video Expert? Answer questions, earn points and help others
