Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Service Manual Dear Sir, We are in the UK and although my double drawer dishwasher is branded Whirlpool ADG2900, I see that it is made by Fisher & Paykel. The top drawer motor started making a different noise about 3 months ago and now there is some dirty water left in the drawer after the cycle completes. The pots remain dirty. If you could get me the service manual I could try and sort it out. Please help! Thanks, RP.
  • Fisher and P... Master
  • 3,791 Answers
The top spinner is just clipped on. if you look at it you will see the cut in the plastic and it will just pull off. clean out the spinner and in the hole use some pipe and blow down it. on first cycle it should empty the dirty water out.
Posted on May 25, 2017
  • 125 Answers
SOURCE: Fisher& Paykel
Its under the bottom drawer dry out and re-assemble
Posted on Jan 12, 2008
  • 413 Answers
SOURCE: How can I fix my Fisher and Paykel DD 6031 Dishwasher? its leaking
When a flood condition is detected, both draws will activate the drain motors and flash F1. Remove the bottom drawer and dry the catch basin.
There are three possible scenarios;
1. Defective lid motor(s)...Each drawer has two lid motors, attached to the cabinet on either side of the drawer, that pull the lid tight to the drawer when the cycle is started. (this was very common on early models)
2. Something too tall was placed in the drawer preventing the lid from closing completely.
3. (only seen this once) the drain hose developed a crack causing water to leak only when draining.
If you need further assistance, let me know
The FixYa Team.....
Posted on Jun 23, 2008
  • 125 Answers
SOURCE: fisher and paykel leak
most likely the actuators are bad. with the unit off push and hold the lock and start buttons, lock first then start, after about 6 seconds the display will flash 188. press the power button, ho will be displayed. push the start button until Ld is displayed. open the drawer in question and push the lock button and watch the lid both sides should go down evenly, push the lock key to move it up and down as needed. push the power button to exit diagnostics. if you notice that the lid doesn't go down evenly or if one side stays up replace the actuators, they come as a pair. call a dealer/servicer to order actuators. make sure to specify top or bottom as there is a difference. hope this helps
Posted on Mar 03, 2009
  • 784 Answers
SOURCE: I have a Fisher Paykel dishwasher with water in top drawer
You need a Air gap kit designed by Fisher and Paykel to address this problem. It is pricey but it is worthy. I used this and very happy with it since no back flow problem from one while other running. Here is a link to order it.
Posted on Dec 29, 2009
SOURCE: Fisher Paykel double drawer dishwasher DS6031
you have an overflow leak problem....shut off circuit breaker or pull fuse....let it dry out for up to 4 days; hopefully overnight; peak under dryer and feel metal drip pan and if wet you might be able to dry with a hair dryer...WHY? the lid did not seal when you put cycle on...the lid lowers and you had something..typically too bid glasses on second shelf that was above the seal lip of the tub...stack correctly after this and no worries...
Posted on Jan 05, 2010
Top half of my dish washer beeps when i push the power button
you will find this diagnostic service document useful.
The likely reason for top drawer not starting wash program when you press start button is the drawer home sensor is either faulty or the drawer is misaligned. This means controller thinks the drawer is open and does not start the cycle.
Apr 28, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Keep blowing fuses
This means there is water collected on the base of the dishwasher cabinet under the bottom drawer. You will need to disconnect the dishwasher mains plug and take the bottom drawer out to dry the base out. Follow instructions in this manual (page 7 step 2) to remove the drawer.
Fisher Paykel DishDrawer Installation Instructions ManualsOnline com
Jan 08, 2014 | Dishwashers
My dish draw **** up with a service code f 1 , what does this mean
This can mean several things. If you have double drawer dishwasher then you need to confirm if you get the F1 message in both drawers or just one.
If both drawers then it is caused by water leakage and flood switch activiates. If only in one drawer then the power supply to the other drawer is blown.
For single unit drawer it means flood switch triggered.
Dec 26, 2012 | Fisher and Paykel 24 in. DS-603 Built-in...
Fisher paykel dishwasher double drawer
Download this manual from Fisher Paykel and examine the parts list for a hose joiner ( mergese two into one) This link provides you with contact information from the manufacturer but if you have a Lowes department store nearby, they carry that brand and can probably get you the part you need...
Also: Have you tried contacting the place that sold it to you for a replacement? They may be your best bet...
Hope this helps you..
If it does, please rate my response accordingly.. Thanks
Oct 01, 2008 | Fisher and Paykel GWL11 Top Load Washer
FP DD603 draining problem
This device will solve the issue of cross-draining between drawers on Fisher paykel double dish drawers.
Aug 10, 2008 | Fisher DD603B / DD603W / DD603H Dishwasher
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
85 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
