Question about D-Link AirPlus DI-524 Wireless Router
How can i know the routers commands to configuare a cisco router ? Thanks
  • Teis Thomsen
    Teis Thomsen May 11, 2010
    the user/password is cisco/cisco if you haven changed it, - now you are in - what do you need to know?
    Scholar:
  • 70 Answers
Question mark is your best friend if you don't know when what commands you can type, but learning how to configure a cisco router is not a 2 minutes thing and 1 post is far not enough to tell you all about it. A list of commands won't do too much good for you anyway because there are 3 different modes and each has it's own commands and there are lots of commands.
If you want to learn the basics I suggest you to read their most basic book "CCENT/CCNA ICND 1"
Or try out their SDM, that way you can configure the router with good old fashion pushbuttons and check out the commands what it's sending to the router.
Here's a little bit of showaround about SDM:
If this isn't going to help you out I suggest you to post another question where you are specifically telling what you'd like to do and some expert will write down the commands, but you need to be very specific with the details of the network and the requirements and the services you need, wich routing protocol you'd like to use, etc...
Posted on Nov 26, 2008
Problem with cisco 2513 routers
Check what version of software do you have. Do "dir" command and look at the file name. If it contains "K9" in the name, then it has "crypto" functionality, if it doesn't, then you need to find it (however it will be quite a challenge, as these routers are end-of-life for a decade...)
Good luck,
Mike ' CCNP, CCDP, CCSP, CCVP, etc.
Cisco Compatible Headset Adapters for 7940 7960 etc
Mar 30, 2017 | Cisco Computers & Internet
I would like to configure port fowarding on the Cisco 857 router using the http interface rather than via any coding. Is it possible and what do I need to do? In my scenario, the router must be configured...
It is possible to configure your router via a web browser. Although it’s disabled by default, your router has its own mini HTTP server built in. This provides another way to gain access to the router for the purpose of issuing commands. To enable the HTTP server, you have to use the command "ip http server" from the global configuration mode.
cisco(config)#ip http server
cisco(config)#
Then open a web browser and point it to one of your router’s IP addresses. The interface is not really nice, but you can issue commands using hyperlinks.
For security reasons I still suggest that you keep the HTTP server turned off, since it offers just another point of access for potential hacking.
What is so bad about the command line? Configuring port forwarding is actually pretty easy, once you know the commands.
Type show ip interface to find the name of the interface you want to set port forwarding for.
The show ip nat translations command shows you the current port forwards on Router.
Type configure to enter the configuration mode
The command for port forwarding is: ip nat inside source static (TCPorUDP) (YourComputersIP) (PortToForward) interface (name)(PortToForward)
in you case:
ip nat inside source static tcp 192.168.0.1 5900 interface (name) 5900
and
ip nat inside source static tcp 192.168.0.2 5901 interface (name) 5901
replace (name) with the interface name you got from the first command.
Then press CTRL-Z to end the Configure Session
Type copy run start once you tested your settings and press ENTER for the question Destination filename [startup-config]?
I have heard of some commercial tools that let you configure your router via web interface, but they are very expensive (around 1400$).
You can try it out for 14 days. Go here.
If you want to play with a free one, go to Cisco (link) and check it out. (You have to be a member though.)
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Oct 24, 2009 | Cisco 857 Router (CISCO857K9)
What command will show the maximum bandwidth a
The command is : bandwith ?
will show you the maximum bandwith
Jun 23, 2009 | Cisco 7505 Router
Cisco VPN Issue
If you are using the firewall feature set on the 1841 then make sure, you have all permit statements right and nonat statements in place. Try command line as well and go over some router to router example configs from Cisco's website
Jun 13, 2009 | Cisco 1841 Advanced Security Feature Pack...
Ethrnet problem for cisco 1841 router?
Hi
You must enter the interface configuration mode and issue the command:
no shutdown
Mar 19, 2009 | Cisco (1841) Router (cisco1841)
Hi all. Now i'm lose IOS of cisco 2691. help me! and give me how to load IOS to Cisco 2691 by tftp. thanks alot
Recovering Cisco IOS Software imagesIf your Cisco router experiences difficulties and no longer contains avalid Cisco IOS software image in flash memory, you can download a newCisco IOS image using one of the following ROM monitor commands:
blank.gifxmodem—(AllCisco 2600 series routers) Use this command to copy a Cisco IOS imagefrom the console, if the computer attached to your console has aterminal emulator with Xmodem capability. See the "Copying an Image from the Console Using the xmodem Command" procedure.
note.gif Note blank.gifDownloadinga Cisco IOS image from a console is very slow. This procedure should beused only in an emergency and is not recommended for normal Cisco IOSimage upgrades.
For the fastest possible download from a console, set the console speed to 115200 bps by using the confreg ROM monitor command. See the "Configuration Register Commands" procedure.
blank.giftftpdnld—(ExceptCisco 2691) Use this command to copy a Cisco IOS image from a TFTPserver that is accessible through the FastEthernet 0/0, Ethernet 0/0,or Token Ring 0/0 port. See the "Copying an Image from a TFTP Server Using the tftpdnld Command" procedure.
note.gif Note blank.gifThetftpdnld command is not available on the Cisco 2691 router. Therecommended method for installing a Cisco IOS image on a Cisco 2691router is from a CompactFlash memory card loaded in the externalCompactFlash memory card slot. See the "Entering Boot Commands" procedure.
P.S.: If this information was helpful, please rate this solution.
Mar 12, 2009 | Cisco 2691 Series IOS
I have cisco router 857 and dont know how to configure
Hi!
You can access the user manual for your router by going to:  http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/857sg_bk.pdf
But simply put,  - You have to enable the web interface in Hyperterminal/Telnet/Terminal - To connect to your router this way, open your Terminal and type the following commands in order:
1) enable (enter password if necc.) 2.) config term 3.) ip http server (this command might also be set to "no ip http server") 4.) exit
After doing the above: 1.) Press Cntrl+Z 2.) Go to Copy, Run, Start 3.) Open your browser and go to "10.10.10.1"
Good luck! -TJ
Nov 30, 2008 | Cisco 857 Router (CISCO857K9)
Help me plz
cisco routers make use of an IOS software for configurations.
you have to connect the router to a computer system through an hyper terminal program in order to access the router command interface,there is no way you will be able to configure this router without having cisco configurations knowledge.
the steps could be complex/complecated for a novice.but all the same,
after running the hyper terminal program on your computer to connect the router(start-accessories-communication-hyper terminal) make sure you use cisco serial cable or a cat5e roll over cable.
press the enter key once and type 'enable' then press enter,
configure terminal,to take you to a global configuration mode.
i will advice that you should contact a cisco person in your area for help
Apr 23, 2008 | Cnet CN UM56-RS (CNUM56-RS) Modem
D-Link AirPlus DI-524 Wireless Router Logo
151 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
