Question about Hotpoint Washing Machines
I have a hotpoint WF540 Could you tell me what the flashing lights- on/off,final spin,wash enhance,reduced creases,rinse hold and mini load, mean these all flash when switching on and trying to use, eventually it will usually start correctly if the mains are switched of and switched on again Thanks ****
  • 1 more comment
  • mg188 Nov 23, 2008
    Very helpfull thanks very much
  • Hotpoint Master
  • 19,396 Answers
If they flash all at the same time means that there is a faulty control panel.
Try unplugging power cord for one hour to see if it clears the error.
Posted on Nov 23, 2008
  • Ginko
    Ginko Nov 23, 2008
    If the error (lights flashing) do not go away after restarting, then check if there is water inside the machine.
    If there is water, check the drain hose and unclogged it, a faulty draining pump can also jam the control timer, and give you the problem.
    If there is no water inside the machine, water supplies are connected regularly, and the cycle is not advancing with the panel flashing like a christmas tree, then you need to replace the control/timer assembly.
    Try entering model number here to get parts and schematics.
    Or try here.
2 Suggested Answers
  • 53 Answers
SOURCE: hotpoint wf540 stopping on a rinse and spin and
check pump/filter/outlet hose for blockages. if ok, check pressure switch (disc shaped item at top of machine with 4? wires and a tube) by blowing into it gently - should hear clicks, then blow into tube to pressure chamber - should be clear.
Posted on Oct 26, 2009
Hotpoint fault codes
try a different store.
Oct 31, 2013 | Washing Machines
My hotpoint washing machine WF560 mini load and reduced creases lights are flashing and also the on/off light is also flashing, please help. Thanks
Heating eliment or PCB, is this when doing a prewash? or a normal wash excluding pre wash?
if you can manualy pump out and manualy rinse and spin, my guess is heating eliment is broke £20-£30
Jan 27, 2011 | Washing Machines
Hotpoint wf540 stopping on a rinse and spin and
Oct 26, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Flashing lights
Sounds like a fault code Ring your local dealer They should have a list of codes and what they mean Hopefully they'll be kind enough to tell you over phone
Oct 22, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Lights flashing on WF320P
i'm having same problem people have said empty filtter but i have done that and the water is running out but still flashing
so sorry wish i could help.
Sep 05, 2009 | Hotpoint Aquarius WF000 Front Load Washer
The 3 buttons
button selection : To select an option press the button and you will see a light come on above the button. Press again to cancel and the light will go out. You cannot alter the options once the machine is running. Note : remember to cancel buttons after use!
As you look at the machine
Left hand button... Rinse Hold.. use this option to Help reduce creasing of delicate or synthetic fabrics by holding clothes in the final rinse water. The rinse hold light will flash to indicate that the programme is holding final rinse water. Complete the final spin by pressing the Rinse Hold button when light is flashing.
This is not available with Wool or Spin only programmes.
Middle Button.... Energy Save... use this option to save money and time on lightly soiled loads. This is not available with the Quick Wash, Rinse and Spin, or Spin Only programmes.
Right Hand Button .... Super Rinse... use this option for Large Wash loads and items for young children or people with sensitive skin. This option increases the water level for the first two rinses. This is not available with Cold Wash, Rinse and Spin or Spin Only programmes.
Copied from my Hotpoint FEW12 user instruction sheet.
Hope it helps.
Sue
Jul 31, 2008 | Hotpoint First Edition FEW12 Front Load...
WF540 - Won't work and rinse hold and wash enhance lights flash?
Hi ya, just a quick suggestion, have you cleaned the filter on the front of your machine?? My machine did this and it was only when i cleaned the fluff and the 5 pence pieces from this filter it stopped, Hope it helps
Dobby
May 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Wma54
will help type this into a search engine it the user manual !http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WMA50_WMA52_WMM53_WMA54_WMA56_WMA58_WMM59_small.pdf
Feb 15, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Washing Machines Logo
180 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
