Question about Bosch Classixx WVF 2402 Front Load Washer/Dryer
Fluff in drum blocking pump
Can't clear as I can only get access to the inside of the pump (the filtered water side) from the removal cap at the front of the machine
Appliance smells of standing water, unscrewed the pump cap, there was a small amount of water and some congealed soap, turned the machine upside down,more water- came out-clear, took off inlet hose to pump, some soap and small amounts of black decomposed gunk. will this solve the prob?
Posted on Aug 22, 2009
  • Bosch Master
  • 3,463 Answers
Hi.
You will probably have to remove the hose from the drum to the pump to clear the blockage.
access is from the rear.
Posted on Nov 23, 2008
My Bosch wfmc2100 continues to add time to the timer and when I place it in spin mode I hear pump come on and drain but it acts like its still agitating the clothes and never Ramps to speed.
Some times if you wash large and small items the washer cannot get the clothes balanced enough to go into high spin. The washer being out of level can also cause this problem. Another issue that can cause this is the drain fluff/filter is plugged a bit and wont let enough water to the drain pump fast enough and when the timer sees that there is still water in the drum it adds more time to allow for the water to be removed. front bottom access panel will get you into the fluff/filter to clean it out. Make sure to get all the threads clean of sand and debris and use light oil to replace the cap or you will break it trying to reseal it.
Jul 29, 2016 | Bosch Washing Machines
Miele w340 coming up error check drain ..there is no problem with the pump or the pipes as have given the pump a direct feed the pump is good and the water drains out as it should within 60 seconds
Hi dear.
Try out followings see if it helps.(if you know what you are doing.).
1-Unplug machine from power.Remove the fluff filter. Pour some water in to drum and monitor how quickly comes out amount of water poured in to drum. If it's slow there is a blockage between tub to fluff filter hose.
2- There is a non return valve on the machine. When you remove top cover, it's located back LHS. Remove the part but careful not the drop tiny ball inside of it. Check for blockage. Another hose comes from front to middle of LHS panel and joins Y shape attachment. Check that hose also for blockage. Try to blow air in it while keeping fluff filter open. If its blocked, needs properly cleaning.
I hope that helps. Thanks.
Mar 06, 2016 | Miele Washing Machines
Wont drain?
Check the pump filter which could be blocked or something like a nail has jammed the pump impeller. this may cause a mess as the water needs to be drained to access the removable cover to gain access to the filter/impeller.
Also check the drain pipe is not blocked. this can also be used to drain the machine into a bucket manually.
Apr 28, 2015 | Washing Machines
My housemate washed two garments in my WT540 AQUARIUS HOTPOINT MACHINE and now water is stuck in the drum and not moving. The door is locked. How do I wash out the water so I can get those two garment
something has blocked the pump I susspect, turn off the machine!!! there should be a small cover or door at the base of the machine, have a baking tray and large towel ready to collect the water, open the pump cover place the tray as close as possible and if you have a small tube inside then remove the plug and drain the water to the tray.if its just the screw cap then unscrew the cap behind the cover anti clockwise, water may begin to empty so be ready to either screw the cap back in or replace the stopper as the water in the machine will fill the tray several times, when all the water is empty check the pump is clear by looking into the hole the water flowed from, remove any obstrustion ( if you have the tube you will also have a screw cap to access the pump filter) when obstuction is cleared, screw caps back in and put stopper in, switch the machine on and select a spin cycle,let it finish and end, this should sort it out.
Dec 06, 2013 | Hotpoint Aquarius WD63 Front Load...
Wasing machine fills with water during washing and wont pump out filling the drum...
1. Empty the drum via the filter / trap at the front (there is sometimes a drain pipe near the filter - otherwise be prepared to use lots of towels to soak up the water).
2. Check / clean the filter.
3. Ensure that the drainage pipe is not blocked.
4. Check that the pipe from the pump to the waste water pipe is not kinked / blocked.
5. Check that the pipe from the drum to the pump is not blocked.
6. Does the pump sound like it's trying to work? If not, it could be that the pump is dead. Pumps can often become blocked with fluff / slime from the machine.
Jan 13, 2011 | Bosch Washing Machines
Duet GHW9150P Front Load Washer: I find water in the drum after i have washed cloth...
Check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water coming from soap compartment. is there someway to clean the dryer fluff from machine
It sounds like the water outlet is blocked. Same happened to me.
Unplug machine from mains.
Remove panel located on the rear near the base of machine.
In the bottom right corner you will see the outlet pipe and the pump.
Remove grey outlet pipe to get better access.
Undo the large jubilee clip where the black pipe joins the drum outlet.
Inside this pipe is a white plastic cage filter.
Check to see if anything is blocking it.
Jan 07, 2010 | Hotpoint Ultima WF840 Front Load Washer /...
I wonder why there is still water left inside my front load after draining. It used to be totally drained. But now as you turn the drum by hand you can hear water inside of it. My samsung is Wd 6102
Hi the likely problem is a blocked drain filter or a bad pump. Their will either be a small door at the front right or a removable panel under the door. gain access to the pump and beside the pump there will be what looks like a gas cap on a car. unscrew it and clean the filter. If you don't see too much that would block the filter then your problem is the pump replace it. If you have any other questions please feel free to comment. Mike
Dec 06, 2009 | Samsung Washing Machines
The washer is not draining or spinning properly and the display shows the letters Sd! Help!
Hi, It sounds like the pump is plugged up. Remove the front lower panel and locate the pump. The pump has an access cap that you wil need to remove. You will need to lower the drain hose into a bucket or try and remove the water with a wet/dry vacc before removing the pump cap. (You will get wet)
Once you can remove the pump access cap, clean the filter out and check inside the impeller opening to see if it has any lint plugging it.
Please let me know if I have helped you at all or if I can assist you further,
Thanks
Vic
Jul 18, 2009 | Kenmore 46462 Front Load Washer
Water is not draining out completely after the wash.
This is a common fault if your drain hose or the drain pipework after it is blocked by tissues or fluff etc remove the drain hose from the vertical drain pipe or u-bend connection and check that all are free of obstructions. Also a lot of machines have a filter located at the bottom of the machine either behind a flap at the front or located near the pump at (usually) the back of the machine underneath. This can be got at by either removing the back panel if there is one or tilting the machine forward to access it from underneath chock the drum with wood to avoid drum suspension damage or re- attach the drum bolts which were removed when the machine was delivered if you still have them. The pump will have a rubber hose attached before it and the pump is connected to the machine end of the drain hose, often the rubber hose is large bore and incorporates a hard plastic filter designed to trap buttons coins etc before entering the pump and damaging the impeller blades, remove any debris.
In essence you are making sure the the whole drainage route from the drum to the final drain point is clear and free flowing.
Jul 14, 2008 | Hotpoint Dishwashers
Bosch Classixx WVF 2402 Front Load Washer/Dryer Logo
193 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
