Bosch washing machine drum will not turn.
Washing machine WFF2000GB/14 goes through the wash cycle but the drum does not turn. The pre wash light is flashing four times.
    Brigadier General:
  • 6,966 Answers
Initially, the washer's drum not turning could possibly be a loose or broken belt where a replacement is available at TD Spares in UK. As to the error code identification, most washers have a technical sheet somewhere on its body, perhaps the rear where the codes particular to that model are specified.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 23, 2008
    Genius:
  • 1,550 Answers
This is usually the drive belt.
  • SAM ANDERSON Nov 23, 2008
    The drum may be jammed by an item of clothing.
    The main motor may be faulty. There may be a broken wire to the motor.
  • Washing Mach... Master
  • 19,396 Answers
Check if water is getting inside the machine from water supply at the back.
Check that there is no water inside the machine and that drain hose is not clogged.
  • Ginko
    Ginko Nov 23, 2008
    If the drum does not start the cycle at all or stops before filling, then check:
    That water is getting inside the machine from water supply at the back.
    If water supplies are fine, but machine is still not filling, then it is usuallya faulty inlet valve.
    Check that there is no water inside the machine and that drain hose is not clogged. Eventually free the drain lines if needed, if the machine is not draining it can be a defective drain pump
    If instead the machine complete pre wash then it stops , that means that there is a problem with water heating, controller is not detecting that water is hot enough and cycle is not advancing. In this case machine completes the cycle if you manually advance the timer.
    Check if water inside the machine is getting warm. If water is not getting hot you have a bad heating element, if water is hot but cycle stays stuck at this point, then it is a faulty thermic sensor not detecting water temperature.
    See here a generic diagram as reference: Front Load Frigidaire/GE/Kenmore Style
    Try entering model number here to get parts and schematics.
    Or try here.
How do i repair a bosch classixx 1200 washing machine that wont pass the first cycle
I had the same problem, if you replace the element it will solve your problem, happy washing.
Oct 17, 2014 | Bosch Washing Machines
My Bosch washing machine won't turn the bowl
Hi Justene,
i Think its control circuit has a problem.
or the fuse for motor drive circuit is damaged.
please check with electrician.
regards.
nuwan
Jan 13, 2014 | Bosch Washing Machines
BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
Feb 16, 2009 | Maytag PAV2300 Top Load Washer
The prewash light sometimes comes on in my bosch washing machineo
I think you should concern with the manufacturers of this company because concerning someone might be risky. UK Academic Writers
Jul 25, 2017 | Bosch WFMC 3200 Front Load Washer
My Bosch WFF 2000 washing machine goes through its cycle and then leaves the on/off button lit, the door button lit and the pre-wash button flashing; also the door will not open until you turn all the...
The problem turned out to be foreign objects in the pump that stopped the machine from draining; the solution is simply to open up the pump and remove the objects!
Sep 09, 2008 | Bosch Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Bosch wff 2000 washing machine - won't spin/drain
How did you solve this problem. I have the same problem. Kiran
Mar 09, 2008 | Washing Machines
Detergent dispenser
As far as I am aware, there IS NO dispenser for bleach, you have to put bleach in drum before adding clothes and starting cycle. The far right compartment is only for "pre-wash" cycles, and if no pre-wash is selected, water will run through ALL compartments at the rinse stage..... Oshie
Feb 28, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
