Question about Weather King Heating & Cooling
Weather king works for 15 seconds and stops working
I cleaned every thing you can see and I still can not get it to work.
If we do not turn on the heater for a few hour it will start on its own
but once it stops it will continue to go for 10 second stop and it
will just continue to on off, on off every 10 seconds.
  • 306 Answers
If you are talking about a furnace the problem sounds like the flame proving device located at the end of the burners. Looks like a solid wire hanging down into the flame. Take some steel wool and gently remove the carbon that has built up on the surface. Don't get rough with it as just a mild touch will be good.
Posted on Nov 23, 2008
  • Ken Bledsoe Dec 17, 2008
    Did you try what I suggested to do? ken
  • Ken Bledsoe Feb 14, 2009
    do you still have problem?
Frigidaire front load washer will start and after about 2 seconds will stop. Lights will go from normal working to no spin
From what you have described I would have a professional diagnose the unit's timer and main control board for possible replacement of those parts.
Aug 31, 2012 | Frigidaire FTF2140FS Front Load Washer 10...
I have RUUD furnace with build in coil for air conditioner and Weather King compressor outside of my condo. ALL EQUIPMENT IS 4 YEARS OLD I didn't have any problem with heat at winter, but in summe
When you remove the panel to the unit it turns off the power to it. The reinstalling the panel will reconnect power and allow the unit to reset. So the cheapest and easiest thing you can try is to replace the thermostat. Make sure you see how many wires you have connected to your existing tstat and buy near the same thing. It's possible that the tstat is acting up, not allowing the unit to cool when the temp demands. And turning off power is resetting the tstat as well as the unit. It will be hard to troubleshoot with the info provided so a new tstat will be worth a shot. Hope this helps!
Apr 07, 2017 | Ruud Matching Split Air Conditioner
Fan stopped working
Try to turn the fan by use of a long screw driver or other object. If it feels like it is siezed or getting very hard to move then the fan motor needs replaced. If it turns freely I would replace the capacitor and if that does not solve it then replace the fan motor too! Capacitors are cheap and fan motors are $80 to $120 average!
Jul 08, 2010 | Weather King 10AJA4201AH Air Conditioner
Weather King 13AJA36A01 AC freezing up at night
check the inside coil is dirtyor may be low on freon
May 14, 2009 | Weather King 12AJA4801AH Air Conditioner
Weather King question?
check the capacitor outside, if that doesnt work let me know.
Jun 27, 2008 | Weather King 10AJA4801AH Air Conditioner
Not cooling predictably
Possible causes are dirty filters, dirty condenser coil, dirty evaporator coil, or low referigerant charge. Any one of the conditions will affect heat transfer.
Check the filters in your indoor unit, If they seem to be clean and replaced on a regular basis, your evaporator coil is probably in good shape. Unfortunatley on some Weather King models even checking the evaporator coil is not possible due to the extensive amount of referigerent lines that block access to the coil without some major work including evacuating the refrigerant.
The most likely cause is a dirty outdoor condenser coil. On weather king models you will have to remove the casing that surrounds the coil because is is built in such a way that the condenser coil cannot be properly cleaned with the casing in place. Once it is removed make sure breaker is switched off and clean the coil with a water hose.
If your outdoor coil is not dirty then it is a refrigerent problem.
Jun 10, 2008 | Weather King 10AJA3601AH Air Conditioner
Heating & Cooling Logo
70 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
acrman404a
Level 1 Expert
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
